[Fortran90] how to write increment in dimension
In summary, the conversation revolves around a person seeking help with writing code for 2D FDTD polar coordinates in Fortran 90. They have encountered a problem with handling increments in real numbers, specifically for the variables r and p. The solution involves using do loops to initialize r and p with equally spaced values. The conversation also includes a discussion about the correct starting and ending values for the loops and how to properly use the implied do loop.
s_hy
61
hi all,
i am new with fortran 90. i have here codes for 2d fdtd polar coordinates. but i have problem handling with increment in dimension in real number (as higlighted below). I have googled how to write the increment in do loops, but do loops only applicable for integer. can anyone help me how to solve this.
thank you
Code:
!2d polar coordinates
!reference: Numerical electromagnetic: fdtd method (Umran S Inan, R Marshall)
subroutine test3
implicit none
double precision                   :: f0,miu0,eps0
double precision                   :: delta, dt,dr,dp
double precision                   :: vp,lam0,rph,rmh           !lam0 = lambda
integer                                 :: pp
integer                                 :: rr,m,n
integer                                 :: t
integer                                 :: i,j
double precision,dimension(202,202) :: x,y
double precision,dimension(202,202) :: Ez,Hp,Hr    !Ez,Hy,Hx
double precision                   :: Ein
double precision, parameter  :: pi = 3.14159265
double precision                   :: r
double precision                   :: p
character(len=20)                 :: filename
 f0   = 30.e9
 miu0 = 4.0*pi*1.0e-7
 eps0 = 8.854e-12
 vp   = 1/sqrt(eps0*miu0)
 lam0 = vp/f0
 dr   = 0.05*lam0
 dt   = dr/vp
! space grid 201x201
 rr = 201
[COLOR="Blue"] r = ,dr*(rr-1),dr[/COLOR]
!define deltaphi so that there are 200 points in 2pi rad
 dp = 2*pi/200        !in rad
[COLOR="Blue"] p = 1,2*pi-dp,dp[/COLOR]
pp = size(p)
!initialize Ez,Hp,Hr to zero at t=0
do m = rr,pp
 do n = rr,pp
  Hp(m,n) = 0
  Hr(m,n) = 0
  Ez(m,n) = 0
 end do
end do
! coodinate transformation
do m = rr,pp
 do n = rr,pp
  x(m,n) = 0.0
  y(m,n) = 0.0
 end do
end do
do m = 1,rr
 do n = 1,pp
  x(m,n) = r(m)*cos(p(n))
  y(m,n) = r(m)*sin(p(n))
 end do
end do
!timesteps
do t = 1,200
  write (filename, "('data',I3.3,'.dat')") n
  open (unit=130,file=filename)
!initiate sinusoidal wavepulse at center
!  Ein  = 0.0
!  Ein(t) = sin(2*pi*f0*t*dt)
  Ez(1,1) = sin(2*pi*f0*t*dt)
  !print *, 'Ein(t)=',Ein(t)
!update magnetic field equation for Hr
  do m = 2,rr
   do n = 1,pp-1
    Hr(m,n) = Hr(m,n) - ((dt/miu0/r(m)/dp)*(Ez(m,n+1) - Ez(m,n)))
    !print *,'i=',i,'j=',j,'Hr(i,j)=',Hr(i,j)
   end do
  end do
! correction for 2pi continuity
  do m = 2,rr
   Hr(m,pp) = Hr(m,pp) - ((dt/miu0/r(m)/dp)*(Ez(m,1) - Ez(m,pp)))
  end do
!update magnetic field for Hp
  do m = 1,rr-1
   do n = 1,pp
    Hp(m,n) = Hp(m,n) + ((dt/miu0/dr)*(Ez(m+1,n) - Ez(m,n)))
    !print *,'m=',m,'n=',n,'Hp(m,n)=',Hp(m,n)
   end do
  end do
!fix end point where phi = 2pi
  do m = 2,rr
    Ez(m,1) = Ez(m,1)+(dt/eps0/r(m)/dr)*(rph*Hp(m,1)-rmh*Hp(m-1,1))&
-((dt/eps0/r(m)/dp)*(Hr(m,1)-Hr(m,pp)))
  end do
!update electric field equation
  do m = 2,rr
   do n = 2,pp
    rph = r(m)+dr/2
    rmh = r(m)-dr/2
    Ez(m,n) = Ez(m,n)+(dt/eps0/r(m)/dr)*(rph*Hp(m,n)-rmh*Hp(m-1,n))&
-(dt/eps0/r(m)/dp*(Hr(m,n)-Hr(m,n-1)))
!    write (130,*) m,n,Ez(m,n)
!    if (m == 200) write (130,*) ' '
   end do
  end do
close (unit=130)
end do !n
end SUBROUTINE test3
Technology news on Phys.org
Your assignment statements in blue for r = and p = don't make sense in Fortran.
If you want to create a series of real values for r and p which are equally spaced,
then define r and p as real arrays. You already know the size of the array you will need given the
number of points you want to create in the interval. Arrays in F90 can be dimensioned in a flexible fashion
depending on your requirements.
See: http://www.cs.mtu.edu/~shene/COURSES/cs201/NOTES/F90-Array.pdf
You can also use the implied do loop to initialize the values of your arrays.
actually i have MATLAB code and trying to write in fortran. however i have problem with the interval part for r and p. however, for r i have write it id do loops
Code:
!increment r = 1,dr*(rr-1),dr
do ir = 1,rr-1
  r(ir) = (ir-1)*dr
  !print *, 'ir=',ir,'r=',r
end do
and it is work. but i have problem with p, which is for p the last value should be 2*pi-dp, with the intervalor increment is dp...and size for p is 200. ( p=0:2*pi-dp:dp). can anyone teach me how to write this increment using do loop.
thank you
Code:
n  = 200
dp = 2*pi/n
do ip = 0,n-1
   p = ip*dp
end do
By the way, your loop in the previous post seems short one extra dr...by having ir go from 1 to (rr-1) and additionally multiplying dr times (ir-1)...you have one extra -1; also, you may not want to go from 1, but 0 as my example shows to go from 0 to 2*pi-dp
Likes 1 person
thank you gsal. it's work perfectly.
Related to [Fortran90] how to write increment in dimension
1. How do I increment a value in a Fortran90 array dimension?
To increment a value in a Fortran90 array dimension, you can use the "do" loop structure. This allows you to loop through the array and increment the desired value by a specified amount. For example, you can use the syntax "do i = 1, n, 1" to loop through the array from index 1 to n and increment the desired value by 1 each time.
2. Can I use the "do" loop structure to increment a value by a non-integer amount?
Yes, you can use the "do" loop structure to increment a value by a non-integer amount. You can specify the desired increment amount in the "do" loop syntax, such as "do i = 1, n, 0.5" to increment the value by 0.5 each time. However, keep in mind that this may affect the precision of your calculations.
3. Is there a built-in function for incrementing a value in a Fortran90 array dimension?
No, there is not a built-in function specifically for incrementing a value in a Fortran90 array dimension. However, you can use the "do" loop structure or other programming techniques to achieve the desired result.
4. How do I increment a value in a specific dimension of a multi-dimensional Fortran90 array?
To increment a value in a specific dimension of a multi-dimensional Fortran90 array, you can use nested "do" loops. This allows you to specify which dimension you want to increment while looping through the other dimensions.
5. Can I use the "do" loop structure to increment multiple values in a Fortran90 array dimension simultaneously?
Yes, you can use the "do" loop structure to increment multiple values in a Fortran90 array dimension simultaneously. You can use the same "do" loop to loop through multiple indices and increment the values at those indices by the desired amount.
