Frame of Reference Dependant Mass & the Resulting Conflicts
In summary: However, the gravitation between the 2 vessels is stronger than the gravitation in the frame of reference of X' because the mass equivalent of the kinetic energy of the the 2 ton vessel is greater than mass equivalent of the kinetic energy of the 1 ton vessel. This results in a difference in deviation from the straight paths, which can be resolved by considering the stress energy tensor as the source of gravity. In summary, the two vessels in this scenario experience a difference in gravitational pull due to their relative velocities and the mass equivalent of their kinetic energies, which can be resolved by taking into account the stress energy tensor as the source of gravity.
a1call
90
Hello,
Please:
• Assume a universe void of all matter
• Visualize 2 parallel paths, 10 meters apart. Let’s call them x and x'
Vessel X is moving along x and vessel X' is moving along x'
Vessel X has a mass of 1 metric ton and vessel X’ has a mass of 2 metric tons
• At t0 the two vessels are sufficiently apart to have negligible gravitation towards one another
• The two vessels are moving at a relative velocity of 100 km/h towards a 10 meter flyby. However the actual shortest separation will be less than 10 meters due to deviation from straight paths due to gravitation between the two vessels
• In the frame of reference of X the gravitation is between a 1 ton vessel and a 2 ton vessel + the mass equivalent of the kinetic energy of the 2 ton vessel
• In the frame of reference of X’ the gravitation is between a 2 ton vessel and a 1 ton vessel + the mass equivalent of the kinetic energy of the 1 ton vessel
• In the frame of reference of X the gravitation between the 2 vessels is stronger than the gravitation in the frame of reference of X’. This is because the mass equivalent of the kinetic energy of the the 2 ton vessel is greater than mass equivalent of the kinetic energy of the 1 ton vessel
o How can this conflict and the resulting difference in deviation from the straight paths be resolved?
Thanks in advance.
In modern physics mass is invariant. Also, the source of gravity is neither mass nor energy but rather the stress energy tensor which encompasses energy, momentum, pressure, and stress.
FAQ: Frame of Reference Dependant Mass & the Resulting Conflicts
What is frame of reference dependent mass?
Frame of reference dependent mass is a concept in physics that refers to the measurement of an object's mass in relation to a specific reference frame. This means that an object's mass can change depending on the observer's frame of reference, such as their velocity or acceleration.
How does frame of reference dependent mass relate to Einstein's theory of relativity?
Einstein's theory of relativity states that mass and energy are interchangeable and that the laws of physics should be the same for all observers in uniform motion. This means that an object's mass can appear different to different observers depending on their frame of reference, which is known as frame of reference dependent mass.
What are some examples of conflicts that arise from frame of reference dependent mass?
One example is the twin paradox, where one twin travels at high speeds in space while the other twin stays on Earth. When the traveling twin returns, they will have aged less than their twin on Earth due to the effects of relativity and frame of reference dependent mass. Another example is the increased mass of particles in particle accelerators, which can lead to conflicts in the calculated energy and mass of the particles.
How does frame of reference dependent mass affect our understanding of the universe?
Frame of reference dependent mass is crucial in understanding the behavior of objects in the universe. It helps to explain phenomena such as time dilation, length contraction, and the bending of light around massive objects. Without considering frame of reference dependent mass, our understanding of the universe would not be complete.
Can frame of reference dependent mass be observed in everyday life?
Yes, frame of reference dependent mass can be observed in everyday life. One example is the Doppler effect, where the frequency of sound or light waves appears to change depending on the observer's relative motion. Another example is the difference in weight measurements on Earth and in space, where an object's mass appears different due to the effects of gravity and frame of reference dependent mass.
