Fractional Errors: When to Use Raw vs. Fractional Values?
In summary: If d is the "diameter" of the interval within which the true value will lie then d=2.If one is trying to compute the diameter of the interval for the quotient, one should use as input the diameter of the intervals for the numerator and denominator. Try to avoid confusion. Use only one way of expressing error at a time.
aspodkfpo
148
Why do fractional errors have a different error value from subbing in the raw values?
e.g. 10 +- 1 divided by 10 +- 1
fractional error yields 20%
11/9 - 9/11 yields 40/99
In cases like these do we use the original values and attempt to find the maximum error distance or use fractional errors?
Are you comparing fairly?
Fractional error is ±20%, so a range of 40%. Not much different from 40/99.
But the true difference is 40/99 right? It's not fair, but I'm just trying to resolve my qualms about which gets a more accurate uncertainty.
Sure, but very few will care about a 1% error in what is already an error percentage.
Likes Vanadium 50 and aspodkfpo
Suppose you have measured ##P\pm \delta##. One usually writes the fractional uncertainty as the difference between the two extreme fractional discrepancies from the value ##P##, $$\frac{\Delta P}{P}=\frac{P+\delta}{P}-\frac{P-\delta}{P}=\frac{2\delta}{P}.$$You write it as $$\frac{\Delta P}{P}=\frac{P+\delta/2}{P-\delta/2}-\frac{P-\delta/2}{P+\delta/2}=\frac{(P+\delta/2)^2-(P-\delta/2)^2}{P^2-\delta^2/4}=\frac{2P\delta}{P^2-\delta^2/4}=\frac{2\delta}{P[1-\delta^2/(4P^2)]}$$This last expression is exactly equivalent to your expression. We expect ##\delta## to be at least one order of magnitude smaller than ##P## in which case ##\delta^2/(4P^2) <<1## which means that we can ignore it in the denominator. Therefore, your way of writing the fractional difference matches to a good approximation the more common way.
Also, think about your statement
aspodkfpo said:
##\dots~##but I'm just trying to resolve my qualms about which gets a more accurate uncertainty.
What is an "accurate uncertainty"? If ##P## has a continuous spectrum of values, there is no clear boundary separating the values that could be assigned to it from the values that definitely cannot be assigned to it.
Wait how is 10+/-1 with 11/9 = (P+d/2)/(P-d/2). Why not P+d/P-d
Because that overestimates the uncertainty by a factor of 2. Do the algebra and you will see. I really don't see why you do the fractional uncertainty the way you do. The logic for the usual way is intuitive and the algebra is simple:
Step 1. Subtract the lowest value from the highest value to get a measure of the difference ##\Delta p## between the two extreme values.
##\Delta P=(P+\delta)-(P-\delta)=2\delta.##
Sep 2. Express this difference as a fraction of the measured value to get the fractional difference.
##f=\dfrac{2\delta}{P}.##
Step 3 (optional). Multiply by 100 and tack on a percent sign to write it as a percentage.
##f_{\%}=\dfrac{2\delta}{P}\times 100\%.##
Still don't see why you were writing p+d/2 / p-d/2 when it is 11/9 for 10+- 1 (where I assume 1 is d). Largest possible value would be p+d/p-d, would it not?
Likes aspodkfpo
Related to Fractional Errors: When to Use Raw vs. Fractional Values?
1. What are fractional errors and when should I use raw vs. fractional values?
Fractional errors refer to the uncertainty or margin of error associated with a measurement or calculation. Raw values are the actual measured or calculated values, while fractional values are the ratio of the uncertainty to the raw value. Fractional errors should be used when comparing measurements or performing calculations to ensure accuracy and account for any potential errors.
2. How do I calculate fractional errors?
Fractional errors can be calculated by dividing the uncertainty by the raw value and multiplying by 100 to get a percentage. For example, if the uncertainty is 0.5 and the raw value is 10, the fractional error would be (0.5/10) * 100 = 5%.
3. Can fractional errors be negative?
Yes, fractional errors can be negative. This occurs when the uncertainty is larger than the raw value, resulting in a negative ratio. It is important to pay attention to the sign of the fractional error when interpreting the results.
4. When is it appropriate to use raw values instead of fractional errors?
Raw values can be used when the uncertainty is negligible or when comparing values that have similar uncertainties. In these cases, using fractional errors may not provide any additional meaningful information.
5. How can fractional errors impact my results?
Fractional errors can impact the accuracy and precision of your results. If the uncertainty is large, it can significantly affect the final value and potentially lead to incorrect conclusions. It is important to consider fractional errors when interpreting and reporting results to ensure accuracy and reliability.
