tpa
- 6
How to calculate the start up torque in inch pounds to start a plastic tube of 1.90" OD x 1.50" Id that has a shaft and ball bearings on each end. The shaft will be supported on each end, and will not rotate. The tube is horizontal. It would be similar to putting a conveyor roller in a frame, taping a string over the center so it hangs down both side equally with buckets on each side of equal weight, then add weight to one side only until the roller moves.. How much force did that take in inch pounds? That is what I want to measure and need a formula for it. Then I want to be able to build a machine to measure same, if you have any ideas on that too. Something repeatable and reliable.
Thanks
Thanks
