Fourier series, pointwise convergence, series computation
In summary, the conversation discusses the pointwise convergence of the Fourier series for a given function, the computation of a series related to this function, and the question of whether the Fourier series converges uniformly on the entire real line. While the Fourier series does converge pointwise on a specific interval, it is not uniformly convergent on the entire real line.
Markov2
149
Let $f(x)=-x$ for $-l\le x\le l$ and $f(l)=l.$
a) Study the pointwise convergence of the Fourier series for $f.$
b) Compute the series $\displaystyle\sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)}.$
c) Does the Fourier series of $f$ converge uniformly on $\mathbb R$ ?
First I need to compute the Fourier series, so since $f$ is odd, then the Fourier series is just $\displaystyle\sum_{n=1}^\infty b_n\sin\frac{n\pi x}l$ where $b_n=\dfrac 2l\displaystyle\int_0^{l} f(x)\sin\frac{n\pi x}l\,dx$ so I'm getting $\displaystyle-\frac{x}{{{l}^{2}}}=\frac{1}{\pi }\sum\limits_{n=1}^{\infty }{\frac{{{(-1)}^{n}}}{n}\sin \frac{n\pi x}{l}},$ but now I don't know how to proceed with the pointwise convergence, also, how to do part b)?
Thanks for the help!
Hi Markov, :)
Firstly the definition of the function \(f\) seem to be erroneous, both \(f(x)=-x\mbox{ for }-l\leq x\leq l\) and \(f(l)=l\) cannot be true. So I shall neglect the latter part: \(f(l)=l\).
I think the Fourier series that you have obtained is also incorrect. It should be,
\[-x=\frac{2l}{\pi}\sum_{n=1}^{\infty}\frac{(-1)^{n}}{n}\sin\left(\frac{n\pi x}{l}\right)\]
Since both \(f(x)=-x\) and \(f'(x)=-1\) are continuous on \([-l,\,l]\) the Fourier series converges point-wise on the interval \((-l,\,l)\) (Refer Theorem 5.5 http://www.math.ucsb.edu/%7Egrigoryan/124B/lecs/lec5.pdf).
Substitute \(x=1\mbox{ and }l=2\) and we obtain,
\begin{eqnarray}
-\frac{\pi}{4}&=&\sum_{n=1}^{\infty}\frac{(-1)^{n}}{n}\sin\left(\frac{n\pi}{2} \right)\\
&=&\sum_{n=0}^{\infty}\frac{(-1)^{2n+1}}{2n+1}\sin\left(\frac{(2n+1)\pi}{2} \right)\\
&=&\sum_{n=0}^{\infty}\frac{(-1)^{2n+1}}{2n+1}(-1)^n\\
&=&\sum_{n=0}^{\infty}\frac{(-1)^{3n+1}}{2n+1}\\
\therefore\sum_{n=0}^{\infty}\frac{(-1)^{n}}{2n+1}&=&\frac{\pi}{4}
\end{eqnarray}
When \(x=l\) we have,
\[\left|f(l)-\sum_{n=1}^{N}\frac{(-1)^{n}}{n}\sin\left(\frac{n\pi l}{l}\right)\right|=l\]
Therefore by the definition of uniform convergence (Refer http://www.math.psu.edu/wade/M401-notes1.pdf) it is clear that the Fourier series of \(f\) is not uniformly convergent on \(\Re\).
Kind Regards,
Sudharaka.
Sudharaka said:
Hi Markov, :)
This is very likely to be intended to indicate the periodic extension: \(f(x)=f(x+2l)\) (or there is a mistake with the value at either \(+l\) or \(-l\), both end points would not normally be included in the domain for a Fourier Series).
Without the periodic extension the question of uniform convergence is moot, since the Fourier Series is periodic and so does not converge to the function outside of the interval.
CB
FAQ: Fourier series, pointwise convergence, series computation
What is a Fourier series?
A Fourier series is a mathematical representation of a periodic function as a sum of sine and cosine functions. It is named after the French mathematician Joseph Fourier and is used in many areas of mathematics and physics, particularly in the study of heat transfer and vibrations.
How is pointwise convergence defined?
Pointwise convergence is a concept in mathematical analysis where a sequence of functions converges to a particular function at every point in the domain. This means that for any given point x in the domain, the sequence of function values approaches the value of the function at that point as the sequence continues.
What is the difference between pointwise and uniform convergence?
The main difference between pointwise and uniform convergence is that in pointwise convergence, the convergence may vary at different points in the domain, while in uniform convergence, the convergence is uniform across the entire domain. In other words, in uniform convergence, the rate of convergence is the same for all points in the domain.
How are Fourier series used in series computation?
Fourier series are used in series computation to represent functions that are not easily expressed in a simpler form. By using a Fourier series, the function can be approximated by a finite number of sine and cosine terms, making it easier to manipulate and compute.
Can any function be represented by a Fourier series?
No, not every function can be represented by a Fourier series. The function must be periodic and have a finite number of discontinuities in order for it to have a Fourier series representation. Additionally, the function must also satisfy certain technical conditions for the Fourier series to converge.
