Frame dragging and Light speed
In summary, the Lense-Thirring effect states that the frame of reference in which a clock ticks the fastest is one that is rotating around the object as viewed by a distant observer. This also affects the speed of light traveling in the direction of rotation compared to light moving against the rotation. The location of the object, observer, and traveling light are not used as global frames of reference in general relativity, but rather as coordinates to label events in a certain region of spacetime.
narrator
228
From http://en.wikipedia.org/wiki/Frame-dragging" :
"Under the Lense–Thirring effect, the frame of reference in which a clock ticks the fastest is one which is rotating around the object as viewed by a distant observer. This also means that light traveling in the direction of rotation of the object will move around the object faster than light moving against the rotation as seen by a distant observer."
Is this a speed change to light wrt itself? Is the observation of the "distant observer" different to an observer sitting on the object?
Side question: Is the location of the object, the observer and the traveling light what is meant when people talk about a "coordinate chart"?
Space news on Phys.org
The change is due to space itself bing dragged around the rotating object. This drag would affect the time it takes for light to travel past the object because space itself is being altered. Locally the speed of light is the same.
Not sure what you mean by "wrt itself." The velocity of a physical object with respect to itself is always zero. You can't have a frame of reference moving with a beam of light, so the velocity of light with respect to itself isn't zero, it's just undefined.
No, GR doesn't have global frames of reference like that. A coordinate chart means a set of coordinates that label every event in a certain region of spacetime.
Thanks folks.. understandable and makes sense :)
I can provide a response to this content. Frame dragging and light speed are both concepts that have been extensively studied and observed in the field of physics. Frame dragging, also known as the Lense-Thirring effect, is a phenomenon that occurs when a massive rotating object, such as a planet or a black hole, "drags" the surrounding spacetime with it, causing a distortion in the fabric of spacetime. This distortion can have an impact on the behavior of objects, including light, in the vicinity of the rotating object.
The statement from the Wikipedia article is referring to the fact that the frame of reference in which a clock ticks the fastest is one that is rotating around the object. This means that time appears to move slower for an observer on the rotating object compared to a distant observer. This also has an effect on the speed of light. Light traveling in the direction of rotation of the object will appear to move faster to a distant observer compared to light moving against the rotation.
To answer the first question, this is not a speed change of light relative to itself. The speed of light remains constant in all frames of reference, as per Einstein's theory of relativity. However, the observed speed of light can appear to be different for different observers due to the effects of frame dragging.
As for the second question, the observation of a distant observer will be different compared to an observer sitting on the rotating object. This is because the frame of reference for the two observers is different, and therefore their perception of time and speed will also be different.
Regarding the side question, a coordinate chart is a mathematical representation of the coordinates of different points in a given spacetime. In this context, the location of the object, the observer, and the traveling light can all be represented on a coordinate chart to better understand the effects of frame dragging and light speed.
Related to Frame dragging and Light speed
1. What is frame dragging?
Frame dragging is a phenomenon in which the rotation of a massive body, such as a planet or star, causes the space and time surrounding it to be dragged along with it. This can have an effect on the motion of nearby objects, including light.
2. How does frame dragging affect light speed?
Frame dragging can cause the speed of light to vary in different directions, depending on the direction of the rotation of the massive body. This can result in changes to the observed speed of light, but it does not violate the fundamental constant speed of light in a vacuum.
3. Is frame dragging related to Einstein's Theory of General Relativity?
Yes, frame dragging is a prediction of Einstein's Theory of General Relativity. This theory describes how gravity affects the curvature of space and time, and frame dragging is a result of this curvature.
4. Can frame dragging be observed in real life?
Yes, frame dragging has been observed in several experiments, including the Gravity Probe B mission conducted by NASA. This mission measured the amount of frame dragging caused by the Earth's rotation.
5. Are there any practical applications of frame dragging?
While frame dragging may not have direct practical applications, understanding this phenomenon is important for accurately measuring the motion of objects in space. It also serves as further evidence for the correctness of Einstein's Theory of General Relativity.
