Four bar linkage odd behaviour? (Simscape Multibody)
In summary: Mech_Engineer has found a problem with the linkage dynamics that is causing the mechanism to behave in a different way when initial positions are eliminated. Simulations in Autodesk Inventor and Matlab seem to back up his findings.
Rodders
Dear community,
I posted this thread in Mathworks Simscape Community two days ago or so. And I have decided to record a video and post all the information in this forum. This is my first time, so hello and thanks for reading!
Last month I was playing around with Simscape Multibody and I realized something. They have a "four bar linkage" preset to simulate its physical behaviour, so I changed a bit the initial positions and I found this:
I have simulated the same mechanism in Autodesk Inventor and It behaves as I expected (as a pendulum). I supposed that the simmetric position in this case should be the equilibrium position, the attractor.
Then, I decided to create a new simulation in Matlab and this very weird situation popped up. But I do not see why, how, where... I mean, It goes far beyond my understanding.
Some data are:
-Connector Link (Yellow bar):
-Density: 1000 kg/m^3
-Volume: 10x2x0.5 cm^3
-Rocker Link (Red bar):
-Density: 100 kg/m^3
-Volume: 25x2x0.5 cm^3
-Crank Link (Blue bar):
Conditions:
-No friction.
-No external foces.
-Just gravitation acting.
-State targets (initial positions): specified in the video. Sorry about the size. Please watch full screen in 1080.
I would appreciate your comments on this issue, please, I really need it...
Thanks again!
So, what exactly is the issue? Looks to me like the simulation is not reflecting reality due to some minuscule unbalance in forces.
Thanks for your feedback Mech_Engineer, really appreciate it.
I have refused the possibility you mention because, when initial positions are eliminated (see 1:28 in the embedded video) the linkage behaves as expected. It oscillates around the equilibrium position (the attractor), the simmetric position. I cannot believe that just by changing its initial position, the physical behaviour could vary in such a different way...
I have simulated dynamically the linkage in Autodesk Inventor, and it behaves as shown in the video below:
It definitely looks better... I refuse to believe that a change in initial position might affect (in this way) the dynamics of the mechanism.
To double-check the dynamics of this mechanism, I have simulated in Matlab the mechanism and I have come across the following result:
My results are quite similar to Simscape Multibody (similarly wrong?).
As you can see (adjusting the resolution to 1080p), it seems there is an attractor when the angle on the upper-left is set to 0.7 Rad, the mechanism shows a minimal displacement. It seems that this position is its equilibrium position, but this is definitely wrong, as it is supposed to be the simmetric position.
I feel quite lost in this regard... Sometimes physical problems are quite frustrating and mind blowers. This one is blowing my self-esteem! XD
Thanks a lot for your time, hope anyone can help me...
Solved in Mathworks Community (link to the thread).
Thanks to everyone
Related to Four bar linkage odd behaviour? (Simscape Multibody)
1. What is a four bar linkage in Simscape Multibody and what does it do?
A four bar linkage is a mechanism that consists of four rigid bars connected by joints. In Simscape Multibody, it is used to model the motion of mechanical systems and analyze their behavior.
2. Why is the behavior of a four bar linkage sometimes considered "odd"?
The behavior of a four bar linkage can be considered odd because it can exhibit unexpected or counterintuitive motion due to the complex interactions between the bars and joints.
3. How can I troubleshoot odd behavior in a four bar linkage model?
To troubleshoot odd behavior in a four bar linkage model, you can check for any incorrectly placed or defined joints, incorrect physical properties of the bars, or any other errors in the model setup.
4. Can I control the motion of a four bar linkage in Simscape Multibody?
Yes, you can control the motion of a four bar linkage in Simscape Multibody by adding actuation elements such as motors or springs to the joints. This allows you to simulate the behavior of the linkage under different control inputs.
5. Are there any limitations to using a four bar linkage in Simscape Multibody?
While four bar linkages are commonly used in mechanical systems, they may not accurately represent all types of motion. In addition, the simulation results may not be completely accurate due to simplifications made in modeling the system. It is important to validate the results with physical experiments.
  • Mechanical Engineering
