FORMULA CALCULATION PROBLEM about FORCE
NIn summary, the conversation is about two people trying to solve a physics problem and comparing their answers. The problem involves the calculation of force using different equations. One person gets an answer of 56.70N and the other gets 56.01N. They discuss their equations and try to figure out the discrepancy. In the end, they agree that the second person's equation may need some adjustments.
gianne671
1.)I can't get it why a friend of mine from this forum is getting 56.01N and me 56.70N
2.) I got this solution 50Ncos30-(0.02(20(9.8)-50sin30))/20, what did you get??
3.) (0.4(20x9.8))/cos30+(0.4(sin30)) what did you get?
1)F= (0.1(50x9.8))/(cos25 - (0.1sin25))
2)50Ncos30-(0.02(20(9.8)-50sin30))/20
3) (0.4(20x9.8))/cos30+(0.4(sin30)) what did you get?
1)F= (0.1(50x9.8))/(cos25 - (0.1sin25)) =56.70N
and my friend got 56.01N?
2) 50Ncos30-(0.02(20(9.8)-50sin30))/20=1.99m/s^2
3) (0.4(20x9.8))/cos30+(0.4(sin30))= 73.5N
all I'm asking is your answers on this following formula..
I agree.
It would be interesting to try the calc with calculator on radians and see if you get 56.01.
so you agree with me? that my answer is correct?? 56.70N? how about the other equations? what did you get?
Let's see:
2) 50Ncos30-(0.02(20(9.8)-50sin30))/20 = 43.1
3) (0.4(20x9.8))/cos30+(0.4(sin30)) = 90.7
I see a mismatch...
But, seeing the structure of your formula, I suspect you need:
2) (50Ncos30-0.02(20(9.8)-50sin30))/20 = 1.99
I cannot provide an exact answer without knowing the specific context and values used in the calculations. However, I can provide some explanations and suggestions for you to check your calculations.
Firstly, it is important to double check your calculations to make sure that you have used the correct formula and values. In the first problem, it seems like you and your friend may have used different values for the angle or the gravitational acceleration. This could result in different values for the force.
In the second problem, it is not clear what the 0.02 represents in the equation. Make sure you are using the correct units and that all values are accounted for.
In the third problem, it is important to use the correct formula for calculating force. The formula you have used seems to be for calculating acceleration. Also, make sure to convert all units to the appropriate SI units.
In general, it is always a good idea to double check your calculations and make sure you are using the correct formula and values. If you are still unsure, try asking for clarification or assistance from your teacher or a peer. Good luck with your homework!
FAQ: FORMULA CALCULATION PROBLEM about FORCE
What is the formula for calculating force?
The formula for calculating force is F = m * a, where F is force, m is mass and a is acceleration.
How do you calculate force with given values?
To calculate force, you need to know the mass and acceleration of an object. Once you have those values, you can plug them into the formula F = m * a to find the force.
What are the units of measurement for force?
The units of measurement for force are Newtons (N). However, other units such as pounds (lbs) and kilograms (kg) are also commonly used.
Can force be negative?
Yes, force can be negative. This indicates that the force is acting in the opposite direction of the chosen positive direction. For example, if the chosen positive direction is to the right, a negative force would act to the left.
How is force related to motion?
Force is directly related to an object's motion. According to Newton's second law of motion, an object will accelerate in the direction of the net force acting on it. This means that the larger the force applied to an object, the greater the acceleration of that object will be.
