Fortran functions as arguments of functions
In summary, the conversation is about a user asking for help with programming in Fortran. They have a question about using user defined functions as arguments and have written a code for numerical integration. However, when they run the program, they get an error message. After further discussion and research, they were able to fix the issue by using the EXTERNAL declaration statement.
Biederman
Hi all,
It is my first time to resort to the help of members of this forum :)
My question is related to programming in fortran but I am rather new with it.
So here is the question:Can I use user defined functions as arguments of a user defined functions in Fortran?
I have written a simple code for numerical integration but when I run the program I get an error message "segmentation fault (core dumped)"
Here is the code:
C%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
PROGRAM NUMERIC
REAL :: INTEG,SINE
PRINT*,INTEG(SINE,0.0,3.14159,100)
END
FUNCTION INTEG(FUNC,A,B,N)
INTERFACE
FUNCTION FUNC(X)
REAL :: FUNC, X
END FUNCTION
END INTERFACE
REAL :: A,B,INTEG,H,TOTAL,FUNC
INTEGER N,I
! THE INTEGRATION FORMULA IS: INTEG=H*(0.5*FUNC(X0)+FUNC(X1)+...+0.5*FUNC(XN))
H=(B-A)/N
TOTAL=0.5*(FUNC(A)+FUNC(B))
DO I=1,N-1
TOTAL=TOTAL+FUNC(A+I*H)
ENDDO
INTEG=TOTAL*H
RETURN
END FUNCTION INTEG
FUNCTION SINE(X)
REAL :: X,SINE
SINE=X*SIN(X)
RETURN
END
C%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
After running I get: Segmentation fault (core dumped)
I don't know what's wrong with the code, since there is no error message during the compilation.
I would appreciate your help.
Technology news on Phys.org
You should research the EXTERNAL declaration statement if you are passing function or subroutine names as arguments.
Thank you SteamKing. I've got the program working after checking the EXTERNAL statement, as you had suggested.
Thanks again
Related to Fortran functions as arguments of functions
What is a Fortran function?
A Fortran function is a block of code that performs a specific task and returns a value to the calling program. It is a reusable piece of code that can be called multiple times within a program.
Can you pass a Fortran function as an argument of another function?
Yes, Fortran allows functions to be passed as arguments of other functions. This allows for greater flexibility and modularity in code, as functions can be reused and called from different parts of a program.
What are the advantages of using Fortran functions as arguments of functions?
Using Fortran functions as arguments of functions allows for more efficient and modular code. It also reduces the need for repetitive code, as functions can be reused in multiple places within a program. Additionally, it can make code easier to read and debug.
Are there any limitations to using Fortran functions as arguments of functions?
One limitation is that the function being passed as an argument must have a compatible type and number of arguments with the function it is being passed to. Additionally, some compilers may have restrictions on the use of functions as arguments, so it is important to check the documentation for specific guidelines.
How do you call a Fortran function that is passed as an argument of another function?
To call a Fortran function that is passed as an argument, you can use the "call" statement followed by the function name and its arguments inside the parentheses. The result of the function can then be stored in a variable for further use.
