MHB Formula for changing a plane intersection angle
The discussion revolves around calculating and changing the intersection angles between planes formed by four vectors originating from a common point. The user has provided specific vectors and their angles with respect to one vector, vBC, and has outlined a method for calculating the intersection angles between the planes defined by these vectors. They seek a way to adjust the intersection angle between two planes without altering the angles between the vectors themselves, suggesting a rotation around the axis of vBC. The user also references a formula for determining the minimum distance between a point and a line, seeking clarification on the use of cross products in this context. The conversation highlights the complexities of 3D vector rotation and plane intersection calculations.
LMHmedchem
Hello,
This is a bit more complex than my previous post, but I don't think it qualifies for university level difficulty. Please move this to the appropriate forum if my assessment is not correct.
I have 4 vectors in three space where each vector has its tail at the same point (point B).
Code:
id    x        y        z
B     0.000    0.000    0.000
vBA   0.183   -0.479    0.358
vBD   1.970    2.395   -0.524
vBE  -3.798   -1.214    0.168
vBC  -5.847    4.571   -1.137
I have the angle between each vector and vBC (in radians).
Code:
∠ ABC = 2.466
∠ DBC = 1.570
∠ EBC = 0.989
Each vector pair forming one of the angles above lies on a Euclidean plane. These planes intersect along vBC. I can calculate the plane intersection angles as follows.
For the intersection angle ∠ ABC ∩ DBC (angle of intersection between planes ABC and DBC, sorry I don't know the proper symbolic nomenclature for plane intersection angles).
1. take the vector rejection of vBA against vBC
2. take the vector rejection of vBD against vBC
3. calculate the angle between the two rejection vectors
Code:
∠ ABC ∩ DBC = 2.484
∠ ABC ∩ EBC = 0.674
∠ DBC ∩ EBC = 3.125
I need to change the angle of intersection between two planes without changing any of the angles between vectors ∠ABC, ∠DBC, or ∠EBC. Changing ∠ ABC ∩ DBC would involve essentially rotating the tip of vBA in a circle around the axis of vBC while the tail of vBA stays at point B, but I don't know how to do that.
The methods I have seem for rotating a vector in 3D involve rotating the vector about one axis.
From stackexchange, a 3D rotation around the Z-axis would be,
Code:
|cos θ   −sin θ   0| |x|   |x cos θ − y sin θ|   |x'|
|sin θ    cos θ   0| |y| = |x sin θ + y cos θ| = |y'|
|  0       0      1| |z|   |        z        |   |z'|
To use such a method, I would have to translate my current coordinates so that vBC is aligned with one axis, make the 3D vector rotation, and then translate back. That seems overly involved. It seems as if I should be able to use something like the above using the coordinates of vBC.
Any suggestions would be appreciated,
LMHmedchem
Mathematics news on Phys.org
In this post:
http://mathhelpboards.com/calculus-10/12-3-63-determine-smallest-distance-between-point-line-22704-post102528.html#post102528
I showed that if we have a line described by the two points:
$$P_1\left(x_1,y_1,z_1\right),\,P_2\left(x_2,y_2,z_2\right)$$
And the point:
$$P_0\left(x_0,y_0,z_0\right)$$
Then the minimum distance between them is given by:
$$D_{\min}=\frac{\left|\left(\vec{P_2}-\vec{P_1}\right)\times\left(\vec{P_1}-\vec{P_0}\right)\right|}{\left|\vec{P_2}-\vec{P_1}\right|}$$
I would use this formula to determine the distance of the head of the vector to be rotated from the axis of rotation, and then use the formula again to determine the locus of points all having this same distance from both the fixed tail and the axis of rotation. You will likely get two circles, one of which would be discarded.
And the point:
Looking at the equation above,
does the numerator refer to the cross product of vectors (p2-p1) and (p1-p0)? Since the resulting distance Dmin is a scalar, it seems as if this should be a simple product, but "x" often means cross product when vectors are concerned so I thought I should ask. Since the shortest distance between the line and a point is a vector perpendicular to the line, the cross product also makes sense.
Sorry about not being very good with latex.
LMHmedchem
LMHmedchem
The numerator is the magnitude of the indicated vectorial cross product. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
