MHB Fractional Logarithmic Integral 02
The integral $$\int^1_0 \frac{\log (1+x)}{1+x^2} dx$$ is evaluated using results from previous work on fractional logarithmic integrals. A related integral, $$\int^{1}_0 \frac{2\log(1+x)}{1+x^2}\, dx$$, is shown to be numerically equivalent to $$\frac{\pi}{4}\log(2)$$. The discussion references the dilogarithm function, specifically the use of $$\text{Li}_2$$ in the evaluations. The numerical equivalence of the original integral is established as $$\frac{\pi}{8}\log(2)$$. A detailed proof for these results will be provided later.
alyafey22
MHB
$$\int^1_0 \frac{\log (1+x)}{1+x^2} dx $$
$\log $ is the natural logarithm .
Mathematics news on Phys.org
Here is a hint
Try series expansion and harmonic sums
Using a result that I proved http://www.mathhelpboards.com/f10/generalized-fractional-logarithm-integral-5467/#post25055
$$\int^t_0 \frac{\log(1+ax)}{1+x}\, dx = - \text{Li}_2 \left( \frac{t}{t+1} \right) +\text{Li}_2 \left(\frac{t-ta}{t+1}\right)-\text{Li}_2(-at)$$
$$\int^{1}_0 \frac{2\log(1+x)}{1+x^2}\, dx = i \text{Li}_2 \left( \frac{1+i}{2} \right)-i \text{Li}_2 \left( \frac{1-i}{2} \right) -i\text{Li}_2 \left(i \right)+i\text{Li}_2 \left(-i \right)$$
Which is numerically equivalent to
$$\int^{1}_0 \frac{2\log(1+x)}{1+x^2}\, dx= \frac{\pi}{4}\log(2)$$
$$\int^{1}_0 \frac{\log(1+x)}{1+x^2}\, dx= \frac{\pi}{8}\log(2)$$
The proof of numerical equivalence is quite long , post it later .
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
