Franck hertz Experiment-Ionization vs Excitation
In summary: This process repeats itself as the accelerating voltage is raised, resulting in a sawtooth pattern in the current. In summary, the Franck-Hertz experiment demonstrates the relationship between ionization and excitation in neon gas, showing that while the electrons can reach a high enough energy to excite the gas, they do not have enough energy to fully ionize it.
realgenob
Franck hertz Experiment--Ionization vs Excitation
We performed the Franck-Hertz experiment with neon gas. As we raised the accelerating voltage, the electrons gained enough energy to raise the energy of the neon through inelastic collisions. Those electrons lose some energy and and can't reach the cathode due to the retarding voltage which in turn causing the voltage to drop. When the gas returns to a lower state, the collisions with the electrons are again elastic and the electrons reach the cathode, restoring the higher current. I understand that process, however, I have an analysis question that ask "Why doesn't the gas ionize when the accelerating voltage is raised beyond the ionizing potential of neon.
The main reason why the gas doesn't ionize when the accelerating voltage is raised beyond the ionization potential of neon is because the electrons gain enough energy to raise the energy of the neon through inelastic collisions, but not enough energy to fully ionize the gas. Because of this, the electrons are able to lose some energy and be unable to reach the cathode due to the retarding voltage which in turn causes the voltage to drop. When the gas returns to a lower state, the collisions with the electrons are again elastic and the electrons reach the cathode, restoring the higher current.
FAQ: Franck hertz Experiment-Ionization vs Excitation
1. What is the Franck Hertz Experiment?
The Franck Hertz Experiment is a physics experiment that was conducted in the early 20th century to study the behavior of electrons in a gas. It involves passing a current through a gas-filled tube and measuring the energy levels of the electrons as they collide with gas molecules.
2. What is the difference between ionization and excitation in the Franck Hertz Experiment?
In the Franck Hertz Experiment, ionization refers to the process of an electron gaining enough energy to completely leave its atom and become a free electron. Excitation, on the other hand, refers to the process of an electron gaining energy but remaining in its original atom, causing the atom to be in an excited state.
3. How does the Franck Hertz Experiment demonstrate the quantization of energy?
The Franck Hertz Experiment demonstrates the quantization of energy by showing that electrons can only gain or lose energy in discrete amounts, rather than in a continuous manner. This is observed in the form of distinct peaks in the energy levels of the electrons, which correspond to the different energy levels of the gas atoms.
4. What is the significance of the Franck Hertz Experiment?
The Franck Hertz Experiment was a groundbreaking experiment that provided evidence for the quantization of energy and helped to validate the quantum theory. It also helped to further our understanding of the behavior of electrons in gases, which has many practical applications in fields such as electronics and lighting.
5. How is the Franck Hertz Experiment used in modern technology?
The principles of the Franck Hertz Experiment are still used in modern technology, particularly in the development of electronic devices such as transistors and computer chips. It is also used in the production of fluorescent lights and other gas-discharge lamps.
