Frames with inclined legs using slope-deflection method
In summary, the figure from "Structural Analysis" by Aslam Kassimalli shows that the tangent to the deflected shape at C' is parallel to the original member AC, indicating a zero slope at C. However, the slope at C is considered as an unknown in the slope-deflection equations. This is because the rotation at both C and D is partially restrained by the stiffness of the attached members, making it impossible to assume the parallelism.
Ashu2912
107
This is a diagram from "Structural Analysis" by Aslam Kassimalli while solving frames using slope-deflection method. In the figure, the tangent to the deflected shape at C` is parallel to the original member AC implying that the slope at C is zero. However, later they have considered θC (the slope at C) as an unknown while writing the slope deflection equations. Why so?
I don't think you can assume that the tangent at C' (the prime symbol ' is not clear enough in the figure) is parallel to AC. The tangent at D' is not visibly parallel to BD, and shouldn't be. In general, I would expect both C and D to rotate somewhat, because the rotation is only partially restrained by the stiffness of the attached members.
Related to Frames with inclined legs using slope-deflection method
1. What is the slope-deflection method?
The slope-deflection method is a structural analysis technique used to determine the internal forces and displacements in a structure. It involves calculating the slope and rotation at each joint of a structure, and then using these values to determine the forces and moments at each member.
2. How is the slope-deflection method different from other structural analysis methods?
The slope-deflection method is different from other methods, such as the moment distribution method, because it takes into account the rotational stiffness of each member. This allows for more accurate results, especially for structures with non-prismatic members or varying cross-sections.
3. What are inclined legs in a frame structure?
Inclined legs in a frame structure refer to members that are not perpendicular to the ground, but instead have an angle or slope. These members are typically used to support the weight of the structure and transfer loads to the foundation.
4. How do you apply the slope-deflection method to frames with inclined legs?
To apply the slope-deflection method to frames with inclined legs, the slope and rotation at each joint must be calculated for both the vertical and horizontal directions. These values are then used to determine the forces and moments at each member, taking into account the inclination of the legs.
5. What are the advantages of using the slope-deflection method for frames with inclined legs?
The slope-deflection method allows for a more accurate analysis of frames with inclined legs compared to other methods. It also takes into account the rotational stiffness of each member, resulting in more precise results. Additionally, this method is relatively simple and can be easily applied to frames with varying cross-sections or non-prismatic members.
14K
