Four fundamental forces. Which one is this?
In summary, the stability of a hydrogen atom is due to the uncertainty principle preventing the collapse of the electron onto the proton. This is not a result of any specific force, but rather a consequence of the quantum mechanical ground state of the coulomb potential between the two particles. The involvement of the weak or strong forces is not necessary to explain this phenomenon. Additionally, the stability of the hydrogen atom is not due to any interaction with a neutron, as it is the ground state of a hydrogen atom that is stable, not the neutron itself.
Antiphon
1,686
If you slowly drop an electron onto a proton, you will form a hydrogen atom. In the lowest energy state, it's stable.
Why isn't the lowest energy state an electrostatic-driven collapse of proton and electron?
More specifically, which of the four fundamental forces pushes back on the electron when forced near the proton?
It's not the strong, electric or gravitational forces That only leaves the weak force. But the interaction range for the weak force is much shorter than that.
I assume it is a force that can store and release potential energy or it couldn't oppose the electrostatic attraction.
Avodyne said:
It's the uncertainty principle that prevents the collapse of the electron onto the proton.
That's one way of thinking about it, but not the only one. In the Bohmian interpretation of QM, this effect is due to the quantum potential, i.e. a quantum force that has no a classical analogue. This force depends not only on the positions of the particles, but also on the wave function.
Not enough energy. The proton's mass is 938.2 MeV, the electron's is 0.5 MeV. Together that's 938.7. But the neutron's mass is 939.5. Sure, if you slam 'em together with > 0.8 MeV, part of the time they'll form a neutron and emit a neutrino, but it can't happen at rest, solely on energetic grounds.
I like Serena said:
I believe the Pauli exclusion principle prevents collapse.
Actually I started a similar thread a couple of months ago.
The best answer I got was a post with a list of similar threads right here on PF:
https://www.physicsforums.com/showpost.php?p=3232991&postcount=19
Thanks. From the last link on the page I Qote Borek:
So if Pauli exclusion a force? No, it's just a constraint on allowed QM states, not a result of a potential energy term. Does it look, feel, and smell like a force? Yes, because it causes a violation of Newton I, and we are trained by experience to call every violation of Newton I a force.
I see that; for example throwing a ball on a ferris wheel. You see fictitious forces. The difference here is that I can actually put a lot if energy into this fictitious force. In that case, what field is stressed with the energy?
I can for example lift a mass against gravity and store energy in the gravitational field.
By squeezing two charged spheres together you can introduce energy into the electric field, stored mostly in the space between the charges.
When forcing an electron to be closer to a proton than it would seek to be, you are putting energy into a conservative field. You could actually use this in principle to make a spring. When you wind that spring and run a clock with it, where is the energy stored?
I deliberately chose proton and electron to avoid the discussion about two electrons sharing quantum numbers.
Edit: based on the threads in the linked post I have to conclude it's the electromagnetic field operating but in some other quantum context such as the way the electrons of an atom don't radiate except in radiative transition.
Good point!
So it wouldn't be the Pauli exclusion principle here.
I was just reading up on beta-decay, positron-emission, and electron-capture (see http://en.wikipedia.org/wiki/Beta_decay" ).
In this wiki article it states that it is the weak interaction that causes a neutron to decay into a proton and an electron.
However, it does not become clear, why a neutron would be a "higher" energy state.
Edit: actually, it says that a down quark decays into an up quark, which has a lower energy-mass.
How is this view on it?
I would say that there isn't a "force" causing the hydrogen atom to be stable. I see it as a consequence of the fact that a Neutron is less stable than a Proton. Put simply, a particle is likely to decay into a more stable particle. Until it is more favorable to form a neutron instead of a proton, the proton will not combine with an electron.
For example, let's look at a neutron star. The immense force of gravity makes it more favorable to combine the electrons and protons together into Neutrons rather than to resist gravity using electron degeneracy.
Interesting, but I don't think that's it at all. The H-atom is stable because it represents the quantum mechanical ground state of the coulomb potential between a proton and electron. It cannot relax because there is nowhere for it to go. As far as I can tell there is no need to involve the weak force or strong force to explain this, but perhaps that is only because I am thinking of the non-relativistic version of the problem.
Now, that doesn't mean your analysis above is wrong .. it certainly isn't. I just don't think it answers the question in the original post.
Yeah, I hear you Spectra. I'm not sure what can actually answer the question.
I'll support the idea that its the EM field with a historical argument. The weak and strong forces weren't known in the early days of QM. But pretty good solutions to the hydrogen atom can be had using only the coulomb potentials and Schroedingers equation. From these solutions you already have the ground state of the H atom popping out. If another field were acting here besides the EM field, it wouldn't be in this model and we'd expect a poor representation of the H atom to result, no?
In other words I'm agreeing with Spectracat now.
FAQ: Four fundamental forces. Which one is this?
What are the four fundamental forces?
The four fundamental forces are gravity, electromagnetism, strong nuclear force, and weak nuclear force. These forces govern the interactions between all particles in the universe.
How do these forces differ from each other?
The four fundamental forces differ in terms of their strength, range, and the types of particles they interact with. Gravity is the weakest force, but has an infinite range and affects all particles with mass. Electromagnetism is stronger than gravity, has an infinite range, and affects all charged particles. The strong nuclear force is the strongest force, but has a short range and only affects particles within the nucleus. The weak nuclear force is the second weakest force and has a short range, but it can change one type of particle into another.
Which force is responsible for holding atoms together?
The strong nuclear force is responsible for holding atoms together. This force is what overcomes the repulsive force between positively charged protons in the nucleus and keeps them bound together with neutrons.
How do scientists study these forces?
Scientists study these forces through experiments, mathematical equations, and theoretical models. Particle accelerators like the Large Hadron Collider allow scientists to study the behavior of particles and interactions between forces. They also use complex mathematical equations to describe the behavior of particles and forces. Theoretical models, such as the Standard Model, help to explain and predict the behavior of particles and forces.
Is there a fifth fundamental force?
As of now, there is no evidence or scientific consensus on a fifth fundamental force. However, some theories, such as string theory, suggest the existence of a fifth force. Scientists continue to research and explore the possibility of a fifth force and its potential implications.
