swartzism
- 103
I'm updating some particle physics code from Pang's An Introduction to Computational Physics. It looks like he updated F77 code to F90, but kept a lot of iffy practices in like putting all of his functions, subroutines, and modules into one file without the use of a contains.
What I'm aiming for in this thread is a discussion about GOOD vs BAD programming practices rather than personal preference. Here is his code:
1. I'm more of a fan of splitting up functions, modules, and subroutines into separate files and compiling with all the file names, especially when my functions, subroutines, and modules are going to be used by other main programs as well. Is this just personal preference?
2. I've never seen "function fx(x) result(f)" notation before. Is this a bad practice or am I behind on my syntax and structure?
3. What do you have to comment on the use/non-use of a contains statement?
Thanks in advance.
Code:
! Program 9.1 !
! Please Note: !
! (1) This computer program is written by Tao Pang in conjunction with !
! his book, "An Introduction to Computational Physics," published !
! by Cambridge University Press in 1997. !
! (2) No warranties, express or implied, are made for this program. !
MODULE CSEED
INTEGER :: ISEED
END MODULE CSEED
PROGRAM MCDS
! Integration with the direct sampling Monte Carlo scheme. The integrand
! is f(x) = x*x. Copyright (c) Tao Pang 1997.
USE CSEED
IMPLICIT NONE
INTEGER, PARAMETER :: M=1000000
INTEGER :: time,STIME,I
INTEGER, DIMENSION (9) :: T
REAL :: SUM1,SUM2,S,DS,X,F,FX,R,RANF
! Initial seed from the system time and forced to be odd
STIME = time(%REF(0))
CALL gmtime(STIME,T)
ISEED = T(6)+70*(T(5)+12*(T(4)+31*(T(3)+23*(T(2)+59*T(1)))))
IF (MOD(ISEED,2).EQ.0) ISEED = ISEED-1
SUM1 = 0.0
SUM2 = 0.0
DO I = 1, M
X = RANF()
SUM1 = SUM1+FX(X)
SUM2 = SUM2+FX(X)**2
END DO
S = SUM1/M
DS = SQRT(ABS(SUM2/M-(SUM1/M)**2)/M)
WRITE(6,"(2F16.8)") S,DS
END PROGRAM MCDS
FUNCTION FX(X) RESULT (F)
IMPLICIT NONE
REAL :: X,F
F = X*X
END FUNCTION FX
FUNCTION RANF() RESULT (R)
! Uniform random number generator x(n+1) = a*x(n) mod c with
! a=7**5 and c = 2**(31)-1. Copyright (c) Tao Pang 1997.
USE CSEED
IMPLICIT NONE
INTEGER :: IH,IL,IT,IA,IC,IQ,IR
DATA IA/16807/,IC/2147483647/,IQ/127773/,IR/2836/
REAL :: R
IH = ISEED/IQ
IL = MOD(ISEED,IQ)
IT = IA*IL-IR*IH
IF(IT.GT.0) THEN
ISEED = IT
ELSE
ISEED = IC+IT
END IF
R = ISEED/FLOAT(IC)
END FUNCTION RANF
Thanks in advance.
