Fortran: Search value in array
In summary, The code reads in data1 and calculates the average of the values in data2 column 1. It prints the results as "8 2 27.5".
timewilltell
hi i have two data sets one(data1) containing
9 2 2 5 7 7
10 3 6 6 6 6
and other(data2) containing
5 20
7 30
6 40
9 50
now i want my program to search the values 1 5 7 9 from (data1) in data 2 column 1 and then take the average of the corresoinding values in column 2, for example for first line of data1 the avg of (1 5 7 9) will be
(10+20+30+50)/4=27.5
then write
8 2 27.5
and so on... till now i have written the following program,
program test
implicit none
integer :: pn,en
integer :: i
real ,allocatable, dimension (:,:) :: y
integer,allocatable,dimension (:,:) :: ix
REAL ,DIMENSION (:) :: avg(10000000)
open (11, file='data1.dat')
read (11,*) pn
allocate (y(pn,2))
do i=1,pn
read(11,*) y(i,:)
enddo
close(11)
c *************************
open(12,file='data2.dat')
read (12,*) en
allocate (ix(en,6))
do i=1,en
read(12,*) ix(i,:)
enddo
close(12)
do i=1,en
avg(i)=(y(ix(i,3),2)+y(ix(i,4),2)+y(ix(i,5),2)+
& y(ix(i,6),2))/4
end do
do i=1,en
write(*,*) ix(i,1:2),avg(i)
enddo
end program
this gives me output
8 2 15
9 2 17.5
10 3 0
which is wrong. instead of searching for value it searches for line number ... so what to change in it to search for value not line number
9 2 2 5 7 7
10 3 6 6 6 6
5 20
7 30
6 40
9 50
OK, I sort of get what you're doing here. For the set of values in data1 -- {1, 5, 7, 9} -- use each value as the line number, and take the value in data 2 from that line.
timewilltell said:
then write
8 2 27.5
and so on...
And so on? You need to be clearer in what you're trying to do here. I see where 27.5 is coming from, but where are the 8 and 2 coming from? They happen to be the first two numbers in the line in data 1 where you found 1, 5, 7, and 9, but I'm not sure that's it.
It would be helpful if you explained what each line of data in each file represents.
program test
implicit none
integer :: pn,en
integer :: i
read (11,*) pn
allocate (y(pn,2))
do i=1,pn
read(11,*) y(i,:)
enddo
close(11)
read (12,*) en
allocate (ix(en,6))
do i=1,en
read(12,*) ix(i,:)
enddo
close(12)
do i=1,en
& y(ix(i,6),2))/4
end do
do i=1,en
enddo
end program
8 2 15
9 2 17.5
10 3 0
yes you are right in the output
8 and 2 are first two numbers from data1 and 27.5 is the average.
ok i will explain
for example the first line in data1
Code:
8    2    1    5    7    9
, 8 and 2 are just selected and printed in the output as it is no operation on them. Now the program should take value 1 find this value in the column 1 of data two and similarly 5 , 7 and 9 and then take the average of the corresponsing values in column 2 of data2.
Code:
i have made the program but instead of searching for value it searches for line number and take average... so what to change in it to search for value not line number
I'm not sure, but I think you have your files and arrays switched around.
Unit 11 is your data 1 file, but the array you're working with has only two columns. It needs six columns.
Your code:
Code:
read (11,*) pn
allocate (y(pn,2))
Your other array is read from unit 12, which is associated with data 2. This array needs to have two columns, not six.
Your code:
Code:
read (12,*) en
allocate (ix(en,6))
It would also be helpful if you used array names that were more meaningful than "ix" and "y" and file names more meaningful than data1.dat and data2.dat. Give each array a name that suggests where its data is coming from. Having poorly chosen names confused you, and makes understanding your code more difficult than it needs to be.
O sorry for that, yup i have switched it in confusion
Let this data set be "xdata.dat"
Code:
 8    2    1     5     7     9
 9    2    2     5     7     7
 10  3    6     6     6     6
and this data set be "ydata.dat
Code:
5    20
7    30
6    40
9    50
Code:
 program test
 implicit none
 integer :: pn,en
 integer :: i
 integer,allocatable,dimension (:,:) :: x
 open (11, file='ydata.dat')
 read (11,*) pn
 allocate (y(pn,2))
 do i=1,pn
 read(11,*) y(i,:)
 enddo
 close(11)
 open(12,file='xdata.dat')
 read (12,*) en
 allocate (x(en,6))
 do i=1,en
 read(12,*) x(i,:)
 enddo
 close(12)
 do i=1,en
 avg(i)=(y(x(i,3),2)+y(x(i,4),2)+y(x(i,5),2)+
 & y(x(i,6),2))/4
 end do
 do i=1,en
 write(*,*) x(i,1:2),avg(i)
 enddo
 end program
Does it work now?
BTW, thanks for putting your code in [ code ] tags. Makes it much easier to read.
No, i coz i have changed nothing in the code... the file names i have switched by mistake when posting here... i am getting average with respect to line number not with respect to value of the array.
I don't see anything wrong in your code.
After you read in your x array, add a loop that prints the values. Put a write statement in your next to last loop (where you calculate avg) to make sure that you're getting what you think you're getting with y(x(i, 3), 2), y(x(i, 4), 2), and so on. If there's something wrong here, I'm not seeing it, but having the program print the values it's using will help in understanding what's going on.
Ok ill try to explain the problem more elaborately
for instance i select 5 from first line of file xdata.dat
Code:
8    2    1     5     7     9
now its fourth element is 5. When i am taking the average the program should search for this value "5" in the first column of file "ydata.dat" but instead of searching it select the second column element on line number 5. i want the program to search for this value
OK, I get it. I understand what it's supposed to be doing.
Using your example, x(1, 4) == 5. Now search through the first column of your y array until you find an entry that equals 5. In this case, it's y(2, 1). When you find it, get the value in the second column, which in this case would be y(2, 2), which is 20 in this case. That's the value you want to use for the average.
yup this is i have tried to do this
Code:
do i=1,5
do j=3,6
if (x(i,j)==y(i,1)) then
x(i,j)=y(i,2)
end if
end do
end do
but this don't work... wha i am trying to do is replace the matching values with the corresponding values in the second column that is change this file
Code:
 8    2    1     5     7     9
 9    2    2     5     7     7
 10  3    6     6     6     6
to this
Code:
 8    2    10     20    30    50
 9    2    0       20    30    30
 10  3    40     40    40    40
any help in how to to this?
Code:
do i=1,5
do j=3,6
x(i,j)=y(i,2)
end if
end do
end do
This isn't what I said. I didn't say anything about changing the values in the x array.
Suppose you're reading the first row of the x array, and you see that x(1, 3) == 1.
Iterate through the first column of the y array in a do loop until you find a value that is 1.
Code:
do j = 1,5
  if x(1, 3) .eq. y(j, 1) avg = avg + y(j, 2)
end do
You need to do this for each of the last four values in a row of the x array.
Code:
 8    2    1     5     7     9
 9    2    2     5     7     7
 10  3    6     6     6     6
to this
Code:
 8    2    10     20    30    50
 9    2    0       20    30    30
 10  3    40     40    40    40
Related to Fortran: Search value in array
What is Fortran?
Fortran is a high-level programming language commonly used for scientific and engineering applications. It was originally developed in the 1950s and has undergone several revisions since then.
How do you search for a value in an array using Fortran?
To search for a value in an array using Fortran, you can use the built-in functions INDEX or MATCH. These functions return the index of the first occurrence of the value in the array, or 0 if the value is not found.
Can you search for multiple values in an array using Fortran?
Yes, you can use the WHERE statement in Fortran to search for multiple values in an array. This statement allows you to specify a condition and returns an array of indices where the condition is true.
What happens if the value is not found in the array during the search?
If the value is not found in the array during the search, the INDEX and MATCH functions will return 0, and the WHERE statement will return an empty array.
Are there any alternative methods for searching values in arrays in Fortran?
Yes, there are alternative methods for searching values in arrays in Fortran, such as using DO loops or the FINDLOC function. However, the built-in functions and statements mentioned above are generally more efficient and should be preferred.
