[fortran90] having problem to call back the value from previous loop
In summary, the conversation is about writing programming code in Fortran 90 for a simulation of a TMz mode incident plane in 2D. The code includes parameters, initializations, and time loops for the simulation, as well as coefficients and properties for the 2D wave. The purpose of the code is to model electromagnetic fields.
s_hy
61
hi all,
I wrote programming code for fdtd 2d tfsf in fortran 90 as below:
Code:
!simulation for tmz mode incident plane in 2d
subroutine tfsf2d
implicit none
double precision             :: f0,miu,eps,delta,S,c,lambda,E0,N0
double precision             :: deltat
integer                            :: minit,pinit
integer                            :: iinit,ilast
integer                            :: jinit,jlast
double precision,parameter         :: pi = 3.14159265
double precision             :: phi,cosphi,sinphi
integer                            :: h,m
double precision,dimension(300)    :: Hm,Em
integer                            :: y
double precision             :: f,G,A,B
double precision,dimension(100)    :: k
double precision,dimension(100)    :: Vp
double precision              :: Ca,Da,Cb,Db
integer                            :: i,j
integer                            :: n,p
double precision             :: d,dp,dpp
double precision             :: Einc,Hinc
double precision,dimension(300,300):: Ezinc,Hxinc,Hyinc
character(len=20)          :: filename
double precision             :: miu0,eps0
double precision             :: deltax, deltay
double precision             :: sigma,sigmax,sigmay,sigmat,sigmatx,sigmaty
integer                            :: iinitp,ilastp
integer                            :: jinitp,jlastp
double precision,dimension(300,300) :: Cax,Cay,Dax,Day,Cbx,Cby,Dbx,Dby
double precision,dimension(300,300) :: Ez
double precision,dimension(300,300) :: Hy,Hx
!## parameters ##
 f0 = 100.0
 miu = 1.0
 eps = 1.0
 delta = 1.e-3
 S = 1.0001
 c = 1.0
 lambda = c/f0
 E0 = 1.0D0
 N0 = lambda/delta
 deltat = (delta/c)/sqrt(2.0)
 minit = 1
 pinit = 1
 phi = pi/4.0
 cosphi = cos(phi)
 sinphi = sin(phi)
 !print *, 'cosphi=',cosphi,'sinphi=',sinphi
 miu0 = 1.0
 eps0 = 1.0
 sigma = 1.0
 !print *, 'lambda=',lambda,'deltat=',deltat
 deltax = delta
 deltay = delta
 iinit = 10
 ilast = 100
 jinit = 10
 jlast = 100
 iinitp = 1
 ilastp = 110
 jinitp = 1
 jlastp = 110
 sigmax = sigma
 sigmay = sigma
 sigmat = sigma
 sigmatx = sigma
 sigmaty = sigma
!initialization for 1d grid
 do h = 1, 300
    Hm(h) = 0
    Em(h) = 0
 end do
!initialization for incident wave
do p = 1,300
 do m = 1,300
      Hxinc(m-1,p+2) = 0
      Hyinc(m,p+1) = 0
      Ezinc(m-1,p+1) = 0
 end do
end do
!initialization for field evolution
 do p = 1,300
  do m = 1,300
     Ez(m-1,p+1)=0
     Hx(m-1,p+2) = 0
     Hy(m,p+1) = 0
  end do
 end do
!properties coefficient for 2d wave
 do y = 1,45
  f = 0.5
  k(1) = 2*pi
  G = (1/f**2)*sin(f*pi/N0)**2
  A = (delta*cos(y*pi/180))/2
  B = (delta*sin(y*pi/180))/2
  k(y+1) = k(y)-(sin(A*k(y))**2+sin(B*k(y))**2)-G/(A*sin(2*A*k(y))+B*sin(2*B*k(y)))
  Vp(y) = 2*pi/k(y+1)
  Ca = 1.0
  Cb = deltat/((Vp(1)/Vp(y))*eps*delta)
  Da = 1.0
  Db = deltat/((Vp(1)/Vp(y))*miu*delta)
  !Print *,'Ca=',Ca,'Cb=',Cb,'Da=',Da,'Db=',Db
 end do
!property coefficient
 do m = 1,300
  do p = 1,300
   Cax(m,p) = exp(-sigma*deltat/eps)
   Cbx(m,p) = (1-Cax(m,p))/(sigma*deltax)
   Cay(m,p) = exp(-sigma*deltat/eps)
   Cby(m,p) = (1-Cay(m,p))/(sigma*deltay)
   Dax(m,p) = exp(-sigmatx*deltat/miu)
   Dbx(m,p) = (1-Dax(m,p))/(sigmatx*deltax)
   Day(m,p) = exp(-sigmaty*deltat/miu)
   Dby(m,p) = (1-Day(m,p))/(sigmaty*deltay)
  end do
 end do
!time loop
do n = 1,200
  write (filename, "('data',I3.3,'.dat')") n
  open (unit=31,file=filename)
!1d background wave
 do h = 1, 300
  if (Mod(h,2) /= 0) then  !j is odd;
   Em(h) = Ca*Em(h) + Cb*(Hm(h+1)-Hm(h-1))
   !print *,'h=',h,'Em(h)=',Em(h)
  end if
 end do !h
 do h = 1, 300
  if (Mod(h,2) == 0) then  !j is even;
   Hm(h) = Da*Hm(h) + Db*(Em(h+1)-Em(h-1))
   !print *,'h=',h,'Hm(h)=',Hm(h)
  end if
 end do !h
!plane wave source
  Em(1) = E0*sin (2*pi*f0*n*deltat)
!incident field
  do m = 2,2*ilast+2           !odd
   do p = 2,2*jlast+2          !odd
    if (Mod(m,2)/=0) then
     if (Mod(p,2)/=0) then
      d = cosphi*(m - minit) + sinphi*(p - pinit)
      dp = d - int(d)
      Einc = (1-dp)*Em(int(d))+dp*Em(int(d+1))
      Ezinc(m,p+2) = Einc
     end if
    end if
   end do
  end do
  do m = 2,2*ilast+2
   do p = 2,2*jlast+2
    if (Mod(m,2) == 0) then     !even
     if (Mod(p,2) == 0) then    !even
      dpp = int(d)+0.5
      dp = dpp-int(dpp)
      Hinc = (1-dp)*Hm(int(dpp-0.5))+dp*Hm(int(dpp+0.5))
      Hxinc(m,p+1) = sinphi*Hinc
      Hyinc(m-1,p+2) = -cosphi*Hinc
      !print *,'m=',m,'p=',p,'Hyinc(m-1,p+2)=',Hyinc(m-1,p+2)
      !end if
     end if
    end if
   end do
 end do
!##TFSF boundary##
 do p = jinit-1,jlast-1
   Hy(10,p)=Hy(10,p)+Dby(10,p)*Ezinc(11,p+1)
   !print *,'p=',p,'Hy(10,p)=',Hy(10,p)
  end if
 end do
   Hy(200,p)=Hy(200,p)+Dby(200,p)*Ezinc(199,p+1)
   !print *,'p=',p,'Hy(200),=',Hy(200,p)
  end if
 end do
 do m = iinit-1,ilast-1 !iinit+1,2*ilast-1
   Hx(m,10)=Hx(m,10)+Dbx(m,10)*Ezinc(m+1,11)
    !print *,'Hx(m,8)=',Hx(m,8)
  end if
 end do
   Hx(m,200)=Hx(m,200)-Dbx(m,200)*Ezinc(m+1,199)
   !print *,'Hx(m,200)=',Hx(m,200)
  end if
 end do
   Ez(11,p+1) = Ez(11,p+1)-Cby(11,p)*Hyinc(10,p+1)
   !print *,'p=',p,'Ez(11,p+1)=',Ez(11,p+1)
  end if
 end do
   Ez(199,p+1) = Ez(199,p+1)+Cby(199,p)*Hyinc(201,p+1)
   !print *,'p=',p,'Ez(199,p+1)=',Ez(199,p+1)
  end if
 end do
   Ez(m+1,11) = Ez(m+1,11)+Cbx(m,11)*Hxinc(m+1,9)
   !print *,'m=',m,'Ez(m+1,11)=',Ez(m+1,11)
  end if
 end do
   Ez(m+1,199) = Ez(m+1,199)-Cby(m,199)*Hxinc(m+1,199)
   !print *,'m=',m,'Ez(m+1,199)=',Ez(m+1,199)
  end if
 end do
!## end tfsf boundary##
!## field evolution ##
 do m = iinitp,ilastp
  do p = jinitp,jlastp
     Ez(m,p+2) = Cax(m,p)*Ez(m,p+2)+Cbx(m,p)*(Hy(m+1,p+2)-Hy(m  1,p+2)+Hx(m,p+1)-Hx(m,p+3))
     !print *,'n=',n,'m=',m,'p=',p,'Ez(m,p+2)=',Ez(m,p+2)
     !write (31,*) m,p,Ez(m,p+2)
     !if (p == 219) write (31,*) ' '
    end if
   end if
  end do
 end do
  do p = iinitp,jlastp
     Hx(m-1,p+2) = Dax(m,p)*Hx(m-1,p+2)+Dbx(m,p)*(Ez(m-2,p+1)-Ez(m-1,p+3))
     Hy(m,p+1) = Day(m,p)*Hy(m,p+1)+Dby(m,p)*(Ez(m+1,p+1)-Ez(m-1,p+1))
     !print *, 'n=',n,'m=',m,'p=',p,'Hy(m,p+1)=',Hy(m,p+1)
    end if
   end if
  end do
 end do
close (unit=31)
end do !n
return
end subroutine
i have a problem to call the tfsf boundary condition in field evolution. it's seems that the field evolution didn't react with the boundary (the incident wave = 0)...anyone have any idea which part did i make mistake or other idea how to approach this problem.
thank you
Technology news on Phys.org
You have a missing operator in Hy(m ?? 1, p+2) in your Field Evolution Loop:
I tried to use <> to indicate the position of the error but posting pushed it back to the left margin.
I'm stumped as to why your Fortran compiler didn't catch this error.
This should be clearer as to where the missing operator is.
Code:
Ez(m,p+2) = Cax(m,p)*Ez(m,p+2)+Cbx(m,p)*(Hy(m+1,p+2)-Hy(m [color="red"]<missing operator>[/color]  1,p+2)
s_hy, your code would be easier to read by humans if you added many more spaces. In the line above, the only spaces are around the '='. When everything is jammed together, it's harder for us humans to find things.
Ideally, the line above would look something like this:
Code:
Ez(m, p+2) = Cax(m, p) * Ez(m, p+2) + Cbx(m, p) * (Hy(m+1, p+2) - Hy(m [color="red"]<?>[/color]1, p+2)
   + Hx(m, p+1)-Hx(m, p+3))
Also, and this is some very common amongst Fortran programmers, there are a lot of names used that seem arcane to the point of gobbledygook. For example:
tmz
tfsf2d
TFSF
Einc
Hinc
Ezinc
Hxinc
Hyinc
Cax
Cay
Dax
Day
Cbx
Cby
Dbx
Dby
If you're writing a program that only you will debug and maintain, I suppose that's some justification for doing something quick and dirty. But when your code doesn't work, and you need to get help from others, it makes it much more difficult for others than it needs to be if your variable names have little or no connection with what they represent.
Code:
Ez(m,p+2) = Cax(m,p)*Ez(m,p+2)+Cbx(m,p)*(Hy(m+1,p+2)-Hy([COLOR="Red"]m - 1[/COLOR],p+2)
i have fix the missing part...
Related to [fortran90] having problem to call back the value from previous loop
1. What is Fortran 90 and how is it used in scientific research?
Fortran 90 is a high-level programming language commonly used in scientific and engineering applications. It is known for its efficient handling of mathematical and scientific operations, making it a popular choice for numerical simulations and data analysis.
2. What does it mean to "call back a value" in a Fortran 90 loop?
Calling back a value in a Fortran 90 loop refers to using a variable or data from a previous iteration of the loop in the current iteration. This is often done in order to update or use the value in some way in the current iteration.
3. Why might someone encounter problems when calling back a value from a previous loop in Fortran 90?
There are a few potential reasons for encountering problems when calling back a value in Fortran 90. It could be due to incorrect usage of variables or arrays, improper indexing, or a logical error in the code.
4. How can I troubleshoot issues with calling back values in a Fortran 90 loop?
If you are experiencing problems with calling back values in a Fortran 90 loop, it is important to carefully review your code and check for any errors or inconsistencies. You may also want to consult online resources or seek assistance from a more experienced Fortran programmer.
5. Are there any best practices for calling back values in Fortran 90 loops?
Yes, there are some best practices to keep in mind when calling back values in Fortran 90 loops. It is important to properly initialize variables and arrays, use appropriate data types, and avoid overwriting values unintentionally. It is also helpful to use comments and clear variable names to make the code more readable and easier to troubleshoot.
12K
