Forward Transfer Characteristic of Triode - Gray Searle P1.1
In summary, the Forward Transfer Characteristic of Triode - Gray Searle P1.1 is a measure of the relationship between input and output voltages in a triode vacuum tube amplifier. It is typically measured by applying varying input voltages and creating a graph of the characteristic curve. Factors such as construction, electrode material, grid voltage, and temperature can affect this characteristic. Understanding the characteristic curve is important for determining the linearity, gain, and distortion of the amplifier, as well as selecting optimal operating conditions and troubleshooting issues.
TRAyres
This problem is from Gray and Searle's Electronic Principles:
P1.1 - The MOS transistor characteristics of Fig. 1.8 are a graphical presentation of the functional relationship
## i_{D} = i_{D}(v_{GS},v_{DS} )##
in which ##v_{GS}## is taken as a parameter and ##i_{D}## is plotted against ##v_{DS}##. Alternatively, we could display this relationship by taking ##v_{DS}## as a parameter and plotting ##i_{D}## versus ##v_{GS}##. The resulting family of curves is called the forward transfer characteristic of the triode.
(a) Use the data of Fig. 1.8 to generate this family of curves. Plot the three curves that correspond to ##v_{DS} = 2 volts, 4 volts, and 6 volts.
(b) Can a load-line construction analogous to that illustrated in Fig. 1.10 be used with this family of curves?
Figure 1.8:
Figure 1.9:
Figure 1.10:
Application of KVL to the output mesh of Figure 1.9 yields:
##V_{B} = v_{O} + v_{DS}## or, equivalently, ##V_{B}=i_{D}R_{L}+v_{DS}##
The intercepts of the load line are:
When ##v_{DS}=0, i_{D} = \frac{V_{B}}{R_{L}}## and
When ##i_{D}=0, v_{DS}=V_{B}##
For part (a), I created the LTSpice circuit of an nmos and stepped it by VDS, while sweeping VGS - this gets me the forward transfer characteristic (admittedly there is a difference between the nmos model in LTspice and the output characteristics of the nmos under consideration, but that could be fixed. It's good enough, but more importantly it allows us to get very good values whereas reading values from the graph is not very accurate).
I'll affix the LTSpice circuit to this post later.
So the question is part (b) - is there a load-line we can construct for the forward transfer characteristic? It doesn't seem like it, because the swept parameter (##v_{GS}## ) isn't in the output mesh (whereas ##v_{DS}## is). If we set ##v_{DS}## to some value, we get a horizontal line for ##i_{D}##, because the current through RL is set.
I guess I'm looking for input to see if my thoughts on part (b) are way off?
Thanks all!
Likes berkeman
Hello,
I would like to provide my thoughts on part (b) of this problem. From my understanding, a load-line construction is used to determine the operating point of a circuit by graphing the load line (which represents the load resistance) on the output characteristics graph of the device. However, in this case, we are dealing with the forward transfer characteristic, which plots the relationship between the input voltage and output current.
In this characteristic, the input voltage (##v_{GS}##) is taken as a parameter, while the output voltage (##v_{DS}##) is varied. Therefore, it does not seem possible to construct a load line on this graph, as the load resistance is not directly involved in the relationship between ##v_{GS}## and ##v_{DS}##. Instead, the load resistance (##R_L##) is used to determine the slope of the output curve, but it is not directly plotted on the graph.
In conclusion, I do not believe that a load-line construction can be used with the family of curves obtained in part (a) of this problem. However, I would be interested to hear if anyone has a different perspective on this question.
Related to Forward Transfer Characteristic of Triode - Gray Searle P1.1
1. What is the Forward Transfer Characteristic of Triode - Gray Searle P1.1?
The Forward Transfer Characteristic of Triode - Gray Searle P1.1 refers to the relationship between the input and output voltages of a triode vacuum tube amplifier. It shows how the change in the input voltage affects the output voltage, and is an important factor in understanding the performance of the tube.
2. How is the Forward Transfer Characteristic of Triode - Gray Searle P1.1 measured?
The Forward Transfer Characteristic is typically measured by applying a varying input voltage to the control grid of the triode and measuring the resulting output voltage. This process is repeated for different input voltages to create a graph of the characteristic curve.
3. What factors affect the Forward Transfer Characteristic of Triode - Gray Searle P1.1?
The Forward Transfer Characteristic can be affected by various factors such as the tube's construction, the material used for electrodes, grid voltage, and the tube's operating temperature. These factors can alter the relationship between input and output voltages, resulting in changes to the characteristic curve.
4. Why is the Forward Transfer Characteristic of Triode - Gray Searle P1.1 important?
The Forward Transfer Characteristic is essential in understanding the behavior of a triode vacuum tube amplifier. It can provide valuable information about the linearity, gain, and distortion of the amplifier. It also helps in determining the operating conditions that will produce the desired output.
5. How can the Forward Transfer Characteristic of Triode - Gray Searle P1.1 be used in practical applications?
The characteristic curve can be used in designing and evaluating triode vacuum tube amplifiers. It can help in selecting the appropriate operating points and components to achieve the desired performance. It can also be used to troubleshoot any issues with the amplifier and make adjustments for optimal performance.
