Fortran programming to solve ODEs
The discussion focuses on implementing the second-order Adams-Bashforth method in Fortran to solve the first-order differential equation \(\frac{dy}{dy} = -16 t^3 y^2\) with the initial condition \(y(0)=1\). The provided Fortran program initializes parameters, computes the solution iteratively, and defines a function for \(f(t,y)\). Additionally, there is a request for assistance in generating a CSV file from the Fortran output to facilitate plotting in MATLAB. The conversation emphasizes the ease of importing CSV data into MATLAB for visualization. The overall goal is to create an effective workflow for solving ODEs and visualizing results.
ra_forever8
Consider the first order differential equation
\[\frac{dy}{dy} = f(t,y) = -16 t^3 y^2\]
with initial condition $y(0)=1$
Using second order Adams-Bashforth method, write a Fortran programming to generate an approximate solution to the problem.
Solution
Fortran:
Program adams
Implicit None
Real, allocatable :: $y(:),t(:)$
 Real:: yo, tend, h, k1,k2
Integer:: NI, i
Real,external ::f
!Asking to enter the initial vaule of yo, final time and numbers of step
Print*,  'Enter yo,Tend,NI'
read*, yo,Tend,NI
h= Tend/NI
Print*, 'This gives stepsize h=',h
allocate (t(0:NI), y(0:NI))
!Initial Conditions
t(0)=0
y(0) = 1
!After using runge kutta method, found out k1 =0 and k2= -16h^3,
   k1=0
   k2= -16*h**3
!we know that y(n+1) =y(n) + h/2(k1+K2)  at n=0
y(1) = y(0) + h/2 *( k1+ k2)
!  Loop through the number of steps to calculate the following at each step
do i=2, NI
  t(i)= i*h
write(10,*) i, t(i),t(i-1)
!Second order Adam bashforth for all n
  y(i)= y(i-1) + (h/2)*(3*f(t(i-1), y(i - 1))- f(t(i-2), y(i-2)))
 end do
 end program adams
!declaring function
   Real Function f(t,y)
   Real:: t
   Real:: y
   f = - 16*t**3*y**2
   Return
   End Function f
Now i want to plot this partial derivative ∂f/∂y = |-32 (4t^4 +1)^-1 t^3| against t using fortran to generate a file or something for the MATLAB to plot the graph.
Can someone help me
Mathematics news on Phys.org
If you write your Fortran output as a CSV file then a MATLAB script can import it via the readmatrix() function and then one can plot using MATLAB's plot() function.
https://www.mathworks.com/help/matlab/ref/readmatrix.html
A CSV file is basically a text file with each line representing a row in a spreadsheet and each line containing comma separated (or other character like | or tab) lists of numbers ala 1,2,3,4,5
As an example, y=x^2 in CSV format might look like this:
Code:
1,1
2,4
3,9
4,16
5,25
https://www.mathworks.com/help/matlab/ref/plot.html
This should give you enough info to write a simple plot program in MATLAB.
Likes Greg Bernhardt
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
10K
10K
