Fractional Distillation Calculations
In summary: V=nRT/P and plug in the values to calculate the volume of the condensed vapor.In summary, to determine the number of moles of 4-bromotoluene that will remain vaporized and cannot be collected, we use the ideal gas law equation PV=nRT. We calculate the total pressure of the system using the total pressure formula and the volume of the system by adding the volume inside the column and the volume of the round bottom flask. Then, we plug in the values to solve for n. To determine the volume of the condensed vapor, we use the ideal gas law again, using the number of moles we calculated earlier and the temperature of the vapor.
boredbluejay
4-bromotoluene was synthesized and purified by distillation. There are 5ml of the crude product. A fractional distillation is being carried out in a 100ml round bottom flask. Assume that the volume of the column is 16ml. Determine the number of moles of 4-bromotoluene that will remain vaporized and cannot be collected. What will the volume of the condensed vapor be?
PV=nRT
Total Pressure=χaPa+χbPb, where χis the mole fraction of a or b and P is the normal pressure of a or b.
bp of 4-bromotoluene is 184C
density=1.39g/ml
MW=171.13g/mol
I know that we are trying to find n using PV=nRT. However, I'm not sure which values we plug in. Do I use V=16ml for the volume inside the column? Do I use the boiling point for T? Also, how do you find the pressure of the system? If P= the total pressure of the mixture, how would you find it if you don't know how much of the compound is made up of 4-bromotoluene and what the pressure of 4-bromotoluene is?
Thank you very much!
To determine the number of moles of 4-bromotoluene that will remain vaporized and cannot be collected, we need to use the ideal gas law equation PV=nRT. In this equation, P represents the pressure of the system, V represents the volume of the system, n represents the number of moles, R is the gas constant, and T is the temperature in Kelvin.
First, let's determine the pressure of the system. We know that the total pressure of a mixture is equal to the sum of the partial pressures of each component. In this case, the mixture is composed of 4-bromotoluene and other components. We can assume that the pressure of the other components is negligible compared to the pressure of 4-bromotoluene. Therefore, we can use the total pressure formula: Total Pressure = χaPa + χbPb, where χ is the mole fraction of the component and P is the normal pressure of that component. In this case, we can assume that χa = 1, since we are only dealing with 4-bromotoluene. We can also assume that Pb is negligible. Therefore, the total pressure of the system is equal to the normal pressure of 4-bromotoluene.
Next, we need to determine the volume of the system. The total volume of the system is equal to the volume inside the column (16ml) plus the volume of the round bottom flask (100ml). Therefore, the total volume is 116ml.
Now, we can plug in the values into the ideal gas law equation: PV=nRT. We know that R is a constant, so we can solve for n by rearranging the equation to n=PV/RT. We can use the boiling point of 4-bromotoluene (184C or 457K) for T. We also know that the density of 4-bromotoluene is 1.39g/ml and the molecular weight is 171.13g/mol. Therefore, we can calculate the number of moles of 4-bromotoluene that will remain vaporized and cannot be collected.
To determine the volume of the condensed vapor, we need to use the ideal gas law again. This time, we can use the number of moles we calculated earlier (n) and the temperature of the vapor (457K). We can rearr
Related to Fractional Distillation Calculations
1. What is fractional distillation and why is it used?
Fractional distillation is a process used to separate a mixture of two or more liquids with different boiling points. It is used to purify and extract specific components from a solution.
2. How is fractional distillation different from simple distillation?
The main difference between fractional distillation and simple distillation is the use of a fractionating column. In fractional distillation, the vapor travels through the column, allowing for multiple distillations to occur, resulting in a more precise separation of the components.
3. What factors affect the efficiency of fractional distillation?
The efficiency of fractional distillation is affected by the difference in boiling points between the components, the size and design of the fractionating column, and the rate at which the mixture is heated.
4. How do you calculate the number of theoretical plates needed for fractional distillation?
The number of theoretical plates needed for fractional distillation can be calculated using the equation: N = (log P)/(log (1+HETP(L/V))), where N is the number of plates, P is the desired purity, HETP is the height equivalent to a theoretical plate, L is the length of the column, and V is the vapor velocity.
5. What are some common applications of fractional distillation?
Fractional distillation is commonly used in industries such as oil and gas, pharmaceuticals, and food and beverage to purify and extract specific components from mixtures. It is also used in laboratories for research and analysis purposes.
