Fractal geometry in crumpled paper
In summary, the conversation discusses an experiment where the mass of crumpled paper balls is proportional to their mean external diameter raised to the power of 2.5. This suggests that the balls are fractals, similar to a Koch snowflake which is self-similar and has an infinite perimeter. The conversation then explores the fractal nature of the ridges in a crumpled paper ball and provides references to further reading on the topic.
rafael_01
I've made an experiment similar to the one found here:
http://classes.yale.edu/fractals/fracanddim/boxdim/PowerLaw/CrumpledPaper.html
The result was: the mass of crumpled paper balls is proportional to [tex]D^n[/tex], being D their mean external diameter, and n ≈ 2,5.
As [tex]n[/tex] is not an integer, the balls are fractals. But I cannot see, exactely, what caracterizes them as fractals.
If you look at a Koch snowflake, for example, it is easy to see that it is self-similar, and that it is not a regular euclidean object, as it's perimeter is infinite.
How can a Koch snowflake and a crumpled paper ball be similar kinds of object?
You are looking at a very interesting and surprisingly complex physical system. (Fun, too!).
Open the ball and look at the pattern of ridges. The ridge lengths are fractal in several senses: first, as you look at the ridges from balls of decreasing diameter, you'll see that the ridge patterns look similar even though they are of different overall lengths (like looking at trees of different sizes, but noticing that the pattern of branches and twigs is scale-free). Second, the ridges in a single sheet also look like a branching tree with similar pattern behavior at the largest and smallest scales.
Here is some related student work with a list of references to the professional literature on crumpled paper:
http://www.maa.org/mathland/mathtrek_05_26_03.html"
Related to Fractal geometry in crumpled paper
What is fractal geometry?
Fractal geometry is a mathematical concept that describes the repeating patterns found in nature and the world around us. It is a way to measure and understand complex, irregular shapes and structures.
What is crumpled paper?
Crumpled paper is a sheet of paper that has been crumpled or folded into a disordered, irregular shape. It is often used as a metaphor for chaotic or unpredictable systems.
How does fractal geometry apply to crumpled paper?
Fractal geometry can be used to describe the complex, self-similar patterns that form when crumpled paper is unfolded. These patterns can be seen at both the macroscopic and microscopic level, and can provide insight into the behavior and properties of the paper.
What real-world applications use fractal geometry in crumpled paper?
Fractal geometry in crumpled paper has been used in various fields such as material science, computer graphics, and image processing. It has also been studied in relation to understanding the folding and unfolding of DNA molecules.
What are the limitations of using fractal geometry to study crumpled paper?
While fractal geometry can provide valuable insights into the properties and behavior of crumpled paper, it is not a perfect model and has its limitations. For example, it does not take into account the structural properties of the paper, such as its thickness and stiffness, which can affect the final patterns formed.
  • Beyond the Standard Models
  • General Math
  • Biology and Medical
11K
  • STEM Academic Advising
  • Other Physics Topics
9K
