Fractions as Exponents: 16 3/2
In summary, fractions as exponents are a mathematical expression where a fraction is used as the exponent. The expression "16 3/2" can be read as "16 to the power of three halves" or "the cube root of 16". The value of "16 3/2" can be calculated by converting the fraction exponent to a decimal and taking the root of the base. Using fractions as exponents allows for the calculation of roots, which is useful in mathematical and scientific applications. Fractions can be used as exponents for any positive number, but the resulting value may not always be a real number.
CSmith1
39
=16 1/2
=(2 square root)^3
=(2(4x4)^3
=(2 square root 4)^3
Mathematics news on Phys.org
CSmith said:
1.) 16 3/2
=16 1/2
=(2 square root)^3
=(2(4x4)^3
Here's a quicker way to check your answer. Go to Wolfram Alpha and type in your problem. It will simplify it for you and you can see if your answer matches.
You need to be careful though when entering the problem. For example, your problem should be written there as 16^[3/2]. The ^ symbol means exponent. If there's a fraction, put the fraction inside [] brackets.
FAQ: Fractions as Exponents: 16 3/2
What is the meaning of "Fractions as Exponents: 16 3/2"?
Fractions as exponents refer to a mathematical expression in which a fraction is used as the exponent. In this case, 16 is the base and 3/2 is the exponent.
How do you read "16 3/2" in words?
"16 3/2" can be read as "16 to the power of three halves" or as "the cube root of 16".
What is the value of "16 3/2"?
The value of "16 3/2" can be calculated by first converting the fraction exponent to a decimal. In this case, 3/2 is equivalent to 1.5. Then, the expression becomes 16^1.5 which is approximately equal to 31.749.
What is the significance of using fractions as exponents?
Using fractions as exponents allows for the calculation of roots, such as square roots and cube roots, which cannot be easily represented using whole number exponents. This is particularly useful in mathematical and scientific applications.
Can fractions be used as exponents for any number?
Yes, fractions can be used as exponents for any positive number. However, the resulting value may not always be a real number and may require the use of complex numbers.
