Fourier transform on a distribution
In summary: -\infty}^{\infty} \frac {x^{3n+2}}{(2n)!} e^{-2\pi i yx} dx\right) dy= i\sum_{n=0}^{\infty} \int_{-\infty}^{\infty} \hat{\varphi}(y) \hat{\delta}(3n+2-y) dy= i\sum_{n=0}^{\infty} \hat{\varphi}(3n+2)= i\hat{\varphi}(2) + i\hat{\varphi}(5) + i\hat{\varphi}(8) + ...= i\sum_{n=
jerry109
Determine the Fourier transform on the tempered distribution:
[tex]
\langle f, \varphi \rangle
[/tex]
Where [tex] f[/tex] can be given by they taylor series representation:
[tex]
f = i\sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!}
[/tex]
Fourier transform on tempered distribution is:
[tex]
F\langle f, \varphi \rangle = \langle F f, \varphi \rangle = \langle f, F \varphi \rangle
= i\int \sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!} \hat{\varphi} dx
= i\sum_{n=0}^{\infty}\int \frac {x^{3n+2}}{(2n)!} \hat{\varphi} dx
[/tex]
I'm stuck as how to resolve the infinite sum involving the Fourier transform of the test function [tex]\varphi[/tex].
Perhaps:
[tex]
i\sum_{n=0}^{\infty}\int \frac {x^{3n+2}}{(2n)!} \hat{\varphi} dx = i\sum_{n=0}^{\infty}\int \frac {x^{3n+2}}{(2n)!} \hat{\delta}(x-x_0) dx
= i\sum_{n=0}^{\infty}\int \frac {x^{3n+2}}{(2n)!} e^{2{\pi}ikx_0}dx= ie^{2{\pi}ik{x_0}}\sum_{n=0}^{\infty}\int \frac {x^{3n+2}}{(2n)!} dx
= ie^{2{\pi}ik{x_0}}\sum_{n=0}^{\infty}\frac {x^{3n+3}}{(2n)! * (3n+3)!}
[/tex]Any help would be fantastically appreciated,
Jerry109
Dear Jerry109,
Thank you for sharing your attempt at solving this problem. I can see that you are on the right track, but there are a few things that need to be clarified.
Firstly, when considering the Fourier transform on tempered distributions, it is important to remember that it is defined as an integral, not a sum. So instead of using a summation notation, we should be using an integral notation. Also, the tempered distribution f is not given by a Taylor series representation, but rather by an integral representation. So we should be using an integral representation for f as well.
With that being said, here is how I would approach this problem:
We know that the Fourier transform of a tempered distribution f is given by:
= \int f(x) \hat{\varphi}(x) dx
= \int i\sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!} \hat{\varphi}(x) dxNow, we need to use the definition of the Fourier transform for a function g(x) given by:
\hat{g}(k) = \int_{-\infty}^{\infty} g(x) e^{-2\pi i kx} dx
So, substituting g(x) = i\sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!} \hat{\varphi}(x) in the above equation, we get:
F\langle f, \varphi \rangle = \int i\sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!} \hat{\varphi}(x) dx
= \int i\sum_{n=0}^{\infty} \frac {x^{3n+2}}{(2n)!} \int_{-\infty}^{\infty} \hat{\varphi}(y) e^{-2\pi i yx} dy dx
= i\sum_{n=0}^{\infty} \int_{-\infty}^{\infty} \hat{\varphi}(y) \left(\int_{
FAQ: Fourier transform on a distribution
What is a Fourier transform on a distribution?
A Fourier transform on a distribution is a mathematical operation that converts a function from its original domain (e.g. time or space) to its corresponding representation in the frequency domain. It is commonly used in signal processing and allows for the analysis of a signal's frequency components.
How is a Fourier transform on a distribution different from a regular Fourier transform?
A regular Fourier transform can only be applied to functions that are square integrable, while a Fourier transform on a distribution can be applied to a wider class of functions known as distributions or generalized functions. This allows for the analysis of signals that are not necessarily continuous or differentiable.
What is the purpose of using a Fourier transform on a distribution?
The main purpose of using a Fourier transform on a distribution is to analyze the frequency components of a signal. It allows for the identification of dominant frequencies and the filtering of unwanted frequencies. It is also used in solving differential equations and in the study of partial differential equations.
Can a Fourier transform on a distribution be inverted?
Yes, a Fourier transform on a distribution can be inverted using the inverse Fourier transform on a distribution. This allows for the reconstruction of the original signal in the time or space domain from its representation in the frequency domain.
Is there a relationship between the Fourier transform on a distribution and the Laplace transform?
Yes, there is a relationship between the Fourier transform on a distribution and the Laplace transform. The Fourier transform on a distribution can be seen as a special case of the Laplace transform where the imaginary part of the Laplace transform variable is equal to zero. This means that the Fourier transform on a distribution is a special case of the Laplace transform that is only applied to functions defined on the real line.
