Fourier Transform to find sidebands with 2 different frequencies
In summary, the Fourier transform of the given function f(t)=A[1+B \cos(\omega_1 t+ \phi)] \cos(\omega_2 t+ \phi) can be expressed as a linear combination of delta functions in terms of the frequencies \omega_1 and \omega_2. By using the cosine addition and product-to-sum identities, the function can be rewritten in terms of these frequencies and their associated phases. This allows for the transformation to be computed in the distributional sense and plotted to observe the interactions between the frequencies.
bugatti79
794
Hi Folks,
I need to evaluate the following function [tex]f(t)=A[1+B \cos(\omega_1 t+ \phi)] \cos(\omega_2 t+ \phi)[/tex] to find [tex]f(\omega)[/tex] using the Fourier transform.
Ie, the Fourier transform I use is
[tex]f(\omega)=\displaystyle \frac{1}{\sqrt {2 \pi}} \int^{\infty}_{-\infty} f(t) (\cos \omega t+ j \sin \omega t)dt[/tex]
giving
[tex]f(\omega)=\displaystyle \frac{1}{\sqrt {2 \pi}} \int^{\infty}_{-\infty} A[1+B \cos(\omega_1 t+ \phi)] \cos(\omega_2 t+ \phi) (\cos \omega t+ j \sin \omega t)dt[/tex]
We are integrating wrt t but we have 3 different frequencies. Not sure how to handle this...
Basically i want to plot the frequency response as a function of [tex]\omega_1[/tex] and [tex]\omega_2[/tex]...any ideas?
bugatti79 said:
Hi Folks,
giving
Hi bugatti79,
Your integral diverges unless $A = 0$.
bugatti79 said:
Hi Folks,
giving
From the formal point of view the integral You have written diverges ... unless you do not use the so called 'singularity functions' based on Dirac delta ... see the way ...
Examples of the Fourier Transform
Kind regards
$\chi$ $\sigma$
Hi Guys, thanks for the reply.
1) A and B are just constants, so can we at least pull A outside of the integral? Would this solve the divergence issue?
2) I am not sure if this divergence is related to my original query regarding 3 different frequencies [tex]\omega[/tex] [tex]\omega_1[/tex] [tex]\omega_2[/tex] in the eqn?
Euge said:
Hi bugatti79,
Kind regards
$\chi$ $\sigma$
The answers to 1) and 2) are no and yes, respectively. For 2), the frequencies do not change the divergence of the integral in the usual sense. If you're viewing the Fourier transform distributionally then you may be able to see the interaction of $\omega$ with the two other frequencies frequencies $\omega_1$ and $\omega_2$.
Hi Euge,
What if we changed the limits of infinity and make it a proper Integral by defining some definite limits?
Does this allow us to have [tex]A \ne 0[/tex] for successful evaluation?
bugatti79 said:
Hi Euge,
You wouldn't need to do that if $f(t)$ is multiplied by a smooth cut-off function. Then the corresponding Fourier transform integral can be computed over a finite interval, regardless the value of $A$.
What would be a cutoff function that i could use?
At the moment you can't use them, because you haven't made sense of this Fourier transform -- is the transform a tempered distribution, or is it a usual integral?
Not sure I understand your question.
I already have a plot of f(t) against time. I want to convert it to f(w) to see how [tex]\omega_1[/tex] and [tex]\omega_2[/tex] interact with each other, ie potential sideband frequencies about the main frequency.
THe f(t) function is supposedly is a modulated waveform with the unaffected fundamental along with an upper and lower sideband. (This can be seen when f(t) is expanded out)
Ok, I see that you're viewing the transform in the distributional sense. In that case, we express the result in terms of delta functions. First express $f(t)$ as a linear combination of cosine waveforms by using the product-to-sum identity
\(\displaystyle \cos(x)\cos(y) = \frac{1}{2}(\cos(x + y) + \cos(x - y)).\)
You should get
\(\displaystyle f(t) = A\cos(\omega_2 t + \phi) + \frac{AB}{2}\cos[(\omega_1 + \omega_2)t + 2\phi] + \frac{AB}{2}\cos[(\omega_1 - \omega_2)t].\)
Next, using the cosine addition formula
\(\displaystyle \cos(x + y) = \cos(x)\cos(y) - \sin(x)\sin(y),\)
we "separate" the phases from the frequencies in $f(t)$, resulting in
\(\displaystyle (1) \quad f(t) = A\cos(\omega_2t)\cos(\phi) - A\sin(\omega_2 t)\sin(\phi) + \frac{AB}{2}\cos[(\omega_1 + \omega_2)t]\cos(2\phi) - \frac{AB}{2}\sin[(\omega_1 + \omega_2)t]\sin(2\phi) + \frac{AB}{2}\cos[(\omega_1 - \omega_2)t].\)
For convenience I'll let $\mathcal{F}(g(t))(\omega)$ denote the Fourier transform (your version) of a function $g(t)$. Then for all frequencies $\omega_0$,
\(\displaystyle (2) \quad \mathcal{F}(\cos(\omega_0 t))(\omega) = \sqrt{\frac{\pi}{2}}[\delta(\omega_0 + \omega) + \delta(\omega_0 - \omega)]\)
and
\(\displaystyle (3) \quad \mathcal{F}(\sin(\omega_0 t))(\omega) = -j\sqrt{\frac{\pi}{2}}[\delta(\omega_0 + \omega) - \delta(\omega_0 - \omega)].\)
Use $(1)$, $(2)$, $(3)$, and linearity of the Fourier transform to show that
\(\displaystyle \mathcal{F}(f(t))(\omega) = A\sqrt{\frac{\pi}{2}}e^{j\phi}\delta(\omega_2 + \omega) + A\sqrt{\frac{\pi}{2}}e^{-j\phi}\delta(\omega_2 - \omega) + \frac{AB}{2}\sqrt{\frac{\pi}{2}}e^{2j\phi}\delta(\omega_1 + \omega_2 + \omega) + \frac{AB}{2}\sqrt{\frac{\pi}{2}}e^{-2j\phi}\delta(\omega_1 + \omega_2 - \omega) + \frac{AB}{2}\sqrt{\frac{\pi}{2}}\delta(\omega_1 - \omega_2 + \omega) + \frac{AB}{2}\sqrt{\frac{\pi}{2}}\delta(\omega_1 - \omega_2 - \omega).\)
Hi Euge,
Thanks for you reply. Just working through what you have done.
1) I am not familiar with your notation [tex]\mathcal{F}(\cos(\omega_0 t))(\omega)[/tex] where you have added on the omega term...?
I know that [tex]\mathcal{F}(f(t))= \hat f(\omega)[/tex]
I see you have added the delta function but I am not sure how you arrived at those final terms (2) and (3)?.
\(\displaystyle (3) \quad \mathcal{F}(\sin(\omega_0 t))(\omega) = -j\sqrt{\frac{\pi}{2}}[\delta(\omega_0 + \omega) - \delta(\omega_0 - \omega)].\)<br>
bugatti79 said:
Hi Euge,
Your version of the Fourier transform of a function $f(t)$ is
\(\displaystyle \frac{1}{\sqrt{2\pi}} \int_{-\infty}^\infty f(t)e^{j\omega t}\, dt\)
I let $\mathcal{F}(f(t))(\omega)$ represent this integral (since $\omega$ varies I put $\omega$ in the notation to be definite). Given a frequency $\omega_0$,
\(\displaystyle \cos(\omega_0 t) = \frac{e^{j\omega_0 t} + e^{-j\omega_0 t}}{2}.\)
Therefore
\(\displaystyle \mathcal{F}(\cos(\omega_0 t))(\omega)\)
\(\displaystyle = \frac{1}{\sqrt{2\pi}}\int_{-\infty}^\infty \cos(\omega_0 t)e^{j\omega t} \, dt\)
\(\displaystyle = \frac{1}{2\sqrt{2\pi}}\int_{-\infty}^\infty (e^{j\omega_0 t} + e^{-j\omega_0 t})e^{j\omega t}\, dt\)
\(\displaystyle = \sqrt{\frac{\pi}{2}}\cdot \frac{1}{2\pi}\int_{-\infty}^\infty [e^{j(\omega_0 + \omega)t} + e^{j(\omega - \omega_0)t}]\, dt = \sqrt{\frac{\pi}{2}}[\delta(\omega + \omega_0) + \delta(\omega - \omega_0)].\)
Since $\delta$ is even, $\delta(\omega - \omega_0) = \delta(\omega_0 - \omega)$. So the result follows. Compute $\mathcal{F}(\sin(\omega_0 t))(\omega)$ using the same method.
1) I presume you used the linearity of [tex]\mathcal{F}(a*f+b*g)=a \mathcal{F}(f)+b \mathcal{F}(g)[/tex]?
2) How did you justify or transform the phases into a complex number? Can you show? I understand that they don't effect the amplitude which is fine for me.
3) Not sure how I can plot this for viewing. I intend to use an interactive math package to show how the frequencies vary etc by assigning slider bars for [tex]\omega_1[/tex], [tex]\omega_2[/tex], [tex]A[/tex] and [tex]B[/tex] while having [tex]\omega[/tex] as the abscissa value. Not sure how to handle the [tex]\delta[/tex] or the complex terms?
You're right about the linearity. I didn't transform the phases into complex numbers. I used Euler's identity
\(\displaystyle e^{j\theta} = \cos(\theta) + j\sin(\theta)\)
to get those complex exponentials.
To understand the overall approach:
1)what is the reason we use the dirac function for? Is it because a single sine wave acts as a single impulse where all the power is concentrated?
2)Ie, can the Dirac approach be avoided if we changed the limits of the integral to upper and lower real values?
3)Is this Dirac approach a separate issue from the "cut-off point" that was mentioned in an earlier approach.
Thanks
No, the Dirac functions come out directly from calculation of the Fourier transfrom. The sine and cosine waves are linear combinations of complex exponentials, and complex exponentials translate to (constant multiples of) deltas in Fourier space.
If both limits are finite, the integral will exist in the Riemann sense, so there will be no deltas in the calculation. You'll just have sines in your final answer.
There was no "Dirac approach" but Dirac delta functions came out from direct calculation. It's a separate from cut-off functions.
bugatti79 said:
Hi Folks,
giving
Maybe I am completely misunderstanding the problem, but it seems to me that it would be easier to use some elementary trigonometry, rather than the Fourier transform, to analyse this waveform, because of of the divergence problems noted by Euge and chisigma. In fact, $$\begin{aligned} f(t)\ &=A\bigl(1+B \cos(\omega_1 t+ \phi)\bigr) \cos(\omega_2 t+ \phi) \\ &= A\cos(\omega_2 t+ \phi) + AB\cos(\omega_1 t+ \phi) \cos(\omega_2 t+ \phi) \\ &= A\cos(\omega_2 t+ \phi) + \tfrac12AB\bigl( \cos[(\omega_1 - \omega_2)t] - \cos[(\omega_1 + \omega_2)t + 2\phi]\bigr).\end{aligned}$$ That is a combination of three sinusoidal waveforms, one with frequency $\omega_2$, one with frequency $\omega_1 - \omega_2$ and phase difference $-\phi$, and one with frequency $\omega_1 + \omega_2$ and phase difference $\pi + \phi$, the amplitudes being respectively $A$, $\frac12AB$ and $\frac12AB$. That pretty much agrees with the Fourier transform description obtained by Euge in comment #11.
FAQ: Fourier Transform to find sidebands with 2 different frequencies
What is a Fourier Transform?
A Fourier Transform is a mathematical tool used to analyze the frequency components of a signal or function. It converts a function of time into a function of frequency, allowing for the identification of different frequency components within the signal.
How does a Fourier Transform help find sidebands with 2 different frequencies?
A Fourier Transform can be used to identify the presence of sidebands, which are additional frequencies that appear alongside the main frequency in a signal. By analyzing the frequency spectrum of a signal using a Fourier Transform, one can identify the frequencies of the sidebands and determine their relationship to the main frequency.
Can a Fourier Transform be used to find sidebands with any type of signal?
Yes, a Fourier Transform can be applied to any type of signal, as long as the signal is continuous and has a finite length. This includes signals with 2 different frequencies, as the Fourier Transform is able to separate and identify multiple frequency components within a signal.
Are there any limitations to using a Fourier Transform to find sidebands with 2 different frequencies?
One potential limitation is the requirement for a continuous and finite signal. Additionally, the accuracy of the results may be affected by factors such as sampling rate and noise in the signal. It is important to carefully choose the appropriate parameters and techniques when using a Fourier Transform for sideband analysis.
How is a Fourier Transform different from a Fourier Series?
A Fourier Transform is used for continuous signals, while a Fourier Series is used for periodic signals. Additionally, a Fourier Transform produces a continuous frequency spectrum, while a Fourier Series produces a discrete frequency spectrum. However, both techniques use the same underlying principles of frequency analysis and can be used to find sidebands with 2 different frequencies.
