Fourier Series Frequency, Period, and Coefficients
In summary, the homework statement is to find the fundamental frequency and period of a sine function. The Attempt at a Solution states that the sin^2 is throwing the student off, and that they are not sure if they should integrate it first or find the frequency and period. The student was able to find the period of the function using trig identities and the frequency using a half range cosine expansion. The student is stuck trying to find the exponential and trigonometric coefficients.
ats3216
Given the function 10sin^2(10t)
Find the fundamental frequency and period.
Find the exponential and trigonometric coefficients of the Fourier Series.
I really have no idea how to start this problem. The sin^2 is what is throwing me off, as I am not sure if i am supposed to integrate it first before finding the frequency and period. Any help would be greatly appreciated.
I would start by looking at the graph of sin(t) and sin2t to see what squaring it does to the period of a sine function.
Ok, so I did as you said and checked out the difference. The sin^2(t) seems to cut the period in half, so rather than being ∏/5 in my case, it was ∏/10. So, to find my T variable, it would be:
2∏/(∏/10)
right?
Then I should be able to just plug my ω=∏/10, and T into the equations for exponential and trigonometric coefficients I think...
Sorry, this stuff is really difficult to grasp for some reason.
2∏/(∏/10)
In other words, 20.
right?
Since I don't know what your T represents, I don't know if that is right or not. But you are correct that the period of ##\sin^2(10t)## is ##\pi/10##.
Ok, so now that I know that the period of this function is ∏/10, the frequency is 20.
I graphed it first to figure out the period, then solved it mathematically. Using trig identities:
10sin(10t) = 1/2 - (5cos(20t))/2
The frequency, ω is the 20 in that equation, then plugging that into the equation for solving the period (this is the T I was referring to in my last post, sorry for being unclear):
T=2∏/ω
so T=∏/10.
Thank you for walking me through that. I understand how that part works. Now, the next part is finding the exponential and trigonometric coefficients of this function... Which I am again stuck at.
10sin2(10t) = 1/2 - (5cos(20t))/2 Note typo correction.
T=2∏/ω
so T=∏/10.
Well, there is an easy way and a hard way from here. Here's the easy way. Your function is an even function as you know from graphing it, so its expansion will not have any sine terms. You could note that your trig identity above does express your function as a finite cosine series, so if you go to the work of doing a half range cosine expansion, that is what you will get after a lot of work. And you can substitute for the cosine in terms of complex exponentials and you will have the complex form of the FS, which will also have finitely many nonzero terms.
FAQ: Fourier Series Frequency, Period, and Coefficients
What is a Fourier Series?
A Fourier Series is a mathematical representation of a periodic function as a sum of sinusoidal functions. It allows us to break down a complex function into simpler components and analyze its frequency and periodicity.
What is frequency in a Fourier Series?
Frequency in a Fourier Series refers to the rate at which a function repeats itself. It is measured in terms of cycles per unit time and determines the number of oscillations in a given period.
What is the period in a Fourier Series?
The period in a Fourier Series is the length of time or distance over which a function repeats itself. It is also known as the fundamental period and is denoted by T.
What are coefficients in a Fourier Series?
Coefficients in a Fourier Series are the constants that determine the amplitudes of the sinusoidal functions that make up the series. They represent the contribution of each frequency component to the overall function.
How are Fourier Series used in science?
Fourier Series are used in various fields of science, such as signal processing, image processing, and physics, to analyze and represent periodic functions. They are also used in solving differential equations and modeling real-world phenomena.
