Formula for calculating the output voltage of a pickup coil
In summary, the author is looking for an equation to predict the voltage output of a pickup coil, based on the number of turns, wire resistance, inductance, and coil capacitance. He is also looking for guidance on how to measure the output voltage of a pickup coil before rewinding it.
Elektrokaninen
It should be possible to calculate the output voltage in millivolts of a pickup coil
at a given frequency, based on the number of turns of wire, the wire resistance / meter,
the inductance of the coil in Henrys, coil capacitance, the BH max in Joule, or flux density in Tesla,
and volume of the core magnet,
I haven't had any luck finding an equation online, so maybe there are some wily elektro-maths-wizards here
who can help me find a way to predict the outcome of a pickup rewiring project, and work out
the final signal voltage output at 220 Hz of a coil with 7000 turns of 0.05 mm insulated copper wire
with a cross section area of 0.00196 mm³, and a DCR of 8.75 Ω/m, wound around a 1914 mm³ alnico 5 magnet
with a BH max of 44 J/m³, and flux density of 1.25 Tesla.
Any helpful ideas would be well received.
Cheers!
~E:K
I'm afraid you're going to have to measure it.
Voltage is number of turns X rate of change of flux
and i don't see a way to predict by how much the flux of your magnet will get modulated by whatever it is you're measuring.
e = n X dΦ/dt
What's the area of your 7000 turn coil?
By how much does your 1.25 Teslas fluctuate in response to that 220 hz something you're measuring?
Likes Elektrokaninen
e = n X dΦ/dt
Thank you Jim!
The problem is.. there is nothing to measure until the pickup coil is actually removed
and rewound with a different wire gauge (0.05 mm),
and then there is no going back. It would be a lot of wire to waste.
Ideally, I would like to have some approximation of the mean output voltage with moderate plectrum attack, before winding the coil;
But I can see now, this may not be as straight forward a calculation as I imagined.
The area of the coil is 1078 mm² including the area of the magnet, or 654 mm² excluding the magnet area.
126 turns x 56 outer wraps = 7056 turns.
220 Hz is the frequency of a vibrating (guitar) A-string at the 12th semitone (A3).
This was just a random frequency, it could be anything within guitar range (82 Hz to 1.3 kHz).
Since the duty cycle is 50%, the rate of change would be 440 polarity reversals per second at 220 Hz.
The amount of flux change would depend on how hard the string is attacked, which affects the amplitude of the string,
and in turn the amplitude of the signal in the coil, and the intensity of the magnetic field around the coil and into the magnet.
The only certainty is that it would be two full flux reversals per cycle.
1/440 = 0.002272 s x 7056 turns = 16.036
This figure is much too large to be signal voltage.
It should be something in the 100-300 mV range.
Is there anything here to work with?
Cheers,
~E:K
So, at 7056 turns, the rate of flux change would need to be 1 per 0.000042517 s to arrive at 300 mV,
equal to 23520 half cycles (11760 Hz), which is over 3 octaves above the highest fundamental frequency on guitar.
I suppose I should also be counting harmonic frequencies in the calculation, since they also affect the flux change.
~E:K
Nidum said:
Not full design data but useful reading :
http://www.instructables.com/id/Make-A-Guitar-Pickup/
http://makezine.com/projects/wind-your-own-guitar-pickups/
Googling the obvious ' Making your own guitar pickups ' returns many similar hits .
Thanks Nidum
Internet "How-To" guides are fine for DIY novices, who simply want to have a go at something.
but, In terms of engineering design, they're quite useless.
These tutorials are typically written (or video demonstrated) by "enthusiasts" with only the most basic
understanding of how an inductive transducer works.
Most enthusiasts still believe in the urban myth that DCR is the best indicator of pickup output,
which is an absolutely false and misguided approach. A coil with 5000 turns of 0.04 mm wire
can have the same DCR as a coil with 15000 turns of 0.07 mm wire, and these two coils will have radically different outputs.
DCR is simply the easiest value to measure with a multi-meter;
However, DCR is completely valueless for an inductor, where voltage is directly proportional to the derivative of the current.
Since the derivative of a constant (DC current) is always equal to 0.
The only real practical use for DCR is measuring the length of wire wound on a coil,
assuming the diameter of the wire is known, without cutting off 10 meter of wire to take a measurement
with an Ohm-meter.
I've been winding pickups for many years, and I'm pretty good at it.
I can easily calculate most design variables before winding a coil, such as inductance, DCR, nominal impedance, resonant frequency..
However, I've never found a formula for calculating signal voltage, and this is why I decided to seek out such a formula.
My goal is to design a pickup coil with a pre-determined (design) output voltage,
without wasting over 1.5 km of expensive enamelled finewire on one-off experimental coils,
just to take a measurement.
Making a (measured) output voltage chart of various coils is a practical method, as long as every coil is using the same wire.
0.05 mm is not a wire gauge commonly used in pickup winding, so there are no similar coils available to make a comparative analysis.
The cross sectional area of the wire decides the current capacity and resistance.
The wire diameter decides how many turns will fit in a given space.
The number of outer wraps affects the capacitance, which, together with the inductance, decides the resonant frequency.
f = 1 [COLOR=#black]x[/COLOR]√ LC
[COLOR=#black]...[/COLOR]2π
So there are a lot of variables in the wire alone, that affect the final electrical values of an inductor.
Then there are the variables of the magnet, which also have a huge effect.
There are too many coefficients involved to draw conclusions from simple DCR or voltage measurements.
Cheers
~E:K
You could conceivably model a pickup system in ANSYS . It would be a major project though .
I guessed that someone had already tried FEM modelling -
Google ' ANSYS Guitar Pickup ' and ' FEM Guitar Pickup '
Fabulous link, Nidum
V(t) = K * Cos(2PiF)
Where K is a sensitivity constant (that is constant for small signals.) For all those non-believers hook a guitar to a scope and gently thumb-pluck a string near the centre of its span and watch the near perfect sine wave for a short time. Case almost closed.
Elektrokanien is trying to calculate K .
Magnetic fields are squishy things, even small current flowing in the pickup itself will reach back around into your formulas and affect flux.
wow that's almost 3/4 inch diameter ! Way bigger than i envisioned.that's 1078/10002 = 0.001078m2 X1.25Tesla =.0013475 Weber of flux, 1.35milliWeber to slide rule accuracy
So for every 1% that a 1.35 milliWeber magnetic flux gets modulated by the string at 220 hz sinewave
variation in flux Φ(t) would be 0.01 X 1.35X10-3 sin(220pi X t)
e would be n X dΦ/dt
e = 7000 X 0.01 X 1.035 X 10-3 X 220pi X cos(220pi X t) = 65.3 X cos(220pi X t) volts, a 65.3 volt cosine waveClearly the modulation is nowhere near 1% . Malcolm says
Typically these single coil transducers have a self-inductance of about 3 Henrys and an internal resistance of about 6000 ohms – based on a typical 10,000 turn winding, and they produce typically 100 mV rms.
Magnetic field out where the strings are is probably a lot less than a Tesla.
https://www.kjmagnetics.com/blog.asp?p=surface-fields-101
How is it measured?
For some shapes, the Magnetic Field strength along the central axis of the field can be calculated using known formulas. It is a function of the shape of the magnet and the grade of magnetic material. Other methods include the use of FEA software, experimental measurement with a magnetometer, or a combination of both.
Our specified values come from these theoretical formulas, backed up by many years of empirical testing of our magnets.
Discs/Cylinders
Blocks
In the formulas above,
r = radius of a disc/cylinder magnet
l = length of a block magnet
w = width of a block magnet
t = thickness of a magnet along its direction of magnetization
x = distance from the face of the magnet. Use zero to calculate Surface Field.
interesting thread, guys !
jim hardy said:
Fabulous link, NidumElektrokanien is trying to calculate K .
Precisely!
From the first equation : V(t) = P dL/dt + L dP/dt
We find that :
Output Signal Voltage = magnetic field strength H (A/m) x (length differential / time differential) + self inductance (H) x (magnetic field strength differential / time differential)
The self inductance of 1585 m of 0.05 mm copper Ø wire = 5680 µH
But It's a long road ahead to finding the value of K
The level of precision involving magnetic fields can only be an approximation at best.
I would be satisfied with even a roughly accurate range of voltage values, just enough to get an idea of what to expect.
This is actually a very typical single coil pickup area.
e = 7000 X 0.01 X 1.035 X 10-3 X 220pi X cos(220pi) = 65.3 X cos(220pi X t) volts, a 65.3 volt cosine wave
a 65.3 volt cosine wave, that's impressive.
Now to find Vpk
Vrms = Vpk • √ duty cycle
jim hardy said:
Clearly the modulation is nowhere near 1% . Malcolm saysMagnetic field out where the strings are is probably a lot less than a Tesla.
Absolutely, the magnetic field drops quite sharply with every mm distance.
It's getting more interesting all the time!
Again, Thanks for your extremely helpful comments and calculations Jim.
and thanks for the links Nidum.~E:K
jim hardy said:
If he didnt mind a funky battery preamp , one could get real creative and buffer that thing from external loading
http://www.ti.com/lit/ds/symlink/lm4562.pdf
http://www.ti.com/lsds/ti/audio-ic/audio-operational-amplifier-product.page#
The LM4562 is an amazing OpAmp!
LM4250 is the most common OpAmp used in active pickups, such as the ubiquitous EMG-81, for example.
Personally, I prefer passive pickups.
When that 9 volt battery gets down to 70% charge, an active pickup starts to squeel like a pig.
Although phantom power can remedy that.
~E:K
Ran across this pdf. I always tend to over analyze and sometimes a page such as this brings me back to the future so to speak.
http://www.etsu.edu/physics/espino/courses/gp2sp2010/ch20.pdf
Hope it helps
What am I missing? As a first approximation, is induced voltage proportional to rate of flux change times number of turns? (As in a transformer.)
induced emf in a coil is equal to the negative of the rate of change of magnetic flux times the number of turns in the coil.
FAQ: Formula for calculating the output voltage of a pickup coil
What is a pickup coil?
A pickup coil is a component in an electrical circuit that is used to convert changes in magnetic flux into an electrical signal.
What is the formula for calculating the output voltage of a pickup coil?
The formula for calculating the output voltage of a pickup coil is V = N * A * B * ω * cos(θ), where V is the output voltage, N is the number of turns in the coil, A is the cross-sectional area of the coil, B is the magnetic field strength, ω is the angular frequency, and θ is the angle between the coil and the magnetic field.
What factors affect the output voltage of a pickup coil?
The output voltage of a pickup coil is affected by the number of turns in the coil, the cross-sectional area of the coil, the strength of the magnetic field, the angular frequency, and the angle between the coil and the magnetic field. Additionally, the material of the coil and the speed of the magnetic field's changes can also impact the output voltage.
Can the output voltage of a pickup coil be increased?
Yes, the output voltage of a pickup coil can be increased by increasing the number of turns in the coil, increasing the cross-sectional area of the coil, increasing the strength of the magnetic field, increasing the angular frequency, or decreasing the angle between the coil and the magnetic field. Using a material with a higher magnetic permeability can also increase the output voltage.
How is the output voltage of a pickup coil used?
The output voltage of a pickup coil is used to detect and measure changes in magnetic fields. This can be used in various applications such as inductive sensors, electromagnetic pickups, and guitar pickups.
