Fourier series solution of wave equation
In summary, the conversation discusses a horizontally stretched string with significant effects of gravity, leading to a modified wave equation. The steady state solution is found to be a sum of terms involving sine functions. The process of finding this solution is outlined, including how to handle the initial conditions.
Dazed&Confused
191
Suppose a horizontally stretched string is heavy enough for the effects of gravity to be significant, so that the wave equation must be replaced by ##u_{tt} = c^2u_{xx} - g## where ##g## is the acceleration due to gravity. The boundary conditions are ##u(0,t) = u(l,t) = 0##.
Find the steady state solution ##\phi(x)##
Suppose that initially ##u(x,0) = u_{t}(x,0) = 0##. Find the solution ##u(x,t)## as a Fourier series.
The steady state differential equation is ##u_{xx} = g/c^2## which has solutions ##\frac{gx^2}{2c^2} -\frac{gxl}{2c^2} ##. Here is where I have problems if I try to find solutions to the homogeneous differential equation with the same boundary conditions and initial conditions replaced with ##-\frac{gx^2}{2c^2} +\frac{gxl}{2c^2}##. It would be a sum of ##\sin(\pi n x / l)## terms due to the boundary conditions, but multiplied by a sum of ##\sin(\pi n c t / l) ## and ## \cos ( \pi n c t / l)## terms. The book outlines a way to find the coefficients by expanding the initial conditions to the Foerier series and equating, but the example given was with the heat equation which only had one exponential term that become 1 at ##t = 0##.
Edit: writing this out has made me realize I can that the ##\sin ( \pi n c t / l)## coefficients are zero.
Are you sure it isn't the cos terms that are zero?
Related to Fourier series solution of wave equation
1. What is a Fourier series solution?
A Fourier series solution is a mathematical technique used to express a function as a sum of sines and cosines. It is often used to solve differential equations, such as the wave equation, and is based on the concept that any periodic function can be represented as a combination of simpler sine and cosine functions.
2. How does a Fourier series solution relate to the wave equation?
The wave equation is a differential equation that describes the behavior of waves in various systems, such as sound, light, and water. A Fourier series solution is used to solve the wave equation by breaking down the complex wave function into simpler sinusoidal components, making it easier to analyze and understand.
3. What are the advantages of using a Fourier series solution for the wave equation?
A Fourier series solution allows for a more efficient and accurate method of solving the wave equation compared to traditional methods. It also provides a deeper understanding of the behavior of waves and can be applied to a wide range of physical systems.
4. Are there any limitations to using a Fourier series solution for the wave equation?
While a Fourier series solution is a powerful tool for solving the wave equation, it does have some limitations. It is only applicable to linear systems, meaning that the amplitude of the wave is directly proportional to the force applied. It also assumes that the system is in a steady state, meaning that the wave behavior does not change over time.
5. How is a Fourier series solution of the wave equation calculated?
The process of obtaining a Fourier series solution involves breaking down the wave equation into its component parts, determining the appropriate coefficients for each sine and cosine term, and then combining them to form the final solution. This can be done through various mathematical techniques, such as separation of variables or the method of undetermined coefficients.
