Fourier Transform of Polarization
In summary, the problem involves taking the Fourier transform of a function that represents the polarization of a material, and the goal is to find the final solution for the transform. The first attempt uses the convolution property, but then the shifting property is discovered and used to simplify the solution. The final solution is expressed as F(ω') = ε0 X(ω)∫ E(τ) eiω'τ dτ, and it is shown that ∫ E(τ) eiω'τ dτ = E(ω).
David92
The problem is from an optics text, however I believe the problem to be a mathematical one.
I'm trying to take the Fourier transform of
P(t) = ε0∫ X(t-τ)E(τ) dτ which should equal
P(ω) = ε0X(ω)E(ω)
where ε0 is a constant
X is the susceptibility
E is the electric field
P(t) = ε0∫ X(t-τ)E(τ) dτ <-starting point
Fourier transforms:
P(ω) = ∫ P(t)eiωt dt
P(t) = 1/2π ∫ F(ω)e-iωt
P(ω) = ε0X(ω)E(ω) <- end point (final solution)
First off not sure if convolution is part of the answer where
P(t) = ε0∫ X(t-τ)E(τ) dτ also equals
P(t) = ε0∫ X(τ)E(t-τ) dτ
but I will start my attempt with the first equation
If I plug the P(t) time transforms into the left hand side I get
1/2π ∫ F(ω)e-iωt dω = ε0∫ X(t-τ)E(τ) dτ
now multiply by eiω'tdt and integrate over all time
1/2π ∫ F(ω)e-iωt dω ∫ eiω'tdt= ε0∫ X(t-τ)E(τ) dτ ∫ eiω'tdt
where the left hand side can be arranged to give
1/2π ∫ F(ω) dω ∫ e-i(ω-ω')tdt= ε0∫ X(t-τ)E(τ) dτ ∫ eiω'tdt
using ∫ e-i(ω-ω')tdt = 2πσ(ω-ω') <- Dirac Delta function
∫ F(ω)σ(ω-ω') dω = ε0∫ X(t-τ)E(τ) dτ ∫ eiω'tdt <-Dirac Delta function 'picks out' ω'
F(ω') = ε0∫ X(t-τ)E(τ) dτ ∫ eiω'tdt
and now I'm stuck, unless my approach is wrong to begin with.
I also know the electric field is the real part of eiωt
so the last equation could be rewritten
F(ω') = ε0∫ X(t-τ)eiωτ dτ ∫ eiω'tdt
Though I am not sure if this helps.
It can be rearranged to give
F(\omega') = \epsilon_0 \int E(\tau)\ d\tau \left( \int X(t-\tau)e^{i\omega' t} dt \right)
The integral in the parentheses is the Fourier transform of ##X(t-\tau)##. Using the shifting property of Fourier transform you should be able to find its relation with the transform of ##X(t)##. If you can get the idea of this part, the rest should be pretty straight forward.
Just wanted to mention you could have gotten to this point without all that work. Just plug in
$$P(t) = \varepsilon_0 \int X(\tau-t)E(t)\,d\tau$$ into
$$F(\omega) = \int P(t)e^{i\omega t}\,dt.$$
Thank you blue leaf for pointing me towards the shifting property of Fourier transforms, and vela you are certainly right I just didn't notice. This does save some time!
As for the shifting property I still have a few questions about it,
is the below true?
∫ X(t-τ) eiω't dt = ∫ X(u) eiω'(u+τ) du
where u = t - τ and this then equals
eiω'τ ∫ X(u) eiω'u = eiω'τ X(ω)
This turns F(ω'), from my previous post, into
Does this mean
∫ E(τ) eiω'τ dτ = E(ω) ?
Related to Fourier Transform of Polarization
What is the Fourier Transform of Polarization?
The Fourier Transform of Polarization is a mathematical technique used to analyze the polarization properties of light. It converts a signal in the time or spatial domain into the frequency domain, allowing researchers to study the frequency components of the polarization of light.
Why is the Fourier Transform of Polarization important in science?
This technique is important because it allows researchers to better understand the polarization characteristics of light and how it interacts with matter. This has applications in various fields such as optics, materials science, and biology.
How is the Fourier Transform of Polarization calculated?
The Fourier Transform of Polarization is calculated by taking the Fourier Transform of the Jones vector, which represents the polarization state of light. This involves a complex mathematical process that can be done using computer software or manually using integral equations.
What are the limitations of the Fourier Transform of Polarization?
One limitation of this technique is that it assumes the light being analyzed is monochromatic, meaning it has a single frequency. In reality, most light sources emit a range of frequencies, which can affect the accuracy of the results. Additionally, it cannot account for polarization changes that occur over time.
What are the real-world applications of the Fourier Transform of Polarization?
The Fourier Transform of Polarization has various applications in science and technology. It is used in polarization imaging, polarization microscopy, and studying the properties of materials such as liquid crystals. It also has applications in communication systems, where it is used to analyze the polarization of light in optical fibers.
