brydustin
- 205
There are two functions that I need help with:
http://www.maths.uq.edu.au/expokit/fortran/dgpadm.f
http://www.maths.uq.edu.au/expokit/fortran/dgchbv.f
The problem I'm having is that the arguments on the line DGPADM(...) don't match identically with the explanation. For example, H, ldh and m vs. m and H(ldh,m) not sure why there is a parenthesis. If someone could give me a simple example of acceptable parameters that I could try out,that would be greatly appreciated.
I understand what to put for ideg, m, t, but not so sure about wsp, ipiv , H or the others. For example, H is a matrix, so I guess it needs a matrix as an argument... regardless could someone help me out here?! Thanks!
In the first case:
subroutine DGPADM( ideg,m,t,H,ldh,wsp,lwsp,ipiv,iexph,ns,iflag )
* ideg : (input) the degre of the diagonal Pade to be used.
* a value of 6 is generally satisfactory.
* m : (input) order of H.
* H(ldh,m) : (input) argument matrix.
* t : (input) time-scale (can be < 0).
* wsp(lwsp) : (workspace/output) lwsp .ge. 4*m*m+ideg+1.
* ipiv(m) : (workspace)
*>>>> iexph : (output) number such that wsp(iexph) points to exp(tH)
* i.e., exp(tH) is located at wsp(iexph ... iexph+m*m-1)
* NOTE: if the routine was called with wsp(iptr),
* then exp(tH) will start at wsp(iptr+iexph-1).
* ns : (output) number of scaling-squaring used.
* iflag : (output) exit flag.
* 0 - no problem
* <0 - problem
Second case:
subroutine DGCHBV( m, t, H,ldh, y, wsp, iwsp, iflag )
* m : (input) order of the matrix H
* t : (input) time-scaling factor (can be < 0).
* H(ldh,m): (input) argument matrix.
* y(m) : (input/output) on input the operand vector,
* on output the resulting vector exp(t*H)*y.
* iwsp(m) : (workspace)
* wsp : (workspace). Observe that a double precision vector of
* length 2*m*(m+2) can be used as well when calling this
* routine (thus avoiding an idle complex array elsewhere)
In the first case:
* 0 - no problem
* <0 - problem
Second case:
