MHB Fractions/brackets/parentheses and powers.
  • Thread starter Thread starter Jackie In Italy
The discussion revolves around helping a parent understand a complex math exercise involving fractions, brackets, parentheses, and powers for their daughter's homework. The exercise requires careful attention to the order of operations, emphasizing the need to simplify expressions inside parentheses first, followed by exponents, then multiplication and division, and finally addition and subtraction. A detailed step-by-step solution is provided, illustrating how to simplify the expression correctly. The final answer to the exercise is determined to be 1. This exchange highlights the importance of understanding mathematical principles to tackle similar problems effectively.
Jackie In Italy
My daughter has some maths homework for the Christmas holidays and with a test when she returns next week but I really don't understand how to do this kind of maths and she doesn't understand it either. She has a page of exercises to do but if someone could please help me with one by explaining how to do it, I would be most grateful.
Here is one of the exercises:
(- 1/2 - 1/3)^2 . (2/5 -2)^2 +[(7/9 - 2/3) : (1/2 - 9/22) ] - 5/6 (2+ 2/5)
Sorry I couldn't type the fractions on my computer any better than above. ^2 is to the power of 2 as I couldn't put a small 2 high up.
The dot . is actually in the middle not at the baseline in the exercise.
Mathematics news on Phys.org
Re: Help needed with fractions/brackets/parentheses and powers.
Hi Jackie from Italy! Welcome to MHB!
For starters, do you mean to simplify:
$\left(-\frac{1}{2}-\frac{1}{3}\right)^2 \cdot \left(\frac{2}{5}-2\right)^2 +\frac{\frac{7}{9}-\frac{2}{3}}{\frac{1}{2}-\frac{9}{22}}- \frac{5}{6\left(2+\frac{2}{5}\right)}$
or
$\left(-\frac{1}{2}-\frac{1}{3}\right)^2 \cdot \left(\frac{2}{5}-2\right)^2 +\frac{\frac{7}{9}-\frac{2}{3}}{\frac{1}{2}-\frac{9}{22}}- \frac{5\left(2+\frac{2}{5}\right)}{6}$
P.S. You can quote my reply to see how to formulate the mathematics expressions in latex. :D
or
Hi,
Thanks for your reply.
I am not sure as it is just written as you wrote except the ending
- - - Updated - - -
Hi,
$\left(-\frac{1}{2}-\frac{1}{3}\right)^2 \cdot \left(\frac{2}{5}-2\right)^2 +\frac{\frac{7}{9}-\frac{2}{3}}{\frac{1}{2}-\frac{9}{22}}-\frac{5}{6} (2+\frac{2}{5} )$
- - - Updated - - -
ps. thanks for your help with the latex!
In this case, what you've to exercise cautious with is all about the order of operations. It's a standard that defines the order in which you should simplify the given expression with a combination of different operations.
First, we should always simplify the inside of parentheses before dealing with the exponent of the set of parentheses.
Second, we simplify the exponent of a set of parentheses before we multiply, divide, add, or subtract it.
Next, we simplify multiplication and division in the order that they appear from left to right.
Last, we simplify addition and subtraction in the order that they appear from left to right.
$=\color{red}\left(-\dfrac{1}{2}-\dfrac{1}{3}\right)^2 \cdot \left(\dfrac{2}{5}-2\right)^2 \color{black}+\dfrac{\dfrac{7}{9}-\dfrac{2}{3}}{\dfrac{1}{2}-\dfrac{9}{22}}-\dfrac{5}{6} \color{red}(2+\dfrac{2}{5} )$
$=\color{red}\left(-\dfrac{5}{6}\right)^2 \cdot \left(-\dfrac{8}{5}\right)^2 \color{black}+\dfrac{\dfrac{7}{9}-\dfrac{2}{3}}{\dfrac{1}{2}-\dfrac{9}{22}}-\dfrac{5}{6} \color{red}(\dfrac{12}{5} )$
$=\color{red}\left(\dfrac{5}{6}\right)\left(\dfrac{5}{6}\right) \cdot \left(\dfrac{8}{5}\right)\left(\dfrac{8}{5}\right) \color{black}+\dfrac{\dfrac{7}{9}-\dfrac{2}{3}}{\dfrac{1}{2}-\dfrac{9}{22}}-\dfrac{\cancel{5}^1}{\cancel{6}} \color{red}(\dfrac{\cancel{12}^2}{\cancel{5}} )$
$=\color{red}\left(\dfrac{\cancel{5}}{\cancel{6}^3}\right)\left(\dfrac{\cancel{5}}{\cancel{6}^3}\right) \cdot \left(\dfrac{\cancel{8}^4}{\cancel{5}}\right)\left(\dfrac{\cancel{8}^4}{\cancel{5}}\right) \color{black}+\dfrac{\dfrac{7}{9}-\dfrac{2}{3}}{\dfrac{1}{2}-\dfrac{9}{22}}-\color{red}\dfrac{2}{1}$
$=\color{red}\left(\dfrac{4\cdot 4}{3\cdot 3}\right) \color{black}+\dfrac{\dfrac{7}{9}-\dfrac{2}{3}}{\dfrac{1}{2}-\dfrac{9}{22}}-\color{red}2$
$=\color{red}\dfrac{16}{9} \color{black}+\color{blue}\dfrac{\dfrac{1}{9}}{\dfrac{1}{11}}-\color{red}2$
$=\color{red}\dfrac{16}{9} \color{black}+\color{blue}\dfrac{1}{9}\div\dfrac{1}{11}-\color{red}2$
$=\color{red}\dfrac{16}{9} \color{black}+\color{blue}\dfrac{1}{9}\times\dfrac{11}{1}-\color{red}2$
$=\color{red}\dfrac{16}{9} \color{black}+\color{blue}\dfrac{11}{9}-\color{red}2$
$=\color{red}\dfrac{16+11}{9} \color{black}-\color{red}2$
$=\color{red}\dfrac{27}{9} \color{black}-\color{red}2$
$=\color{red}3 \color{black}-\color{red}2$
$=1$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
