Fraction of a distance (1D Kinematics)
In summary, a cross country team race is about to begin and team Beta plans to use their knowledge of one-dimensional kinematics from their first-year physics course. Each team consists of two people and one horse, with one member riding the horse while the other walks. The rider will leave the walker behind and can tether the horse and continue on foot. This continues until the entire team crosses the finish line. In order to minimize the total race time, the fraction of the distance that Ann should ride is approximately 0.464. The equation used to solve for this fraction was based on the total time each member takes to finish and minimizing the difference between them.
chatnay
A cross country team race is about to begin and team Beta decides to use their one-dimensional kinematics knowledge that they learned from their first year physics course. Each team consists of two people and one horse. The clock is started when the team crosses the starting line with one of the members (let's call her "Ann") riding the horse and the other (we'll call him "Bob") on foot.
The rider will of course leave the walker behind. Ann may tether the horse and continue on foot. When Bob reaches the horse, he mounts it, rides past Ann and tethers the horse further on and continues walking. When Ann reaches the horse, she mounts it and rides past Bob. This alternation of riding/walking continues until the entire team (Ann, Bob and the horse) cross the finish line.
Suppose that Ann walks at a rate of v and Bob (owing to the fact that he has longer legs) walks at a rate of 3.4v. In addition, while Ann is riding the horse, she moves at a rate of 11.6v and Bob (since he is slightly overweight) rides at a rate of 8.1v. (Note also that Bob moves faster on the horse than on foot). Find the fraction of the total race distance that Ann should ride in order to minimize the total race time. Assume that the race is sufficiently long that Ann and Bob can alternate on the horse many times.
s = u +at
I can't resolve this exercise because it seems that my answer is wrong (0.464).
I've set up the following the equations in order to equal them and find the fraction of the distance that Anna rides:
3.4vx + (1-x)8.1v = (1-x)v + 11.6vx
Then I solved for x and i got as a result x = 71/153, which is ≈ 0.464. I've plugged in the value to the equation in order to see if the distance was the same, and it was. Possibly I have committed a mistake in setting up the equation. Is the procedure that I've done appropriate?
Thank you very much PF.
Can you explain what your equation represents? You seem to be summing the distance * velocity pairs (walking, riding) for each participant, then equating the sums. Why is that? What do the d*v's represent?
I would suggest looking at the total time each takes to finish and then minimizing the difference between them.
Assume a total distance of 1 unit. Then Ann will ride for distance f and walk for distance 1-f. Bob does the opposite. You can also make v the unit velocity, so v = 1. Fewer unnecessary variables to lug around that way :wink:
Related to Fraction of a distance (1D Kinematics)
1. What is a fraction of a distance?
A fraction of a distance is a portion or part of a total distance. It is represented as a ratio of two numbers, where the numerator is the distance being considered and the denominator is the total distance.
2. How is fraction of a distance used in 1D kinematics?
In 1D kinematics, fraction of a distance is used to describe the position of an object in terms of a fraction of a total distance. It is often used in equations and calculations to determine the displacement or velocity of an object.
3. What is the difference between fraction of a distance and percentage of a distance?
The main difference between fraction of a distance and percentage of a distance is the way they are expressed. Fraction of a distance is expressed as a ratio, while percentage of a distance is expressed as a percentage (out of 100). Additionally, fraction of a distance is a more precise measure, while percentage of a distance is a more general measure.
4. Can fraction of a distance be negative?
Yes, fraction of a distance can be negative. A negative fraction of a distance indicates that the object is located in the opposite direction of the total distance being considered. This can be seen in situations where an object is moving backwards or in the negative direction.
5. How can fraction of a distance be used to calculate average speed?
To calculate average speed using fraction of a distance, you would divide the total distance traveled by the time it took to travel that distance. This would give you the average distance traveled per unit of time, which is the definition of speed. Fraction of a distance can also be used to calculate average velocity, by taking into account the direction of motion.
  • Cosmology
