Foucault pendulum and a round globe
In summary, the Foucault pendulum can be used to prove that the Earth is a sphere. However, it would be difficult to arrive at this conclusion if it was cloudy all over the Earth.
xaratustra
38
Imagine we are all cavemen without satellite technology and just discovered the Foucault pendulum! As we know the angle of presession depends on the latitude. This can be used to prove that the Earth is rotating, right? Now by putting several Foucault pendula around the Earth, at equidistant longitude and latitude, can we prove that the Earth is a sphere as well?
You could exclude a lot of potential shapes, and by assuming certain smoothness between your sample positions narrow it down to a sphere.
cool. then all pendula must be installed at the same altitude to guarantee smoothness. :smile:
It's not about the altitude, but how densely they are spaced.
Also, since pendulums are based on gravity, you have to assume some model of gravity, which by itself might already imply an equipotential surface, without even the need for swinging pendulums.
Wouldn't it be much easier for them to just glance at the sky and notice how the position of the North Star varies with latitude?
(Flaw: The North Star moves, it was not north in all periods of history.)
If it was (very) cloudy all over the Earth, it would be harder to arrive at an initial Geocentric model Universe but the Fuocault pendulums would definitely indicate rotation. No one would every have moved to a Heliocentric model, I reckon ('till Radio came along).
FAQ: Foucault pendulum and a round globe
What is a Foucault Pendulum?
A Foucault pendulum is a device invented by French physicist Léon Foucault in 1851 to demonstrate the rotation of the Earth. It consists of a long pendulum suspended from a fixed point that swings in a constant direction due to the rotation of the Earth.
How does a Foucault Pendulum work?
A Foucault pendulum works due to the Earth's rotation and the Coriolis effect. As the pendulum swings back and forth, the Earth rotates underneath it, causing the pendulum's direction of swing to appear to change. This effect is due to the Coriolis force, which is an inertial force that acts on objects in motion on a rotating surface.
What does a Foucault Pendulum prove?
A Foucault pendulum proves that the Earth is rotating on its axis. The pendulum's movement is only possible because of the Earth's rotation, and the direction of its swing changes in predictable ways that are consistent with the Earth's rotation. This was an important experiment in the 19th century that helped provide evidence for the theory of Earth's rotation.
Is the Foucault Pendulum affected by the Earth's curvature?
Yes, the Earth's curvature does have an effect on the Foucault pendulum, but it is negligible. The pendulum's movement is primarily due to the Coriolis effect, and the Earth's curvature has a minimal impact on this force. However, the pendulum's motion may be affected by other factors such as air resistance, friction, and the pendulum's height and mass.
Can a Foucault Pendulum be used to prove the shape of the Earth?
Not necessarily. While the Foucault pendulum can demonstrate the Earth's rotation, it does not directly prove the shape of the Earth. The pendulum's motion is consistent with both a round globe and a flat disk rotating underneath it. However, other evidence, such as satellite imagery and measurements from space, support the fact that the Earth is a round globe.
