Fourier series coefficient problem
In summary, the coefficents of a function can be arrived at by minimizing the integrated square of the deviation.
ognik
643
Hi - an example in my book shows that FS coefficiants can be arrived at by minimizing the integrated square of the deviation,
i.e. $ \Delta_p = \int_0^{2\pi}\left[ f(x) - \frac{a_0}{2}-\sum_{n=1}^{p}\left( a_nCosnx + b_nSinnx \right) \right]^2dx $
So we're looking for $ \pd{\Delta_p}{a_n} =0 $ and $ \pd{\Delta_p}{b_n} =0 $
they then jump to $ 0 = -2\int_0^{2\pi} f(x) Cosnx dx +2\pi a_n $ and I can't follow it all, would appreciate some help.
Using the chain rule for the partial deriv for $a_n$, should it be $ 0 = \int_0^{2\pi}\left[ f(x) - \frac{a_0}{2}-\sum_{n=1}^{p}\left( a_nCosnx + b_nSinnx \right) \right] \left( -\sum_{n=1}^{p}Cosnx \right) dx $ - or without the 2nd summation? They must NOT include that last summation but I don't know why?
Then clearly the $a_0$ term vanishes but I can't see why?
And please confirm - integral of a sum $\equiv$ sum of an integral?
Hi ognik,
The place where things took a wrong turn has to do with the use of indices. In the expression $\pd{\Delta_{p}}{a_{n}}$, you want to think of $n$ as fixed; i.e. we have made a choice of which partial derivative we would like to take (e.g. $n=3~\Longrightarrow~\pd{\Delta_{p}}{a_{3}}$). Since $n$ is then fixed, we need to index the sum by a different variable, say $k$, then use the relation $\pd{a_{k}}{a_{n}}=\delta^{k}_{n}$. I think you should be able to get where you want to go from here. If not, let me know. Good luck!
Thanks GJA, while I'm working on that would you mind looking at the other 2 queries I had, quoted above? Much obliged.
Thanks GJA, that's clear now; Also I read that integral of a sum $\equiv$ sum of an integral so I get to:
$ 0 = \int_0^{2\pi}\left[ f(x) - \frac{a_0}{2}-\sum_{n=1}^{p}\left( a_nCosnx + b_nSinnx \right) \right] Cosnx dx $ (I multiplied the -1 both sides)
i.e. $ 0 = \int_0^{2\pi} f(x) Cosnx dx - \frac{a_0}{2} \int_0^{2\pi} Cosnx dx -\sum_{n=1}^{p} a_n\int_0^{2\pi} Cos^2nx -\sum_{n=1}^{p} b_n\int_0^{2\pi}Sinnx Cosnx dx $
The 2nd term evals to 0, the 4th term = 0 due to orthogonality, $ a_n\int_0^{2\pi} Cos^2nx dx = \pi a_n $ but I can't find an argument to drop the summation in front of the third term?
Hey ognik,
Been away from the computer for a bit over the holiday, sorry for the delay. I think you've picked up on what I was getting at in my last post and to help push past the where you're currently stuck, it will be best to get in the habit of actually using a new summation index. For example, where you wrote
we would really want something like this (note that $k$ is being used as the summation index, while $n$ is still the frequency term of the cosine outside the parenthesis in the integrand):
$$0=\int_{0}^{2\pi}\left[f(x)-\frac{a_{0}}{2}-\sum_{k=1}^{p}\big(a_{k}\cos(kx)+b_{k}\sin(kx)\big)\right]\cos(nx)\, dx$$
(Note: We could use any letter (e.g. $m$, $j$, $r$, $s$, etc.) we want to index the sum, except $n$ and $p$ as those letters have an assigned meaning already in the problem)
After multiplying out this new expression the term of confusion now has the form:
$$\sum_{k=1}^{p}a_{k}\int_{0}^{2\pi}\cos(kx)\cos(nx)\, dx$$
Can you you see how to get where you want to go from there? You're very close to being done and I know you can get it. Let me know if this is still a sticking point. Good luck!
Understand GJA, my kids are away so I have time on my hands - and thanks for the reply.
I doubt I would recognise at the moment, when to use a different summation index, and I'm afraid I don't follow why in this case?
However assuming it, from where you introduce the 2nd index: $0= \int_{0}^{2\pi} f(x) Cosnx \,dx - \frac{a_0}{2} \int_{0}^{2\pi}Cosnx dx - \int_{0}^{2\pi} \sum_{k=1}^{\infty}a_k Cos kx Cos nx - \int_{0}^{2\pi} \sum_{k=1}^{\infty} b_n Sin kx Cos nx dx $
The 2nd term evals. to 0, the 4th term is 0 by orthogonality, and the third term $= a_n\pi$ by orthogonality for k=n only (=0 for $k \ne n$)
$ \therefore a_n = \frac{1}{\pi} \int_{0}^{2\pi} f(x) Cos nx dx $ - yay!
FAQ: Fourier series coefficient problem
What is a Fourier series coefficient problem?
A Fourier series coefficient problem is a mathematical problem that involves determining the coefficients of a Fourier series, which is a mathematical representation of a periodic function as a sum of sine and cosine functions. It is used to analyze and approximate complex periodic functions.
How do you calculate Fourier series coefficients?
To calculate Fourier series coefficients, you can use the Fourier series formula, which involves integrating the function over one period and dividing by the period. Alternatively, you can use the Fourier series coefficients table or use mathematical software to compute them.
What are the applications of Fourier series coefficient problems?
Fourier series coefficient problems have many applications in various fields such as physics, engineering, signal processing, and image processing. They are used to analyze and approximate periodic functions, which are commonly found in nature and technology.
What are the challenges of solving Fourier series coefficient problems?
One of the main challenges of solving Fourier series coefficient problems is the complexity of the mathematical calculations involved, especially for functions with multiple frequencies. Another challenge is choosing an appropriate number of terms in the series to accurately represent the function.
How can I improve my understanding of Fourier series coefficient problems?
To improve your understanding of Fourier series coefficient problems, you can practice solving different types of problems and familiarize yourself with the various techniques and formulas used. You can also consult textbooks, online resources, or seek help from a math tutor or professor.
