MHB Formula for Ellipse 'Change of Distance by Change of Theta'?
The discussion focuses on deriving a formula to calculate the change in distance between a planet and the sun in an elliptical orbit as the angle (Theta) changes. The user seeks to understand how the distance varies when Theta changes by 1 degree, emphasizing that the distance is measured from the foci of the ellipse rather than its center. Kepler's second law is referenced, highlighting the constant area swept over time, leading to a relationship involving the area of a triangle formed by the old and new radii. The formula r = b² / (a - c cos(θ)) is provided as a key equation for calculating the distance, with the change in distance (dr) determined through differentiation. The user aims to find the time (dt) associated with this angular change, linking it back to Kepler's law.
SquishyWeRRa
I am working on planetary orbits in an ellipse where the sun is at the foci, not the centre of the ellipse.
I need a formula that describes the 'Change of Distance by Change of Theta angle' where Distance represents the distance between a planet to the sun (Planet is on parameter, Sun is at foci) and Theta represents the angle swept out when a planet moves from one position to the next.
E.g. Let Theta change by 1 degree, what is the change of Distance from the planet to the sun?
Since the orbit is ellipse, the change of distance by change of radius is not constant.
Furthermore, the distance is not calculated from the centre of the ellipse, but at the foci of the ellipse’
Kepler's 2nd law states that the area swept over a specific amount of time is constant.
Assuming that each sector's segment is negligible, the sector becomes a triangle
Area of triangle= 1/2 ab sin⁡C
dA=1/2 (Old Radius)(New Radius)sin⁡(dθ)
Using small angle approximation, sin(dθ)=dθ
dA/dt=(Old Radius)(New Radius)(dθ/dt)
Summation of dA is Area of ellipse πab
Summation of dt is Orbital period
πab/P=(Old Radius)(New Radius)/2 * (dθ/dt)
I know a, b and P. I can let dθ be increments of 1 degree. I need to know how New Radius changes to Old Radius with consideration of dθ. I need to find dt, which is the time taken to sweep that specific 1 degree.
Thank you
Mathematics news on Phys.org
Hi SquishyWeRRa! Welcome to MHB! (Smile)
Here's how an ellipse with its foci looks like, including the relevant formulae.
\begin{tikzpicture}
\draw[gray, very thin,->] (-6,0) -- (6,-0); % x-axis
\draw[gray, very thin,->] (0,-4) -- (0,4); % y-axis
\draw[gray, very thin] (-5,-3) rectangle (5,3);
\draw[red,line width=2pt] (-4,0) -- (-4,1.8) node[right=1pt] {$\ell=\dfrac{b^2}{a}$}; % semi latus rectum
\draw[domain=-180:180,smooth,variable=\t,line width=2pt] plot ({5*cos(\t)},{3*sin(\t)});
\node at (1.2,-2) {$\dfrac{x^2}{a^2} + \dfrac{y^2}{b^2}=1$ };
\node at (-1.5,-2) {$r=\dfrac{b^2}{a - c \cos\theta}$ };
\node at (1.5,-3.5) {$(a \cos u, b \sin u)$ };
\draw (-4,0) -- (0,3) -- (4,0);
\node at (2,3pt) {c};
\node at (-4pt,1.5) {b};
\node at (2.2,1.65) {a};
\draw[<->, green] (-5,-0.3) -- (0,-0.3);
\node[green] at (-2.5,-5pt) {a};
\fill (-4,0) circle (0.1); % focus
\fill (4,0) circle (0.1); % focus
\end{tikzpicture}
It looks like you're looking for the formula:
$$r=\dfrac{b^2}{a - c \cos\theta}$$
The change in distance $dr$ if we change $\theta$ by $d\theta$ is given by the derivative.
And the relationship with $dt$ follows from Kepler's law.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
