Fraunhofer's multiple slits versus atomic scatteres (diffraction theory)
In summary, the Fraunhofer diffraction pattern depends on slit width and slit distance. When you have N=6 atomic scatteres (scattering centers), there is no slit width, but there is an atomic width or something similar. The diffraction pattern of 6 slits and 6 atomic scatteres is different.
Gamdschiee
28
Hey, I am currently busy with studying solid state physics and looking at diffraction theory. Following link explains Frauenhofer diffraction pretty good: http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/mulslid.html#c3
Let's assume a N=6 multiple slits. Its diffraction pattern depends on slit width w and slit distance d.
But when you have N=6 atomic scatteres (scattering centers) you only have the distance d between them. There is no slit width. But is there a atomic width or something similar?
So how differs the diffraction pattern of 6 slits and 6 atomic scatteres? (1D observation only for now)
EDIT: I meant Fraunhofer, sorry. Maybe a mod could edit the title please.
<mentor edited title>
The Fraunhofer single slit diffraction is much simpler than the crystal scattering that you previously did. (Recall https://www.physicsforums.com/threads/diffraction-on-periodic-structures.952210/#post-6033221 ) . The crystal scattering involves reflections off of crystal planes with angle of incidence=angle of reflection, along with the atoms in adjacent planes needing to have the optical path difference be an integer number of wavelengths. ## \\ ## The interference principles are the same in multi-slit diffraction as for scattering by the atoms of a crystal, but the Fraunhofer case for multiple slits is much simpler than scattering by a crystal. Here is a recent homework that came up on this topic that you might find of interest: https://www.physicsforums.com/threa...tion-pattern-ratio-of-power-densities.956805/ This is quite a detailed examination of the intensity of the peaks as a function of angle, but if you can follow this, you understand the multi-slit case quite well... In particular, the multi-slit case uses a very specialized formula (see post 2 of the "link" ) that is quite exact. It is a very useful formula, and is used very often in the multi-slit case. It is really important to be able to work this formula if you really want to have a good handle on the multi-slit case. This homework problem is a good exercise in working with that formula, and further on in the thread, I describe in detail how the formula is used in the calculation when the denominator goes to zero, which happens at the primary maxima of the diffraction pattern. Other than this slightly complex formula, the multi-slit case is quite straightforward. ## \\ ## And see also the "link" found in post 7 of this very detailed thread. In that "link" they give the correction factor that occurs for a slit of finite width. That is just the single slit diffraction factor. The formula discussed above is the interference factor resulting from multiple slits of very narrow width. If the slits are finite in width, the result is simply the inclusion of a single slit diffraction factor to get the complete result.
Likes Gamdschiee
One additional comment: In quite a number of the write-ups on multi-slit interference, they assume normal incidence and have ## \Phi=\frac{2 \pi \, d \sin(\theta)}{\lambda} ##. In the more general case where the incident angle differs from zero (normal incidence), the equation reads ## \Phi=\frac{2 \pi \, d (\sin(\theta_i)+\sin(\theta_r))}{\lambda} ##. ## \\## And an additional item: I believe this may have been discussed in the previous thread a couple months ago about crystal scattering: (see e.g. post 20 of that discussion) For the derivations with the diffraction grating, the phase factor ## \phi=(\vec{k}-\vec{k}')\cdot \vec{r} ## is replaced by ## \phi=\frac{2 \pi \, x (\sin(\theta_i)+\sin(\theta_r))}{\lambda} ## where ## x ## is the position on the plane of the slit, and the integral over ## \vec{r} ## is replaced by an integral over ## x ##. ## \\ ## The derivation with the multi-slit case is quite similar to the scattering by a crystal, but actually a little simpler, and with equally spaced slits, the result can be readily computed by summing the geometric series. The intensity ## I ## is then found by taking the square of the amplitude of the resultant ## E ##, and gives the formula as provided in post 2 of the second "link" above. With the integration over ## x ## , the ## \phi ## of significance is ## \Phi=\frac{2 \pi \, d (\sin(\theta_i)+\sin(\theta_r))}{\lambda} ##, and it is this last ## \Phi ## that appears in the intensity formula of post 2 of the second "link" above. ## \\ ## We will repeat that formula here: ## I=I_o \frac{\sin^2(\frac{N \Phi}{2})}{\sin^2(\frac{\Phi}{2})} ##.
Likes Gamdschiee
Gamdschiee said:
Thanks you!
But you can say in general that the diffraction pattern from N=6 scatteres looks like the one from N=6 slits?
Like this (example with 5 slits): http://www.physics.louisville.edu/cldavis/phys299/notes/lo_msdiffraction_fig2.jpg
So you can say N slits = N scatteres.
I don't think that works. If you have 6 point sources in a line , the pattern will in some ways be similar to that of 6 slits, but not identical. ## \\ ## Most often, whether it is a bunch of slits, or a diffraction grating, there is some illumination that extends in the ## y ## direction. If you are referring simply to atoms, I think you would get a completely different result. 6 scatterers might produce a similar pattern, but the signal would be lost in the noise. The closest analogy might be if 6 crystal planes were involved in the scattering. The Bragg condition still includes the condition that angle of incidence equals angle of reflection, so that scatters from the same plane constructively interfere with a ## m=0 ## type maximum. In general, the Bragg peaks involve constructive interference from perhaps 1,000, 000 or more scatterers, and perhaps 1,000,000,000 or more. ## \\ ## (Edit: And on further thought, these numbers are even very conservative). And in crystal scattering, the wavelength needs to be much shorter, because atomic distances are on the order of 2 Angstroms, thereby, the scattering is done using x-rays.
Likes Gamdschiee
Ok, I see your point.
What about 2D then? E.g. we take this six atom scatteres and form it into a hexagon. For startes I read this here: https://www.doitpoms.ac.uk/tlplib/diffraction/diffraction3.php
So could it be that the diffraction pattern will just look like a hexagon without the lines between the "intensity points" ?
The approach you are taking is the kinds of calculations that are done in making arrays of r-f antennas=radiating sources, to try to create a pattern that peaks in certain directions, e.g. for a radio station. For the kind of signal levels that is generated by a single atomic scatterer, this is simply unfeasible. You need literally millions of scatterers in a regular array to produce a couple of Bragg peaks. ## \\ ## An item of interest is that it is the spacing of the sources/scatterers that determines the location of the primary maxima, and not the number of sources. e.g. a diffraction grating can have 20,000 lines on it, (reflection type grating), and the primary maxima are in the same locations as if there were only 5 or 6 lines on the grating=e.g. 5 or 6 slits. More lines means on the grating means sharper peaks=higher resolution for the spectrometer, but it does not change the location of the peaks, given by ## m \lambda=d (\sin{\theta_i}+\sin{\theta_r} ) ##. ## \\ ## This is a side topic, but one useful concept worth mentioning is the optics that are used in a diffraction grating spectrometer: ## \\ ## A typical diffraction grating is 2"x2" and it is illuminated with a plane wave by using the light from the entrance slit which is made into a plane wave by putting the entrance slit at the focal point of a parabolic or spherical reflector. The collimated plane wave (parallel rays) are incident on the diffraction grating. The diffraction grating acts like a prism=different wavelengths have their bright spots (diffraction pattern peaks) at different angles. Instead of observing the spectrum which is the diffraction pattern in the far field, it can be observed at close range by using a second parabolic mirror and putting the exit slit in the focal plane of this second mirror. The entire spectrum can also be observed on a screen in the focal plane. Parallel rays at angle ## \theta ## are brought to a focus at position ## x=f \, \theta ## in the focal plane. (The beam that is 2" in diameter coming off the grating at a particular angle/wavelength focuses to a point, or in the shape of the entrance slit in the plane of the exit slit.) This way, the exit slit can be used to select a particular wavelength. To get a different wavelength emerging from the exit slit, the grating is rotated. ## \\ ## Since you are studying diffraction theory in some detail, you might find a couple of details quite useful in regards to a diffraction grating type spectrometer. ## \\ ## Edit: See also post 4 of: https://www.physicsforums.com/threads/diffraction-on-periodic-structures.952210/#post-6033221 I repeated it here, but it's quite an important concept.
Related to Fraunhofer's multiple slits versus atomic scatteres (diffraction theory)
1. What is Fraunhofer's multiple slits diffraction theory?
Fraunhofer's multiple slits diffraction theory is a phenomenon in which light passing through multiple slits creates a diffraction pattern on a screen. This theory explains how the spacing and size of the slits affect the pattern produced.
2. How does Fraunhofer's multiple slits diffraction theory differ from atomic scatterers?
Fraunhofer's multiple slits diffraction theory involves light passing through multiple slits, while atomic scatterers refer to the scattering of light by atoms. The main difference is that Fraunhofer's theory focuses on the interference of light waves, while atomic scatterers involve the interaction of light with individual atoms.
3. What factors affect the diffraction pattern produced by Fraunhofer's multiple slits?
The spacing and size of the slits, the wavelength of the light, and the distance between the slits and the screen all affect the diffraction pattern produced by Fraunhofer's multiple slits. Additionally, the number of slits and the angle of incidence of the light also play a role in the pattern.
4. What is the purpose of using Fraunhofer's multiple slits diffraction theory?
Fraunhofer's multiple slits diffraction theory is used to explain and predict the diffraction patterns produced by light passing through multiple slits. This theory has applications in fields such as optics, astronomy, and materials science.
5. How does Fraunhofer's multiple slits diffraction theory relate to the wave-particle duality of light?
Fraunhofer's multiple slits diffraction theory demonstrates the wave-like nature of light, as it involves the interference of light waves. This is one of the key examples of the wave-particle duality of light, which states that light can behave as both a wave and a particle depending on the experimental setup.
  • Atomic and Condensed Matter
16K
