Fortran (gfortran) compiling error
In summary: It's unclear what 'FEM' is or where it comes from. It could be related to the specific Fortran compiler being used.In summary, the individual is seeking help with programming their first Fortran program, which is not running due to a potential issue with the compiler. They provide their code and ask for feedback on what could be causing the issue. The conversation also includes discussions about various subroutines and potential errors in the code. The compiler may be having trouble finding a program or routine called 'FEM'.
zerne
Hello, I need help for programming my first program in Fortran, because it doesn't run. I think it's a problem with the compiler. What do you think?
This is my code
Code:
program Steifigkeitsmatrix
    implicit none
        real :: E,I,l,p
        real, dimension(4,4) :: Ke
        real, dimension(4,4) :: KeI
        real, dimension(4,4) :: KeII
        real, dimension(4,4) :: KeIII
        real, dimension(8,8) :: K
        real :: u,v,w
                u = 2
                v = 3
                w = 4
            read(*,*)   E
            write(*,*)  'E=', E
            read(*,*)   I
            write(*,*)  'I=', I
            read(*,*)   l
            write(*,*)  'l=', l
        p = (E*I)/((l**3)/3)
        call stiffness(l,p,Ke)
        write(*,*) Ke
        KeI   = u*Ke
        KeII  = v* Ke
        KeIII = w*Ke
        write(*,*) KeI
        call globalstiffness(KeI,KeII,KeIII,K)
        write(*,*) K
 end program Steifigkeitsmatrix
        subroutine stiffness(z,q,k)
                real, intent(in) :: z,q
                real, dimension(4,4), intent(out) :: k
                integer :: i,j
                  do i=1,4
                                    do j=1,4
                                            k(1,1)= 12*q
                                            k(1,2)= 6*(z/3)*q
                                            k(1,3)= -12*q
                                            k(1,4)= 6*(z/3)*q
                                            k(2,1)= 6*(z/3)*q
                                            k(2,2)= 4*q*(z/3)**2
                                            k(2,3)= -6*(z/3)*q
                                            k(2,4)= 2*q*(z/3)**2
                                            k(3,1)= -12*q
                                            k(3,2)= -6*(z/3)*q
                                            k(3,3)= 12*q
                                            k(3,4)= -6*(z/3)*q
                                            k(4,1)= 6*(z/3)*q
                                            k(4,2)= 2*q*(z/3)**2
                                            k(4,3)= -6*q*(z/3)
                                            k(4,4)= 4*q*(z/3)**2
                                            write(*,*) 'Zeile:',i,'   Spalte: ', j,'   Wert: ',  k(i,j)
                                    end do
                  end  do
                 return
        end subroutine stiffness
        subroutine globalstiffness(x,y,z,r)
                    real, dimension(4,4), intent(in) :: x,y,z
                    real, dimension(8,8), intent(out) :: r
                    integer :: i,j
                        do i=1,3
                                    do j=1,8
                                            K(1,1)= x(1,1)
                                            K(1,2)= x(1,2)
                                            K(1,3)= x(1,3)
                                            K(1,4)= x(1,4)
                                            K(1,5)= 0
                                            K(1,6)= 0
                                            K(1,7)= 0
                                            K(1,8)= 0
                                            K(2,1)= x(2,1)
                                            K(2,2)= x(2,2)
                                            K(2,3)= x(2,3)
                                            K(2,4)= x(2,4)
                                            K(2,5)= 0
                                            K(2,6)= 0
                                            K(2,7)= 0
                                            K(2,8)= 0
                                            K(3,1)= x(3,1)
                                            K(3,2)= x(3,2)
                                            K(3,3)= x(3,3) + y(1,1)
                                            K(3,4)= x(3,4) + y(1,2)
                                            K(3,5)= y(1,3)
                                            K(3,6)= y(1,4)
                                            K(3,7)= 0
                                            K(3,8)= 0
                                            K(4,1)= x(4,1)
                                            K(4,2)= x(4,2)
                                            K(4,3)= x(4,3) + y(2,1)
                                            K(4,4)= x(4,4) + y(2,2)
                                            K(4,5)= y(2,3)
                                            K(4,6)= y(2,4)
                                            K(4,7)= 0
                                            K(4,8)= 0
                                            K(5,1)= 0
                                            K(5,2)= 0
                                            K(5,3)= y(3,1)
                                            K(5,4)= y(3,2)
                                            K(5,5)= y(3,3) + z(1,1)
                                            K(5,6)= y(3,4) + z(1,2)
                                            K(5,7)= 0
                                            K(5,8)= 0
                                            K(6,1)= 0
                                            K(6,2)= 0
                                            K(6,3)= y(4,1)
                                            K(6,4)= y(4,2)
                                            K(6,5)= y(4,3) + z(2,1)
                                            K(6,6)= y(4,4) + z(2,2)
                                            K(6,7)= z(2,3)
                                            K(6,8)= z(2,4)
                                            K(7,1)= 0
                                            K(7,2)= 0
                                            K(7,3)= 0
                                            K(7,4)= 0
                                            K(7,5)= z(3,1)
                                            K(7,6)= z(3,2)
                                            K(7,7)= z(3,3)
                                            K(7,8)= z(3,4)
                                            K(8,1)= 0
                                            K(8,2)= 0
                                            K(8,3)= 0
                                            K(8,4)= 0
                                            K(8,5)= z(4,1)
                                            K(8,6)= z(4,2)
                                            K(8,7)= z(4,3)
                                            K(8,8)= z(4,4)
                                        end do
                        end do
                        return
        end subroutine globalstiffness
Output
Code:
Description	Resource	Path	Location	Type
../Steifigkeitsmatrix.f90:105.44: Fatal Error: Error count reached limit of 25.	Steifigkeitsmatrix.f90	/FEM	line 105	C/C++ Problem
make: *** [Steifigkeitsmatrix.o] Error 1	FEM		 	C/C++ Problem
recipe for target `Steifigkeitsmatrix.o' failed	subdir.mk	/FEM/Debug	line 15	C/C++ Problem
Unclassifiable statement at (1)	FEM		 	C/C++ Problem
Thanks for help
Technology news on Phys.org
In subroutine 'globalstiffness', the array 'K' is not dimensioned. Also, why are the definitions for the entries in 'K' contained within the loops? All you are doing is redefining 'K' 24 times. The definitions of 'K' can be placed outside the loops, which apparently are used only to print the various entries in 'K'. This curiosity also occurs in subroutine 'stiffness' for matrix 'k', which is properly dimensioned.
It seems the compiler/linker is having trouble finding a program/routine called 'FEM'.
Related to Fortran (gfortran) compiling error
1. What is "Fortran (gfortran) compiling error"?
Fortran (gfortran) compiling error refers to an error that occurs during the process of compiling Fortran code using the gfortran compiler. It is a common issue that arises when there are errors in the code or when the compiler is unable to understand the code.
2. What are some common causes of Fortran (gfortran) compiling error?
Some common causes of Fortran (gfortran) compiling error include syntax errors in the code, missing or incorrect libraries, using incompatible compiler options, and problems with the compiler itself. It can also occur when the code is written for a different version of Fortran.
3. How can I fix Fortran (gfortran) compiling error?
To fix Fortran (gfortran) compiling error, you can start by checking for any syntax errors in your code and fixing them. You can also make sure that you have all the necessary libraries and dependencies installed. If the error persists, try using different compiler options or updating to the latest version of the gfortran compiler.
4. Can I prevent Fortran (gfortran) compiling error from happening?
While some Fortran (gfortran) compiling errors are unavoidable, you can prevent them by writing clean and error-free code. It is also essential to regularly check for updates and keep your compiler and libraries up to date. Additionally, it is helpful to use a debugger or testing tool to catch any errors before compiling.
5. Is there any additional support available for Fortran (gfortran) compiling error?
Yes, there is additional support available for Fortran (gfortran) compiling error. You can refer to the gfortran compiler documentation, online forums and communities, or seek help from experienced Fortran programmers. You can also contact the developer of the compiler for specific troubleshooting assistance.
  • Linear and Abstract Algebra
10K
  • General Math
