I Fourier transform of the density fluctuation
The discussion centers on the Fourier transform of density fluctuations in cosmology, specifically the equation governing the evolution of these fluctuations. The equation presented is a second-order differential equation that describes the dynamics of the density fluctuation, δ, in terms of the scale factor H and matter density Ω_m. The Fourier transform of the density fluctuation is defined, leading to a similar differential equation for δ_k, the Fourier-transformed fluctuation. The participants express confusion about the solution to this equation, suggesting that a Gaussian function may be the only viable solution. The textbook referenced is "Introduction to Cosmology" by Barbara Ryden, which provides the relevant equations and context.
happyparticle
TL;DR Summary
Computing the Fourier transform of the density fluctuation.
There is a Fourier transform that I don't really understand in my textbook.
I have the following equation:
##\ddot{\delta} + 2H\dot{\delta} -\frac{3}{2} \Omega_m H^2 \delta = 0##
Then using the Fourier transform:
##\delta_{\vec{k}} = \frac{1}{V} \int \delta(\vec{r}) e^{i \vec{k} \cdot \vec{r}} d^3 r##
Where ##\delta(\vec{r})## is the density fluctuation.
We get
##\ddot{\delta_{\vec{k}}} + 2H\dot{\delta_{\vec{k}}} -\frac{3}{2} \Omega_m H^2 \delta_{\vec{k}} = 0##
The only function that does that is a gaussian function, I guess. I don't understand the process here.
Thank you
Space news on Phys.org
PeterDonis said:
Which textbook?
Introduction to Cosmology second edition by Barbara Ryden (p.215-219)
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
