- 5,844
- 551
I was given a problem recently that I had to solve and I haven't been able to get a fully satisfactory conceptual grasp of a certain aspect of it. Consider the slowly rotating Kerr solution ##ds^2 = -\alpha^2 dt^2 + \alpha^{-2}dr^2 + r^2d\Omega^2 - \frac{4Ma}{r}\sin^2\theta dt d\phi + O(a^2)## where ##\alpha^2 = 1 - \frac{2M}{r}## for a slowly rotating thin spherical shell of radius ##R##. Inside the shell the metric is just that of flat space-time i.e. ##ds^2 = -\alpha_R^2 dt^2 + d\rho^2 + \rho^2 d\Omega^2##.
If one makes the transformation to a rotating coordinate system ##\psi = \phi -\Omega t## with an angular velocity ##\Omega = \frac{2M a}{R^3}## then the exterior Kerr metric becomes diagonalized when evaluated on the hypersurface swept out by the shell as is easy to show.
However it can be shown that in the ##(t,\theta,\psi)## coordinate system the shell still has an angular velocity ##\omega = \frac{6Ma}{R^3}\frac{\alpha_R^2}{(1 - \alpha_R)(1 + 3\alpha_R)}##. It can be further shown that it is in fact the inertial observers inside the shell that have an angular velocity ##\Omega## with respect to the spatial infinity of the ##(t,\theta,\phi)## coordinate system and that the shell has an angular velocity ##\Omega + \omega## with respect to this system.
What I don't fully understand is why the Kerr metric on the hypersurface swept out by the shell is diagonalized by the corotating system of angular velocity ##\Omega## if this isn't the angular velocity of the shell but rather that of the inertial observers inside. Usually if we have of a rotating frame in which the metric on a rotating object is diagonalized then we would naively think of this frame as cortating with the object. Clearly that isn't the case here and I would like to understand why. In other words, why is it the angular velocity of the inertial observers inside the shell that diagonalizes the shell 3-metric and not that of the shell itself? Thanks for any insights!
