Fourier series--showing converges to pi/16
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Fourier
In summary, the Fourier series with sine and sinh terms converges to $\frac{\pi}{16}$. However, I still don't understand how to evaluate it.
Dustinsfl
2,281
When a Fourier series contains only sine and cosine terms, evaluating the series isn't too difficult.
However, I want to show a Fourier series with sine and sinh converges to \(\frac{\pi}{16}\).
T(50, 50) = \sum_{n = 1}^{\infty}
\frac{\sin\left(\frac{\pi(2n - 1)}{2}\right)
\sinh\left(\frac{\pi(2n - 1)}{2}\right)}
{(2n - 1)\sinh[(2n - 1)\pi]} = \frac{\pi}{16}
Since this series contains sinh, I am not sure how to evaluate it.
My thought: use
$\text{sinh}(x) = -i \sin(ix)$
Deveno said:
My thought: use
I think I will still have some trouble though. I end up with:
\sum_{n = 1}^{\infty}\frac{(-1)^{n+1}}{2n - 1}\frac{\sin\left[\frac{i\pi}{2}(2n-1)\right]}{\sin\left[i\pi(2n-1)\right]}
The sin function isn't really there at all, because $\sin\left(\frac{\pi(2n - 1)}{2}\right) = \sin\left(\bigl(n-\frac12\bigr)\pi\right) = (-1)^{n-1}$. Also, you can use the identity $\sinh(2x) = 2\sinh x\cosh x$, to rewrite the sum as \(\displaystyle \sum_{n = 1}^{\infty}\frac{(-1)^n}{2(2n-1)\cosh\left(\bigl(n-\frac12\bigr)\pi\right)}.\) That looks a bit less complicated than the original series, but I still don't see how to sum it. It clearly converges very fast, because the cosh term in the denominator will get very large after the first few terms. A numerical check shows that the sum of the first three terms is $0.1968518...$, which is very close to $\pi/16$. But that isn't a proof!
I would first clarify what is meant by "converges to \(\frac{\pi}{16}\)". Is this referring to the limit of the series as the number of terms approaches infinity, or to the value of the series at a specific point? Additionally, I would want to know the context and purpose of this series, as it may impact the approach to evaluating it.
That being said, evaluating a Fourier series with sinh terms may be more challenging than one with just sine and cosine terms. One approach could be to use the properties of sinh to rewrite the series in terms of exponential functions, which may make it easier to evaluate. Alternatively, numerical methods such as approximation or integration techniques could be used to estimate the value of the series.
In general, the convergence of a series depends on the behavior of its terms, so understanding the properties of the terms in this series will be crucial in determining its convergence. Overall, evaluating this Fourier series may require a combination of mathematical techniques and careful analysis to determine its convergence to \(\frac{\pi}{16}\).
FAQ: Fourier series--showing converges to pi/16
What is a Fourier series?
A Fourier series is a mathematical series that represents a periodic function as a sum of sine and cosine functions. It is used in many areas of science and engineering to analyze and approximate complex waveforms.
How does a Fourier series converge to pi/16?
A Fourier series can converge to pi/16 when the function being represented is a square wave with a period of 2π. In this case, the Fourier series will have a coefficient of 4/π for the sine function, which when squared and multiplied by π will give pi/16.
What is the significance of pi/16 in a Fourier series?
The coefficient of pi/16 in a Fourier series represents the amplitude of the sine function that is used to approximate the square wave function. It is also used to determine the energy of the signal being represented by the Fourier series.
Can a Fourier series converge to values other than pi/16?
Yes, a Fourier series can converge to a wide range of values depending on the function being represented. Some common values include 0, 1/2, 1, and 2π. The choice of which value the series converges to depends on the coefficients of the sine and cosine functions in the series.
How is the convergence of a Fourier series to pi/16 determined?
The convergence of a Fourier series to pi/16 is determined by the properties of the function being represented. In general, a Fourier series can converge if the function is periodic, continuous, and has a finite number of discontinuities within a given interval. The more terms that are included in the series, the closer the approximation will be to pi/16.
