Fortran program to calculate texas hold em odds
In summary, the conversation discusses calculating the odds of winning in a game of Texas Hold-em. The program will use a set of rules to estimate the outcomes of each hand and determine the chances of winning. The specific scenario given involves having a pair of King and 9 of clubs against a single opponent, making the chance of winning a constant value. The program will ultimately output this chance as the result.
mike81
The instructions are to calculate the odds of winning if you are dealt King and 9 of clubs, what are the odds of winning? I am finding myself spending more time trying to figure out texas hold em (never played before) than writing the program. So far I found a list on wiki that breaks down the winning hands by tiers. I am thinking to store the winning hands into the 8 tiers and based upon where it falls the program will count the number of hands below and divide to give the odds. I am thinking to set up the tiers into arrays? Does this sound like a solid start? I have spent too much time on the game and not enough on the program and am running out of time.
There are many different Texas hold 'ems, different rules for what beats what, split pot or do you judge on colour? Can you form a straight ace high with A+2+3+4+5, does this win or lose from the top straight? Is there a small straight? All these things naturally affect the chance.
Also, what is the dependent value? I mean, I take this is at least the number of players playing, if this is also fixed, then you don't really have a program, you have a constant number that doesn't change. For it to be a program the idea is that it depends on some input.
Another thing that doesn't make sense to me about this question is the fact that people can fault, it's perfectly possible that some one who had a hand that beats yours faults, so you need some chance of people randomly folding, to which psychology comes into play?
So I take it you're supposed to assume that all players play until the end for this experiment and there is no human intervention basically.
So more formally your problem can be expressed (probably) as:
- There are 52 cards
- each player receives 2 of those at random | you get king and 9 of clubs
- of the remaining cards, 5 of those end up randomly in the river so that each player has 7 cards, of which it shares those five with other players
- on those combinations is a total order
finally:
- what is the chance that the combination starting with 9 and king of clubs is the largest element of the set of all the combination the players make under that order.
If you look at it this way, there is with some probability theory an ability to just construct a function which takes the numbers of players as input, and the chance as a rational number as output. All you need to do is formulate that formula into an expression and you're done. This is hardly a problem of programming, rather it is of probability theory.
But, the question you pose here is vague, I had to do a lot of interpretation as I noted, so I'm not sure my formalism of the problem is the problem you intuitively described.
Edit: For strategy, I would start with the total order and define it, an orderning function that takes in two sets of seven cards and determines which is higher.
Sorry I probably should have just posted the question. Here it is,
(3) Time to win at Texas Hold-em. You are getting two cards. It could be a pair (5.9% chance), it could be suited (23.5%, good for flush prospects), it could be unsuited and unpaired (70.6%). At this stage, before ‘the flop’:
• Pair beats other cards unless both cards better (overcards) to the pair.
• Suited beats non-pair unless one of the other cards is an overcard
• Unpaired & unsuited beats same if it has the overcard, otherwise tie.
You’re dealt {K,9} of clubs “the black dog”. The opponent has one of 50x49=1,225 hands. Use a program with the rules above to estimate outcomes for each hand. Divide winning situations by losing situations (ignore ties). What are the ‘odds’ of you winning?
Well, from that story, it can be implied that you have only one opponent and this is fixed.
Therefore, the chance of you winning in that story has no dependent variable any more, it's a constant.
Your program will look similar to
print(that_constant);
(as you can see I don't know Fortran)
This isn't really a programming question as I said, this is probability theory.
I understand the importance of approaching a problem systematically and efficiently. In this case, it seems like you have made a solid start by identifying the winning hands and organizing them into tiers. Storing this information in arrays is a logical next step.
However, I would recommend taking a step back and considering the overall approach to your program. Instead of focusing solely on the specific hand you were dealt, it may be more efficient to create a more general program that can calculate the odds for any hand. This would save you time in the long run and allow for more flexibility in the future.
Additionally, I suggest researching existing algorithms or programs that already calculate Texas Hold Em odds. This could provide valuable insights and potentially save you time and effort. It is also important to prioritize your time and ensure that you are not neglecting other important tasks or responsibilities.
Overall, it is important to maintain a balance between understanding the game and creating an efficient and accurate program. I wish you success in your project.
FAQ: Fortran program to calculate texas hold em odds
What is a Fortran program?
A Fortran program is a computer program written in the Fortran programming language. Fortran is a high-level programming language commonly used in scientific and engineering applications.
How does a Fortran program calculate Texas Hold Em odds?
A Fortran program can calculate Texas Hold Em odds by using a combination of mathematical algorithms and game logic. It takes into account the cards that are dealt, the cards on the table, and the potential hands of all players to determine the probability of winning for each player.
Why use a Fortran program to calculate Texas Hold Em odds?
Fortran is a popular choice for scientific and engineering applications due to its speed and accuracy in handling complex calculations. This makes it a suitable language for calculating Texas Hold Em odds, which involves many variables and probabilities.
Can a Fortran program be customized for different variations of Texas Hold Em?
Yes, a Fortran program can be customized for different variations of Texas Hold Em, such as limit or no-limit games. The program can be adapted to take into account different betting rules and other variations in the game.
Is a Fortran program the only way to calculate Texas Hold Em odds?
No, there are other programming languages and software tools that can be used to calculate Texas Hold Em odds. However, Fortran is a popular choice for its speed and accuracy in handling complex calculations.
