Terocamo
- 47
With Dirac Comb is defined as follow:
$$III(t)=\sum_{n=-\infty}^\infty\delta(t-nT)$$
Fourier Transform from t domain to frequency domain can be obtained by:
$$F(f)=\int_{-\infty}^{\infty}f(t)\cdot e^{-i2\pi ft}dt$$
I wonder why directly apply the above equation does not work for the Dirac Comb:
$$F(III(t))=\sum_{n=-\infty}^\infty\int_{-\infty}^{\infty}\delta(t-nT)\cdot e^{i2\pi ft}dt$$
$$III(f)=\sum_{n=-\infty}^\infty e^{-i2\pi fnT}dt\cdots\cdots [1]$$
Where the correct way to obtain the FT of Dirac Comb is to first find the Fourier series, and then do the Fourier Transform for each term in the summation.
I copied the upper section from a open lecture slide, and I don't even understand how it goes from [2] to [3], not to mention [1] and [3] are totally not the same thing. Any hints guys?
Writing III(t) as Fourier Series:
$$III(t)=\frac{1}{T}\sum_{n=-\infty}^\infty e^{i2\pi nt/T}$$
Doing Fourier Transform:
$$III(f)=\frac{1}{T}\sum_{n=-\infty}^\infty \int_{-\infty}^{\infty} e^{i2\pi nt/T}\cdot e^{-i2\pi ft} dt\cdots\cdots [2]$$
$$III(f)=\frac{1}{T}\sum_{n=-\infty}^\infty\delta(f-\frac{n}{T})\cdots\cdots [3]$$
