Free Body Diagram of Car on Mountain
In summary, the author of the question intended us to consider a curved mountain surface when the car is at the peak of the mountain.
TimeInquirer
32
If a car is on top of a mountain moving with an initial velocity, will it only forces acting on it be the normal force counteracted by the force due to gravity?
No. Is this in relation to a homework problem? Often times you are intended to make assumptions like to ignore certain types of friction, but the intent may be to have you ignore these forces.
It was an open based discussion in my physics class after various demos. We often neglected reaction forces such as forces between the tires and the ground. I am mostly interested in how to represent the initial velocity and acceleration of such a vehicle.
The normal force will be less than the gravitational force. Part of the gravitational force will be used to change the direction of the velocity vector as the car travels in the arc over the crest of the mountain.
It depends on what you mean by 'top of a mountain.' I interpret that to mean that the road is flat which means the velocity would be horizontal, and there would be no acceleration (assuming the person is not using the controls to do so). If, on the other hand, the car is going up or downhill then there will be a component of gravity that points along the slope.
If you have experience with vectors you may be able to draw the components of the gravitational force that are parallel and perpendicular to the road without much difficulty. You can use this to find an expression for the acceleration of the car under ideal conditions. If you look up 'block on a frictionless inclined plane' I bet you'll find some more detail (though you should try the diagram yourself first!).
side question related to a different problem involving a spring. I calculate the frequency to be 2.65 (which is f= 2pi/w) but the answer is 0.265? What can be the reason for this? My angular velocity w is correct because it was given. Thank you.
I have noticed it is because of the way I put it into the calculator sqrt(4/1.4)/2pi vs 1.69/2pi
If you are calculating frequency your formula is incorrect. Check your units (angular velocity has units of inverse seconds).
We clearly have a difference in interpretation here. In the problem statement, they didn't have to mention that it was on the top of a mountain if they didn't expect you to take into account the curvature (and, instead, assume the car was on a flat horizontal surface).
Chet
I agree with you 100%, but why not say 'on a hill' or something? 'Top of a hill' to me says something different. I think you're right that the author of the question intends to discuss the component of gravity on a sloped surface.
I never said that. I said the author intended us to consider a curved mountain surface when the car is at the peak of the mountain.
Chet
Yes, after reading your initial post again I see that is what you meant. I think we can probably agree that the question could have been phrased more clearly and leave it at that.
Likes TimeInquirer and Chestermiller
Related to Free Body Diagram of Car on Mountain
1. What is a free body diagram?
A free body diagram is a visual representation of the forces acting on an object. It is used to analyze the motion of an object and understand the different forces that may affect it.
2. Why is it important to create a free body diagram for a car on a mountain?
Creating a free body diagram for a car on a mountain allows us to understand the different forces acting on the car, such as gravity, normal force, and friction. This helps us analyze the motion of the car and determine its stability on the mountain.
3. How do you draw a free body diagram for a car on a mountain?
To draw a free body diagram for a car on a mountain, you first need to identify all the forces acting on the car. These may include the weight of the car, the normal force from the ground, and any frictional forces. Then, draw a simple diagram of the car and label each force with an arrow indicating its direction and magnitude.
4. What are the key components of a free body diagram for a car on a mountain?
The key components of a free body diagram for a car on a mountain include the car itself, the forces acting on the car, and the direction and magnitude of each force. It is important to accurately label and represent each force to properly analyze the motion of the car.
5. How does a free body diagram help in solving problems related to a car on a mountain?
A free body diagram helps in solving problems related to a car on a mountain by providing a visual representation of the forces acting on the car. This allows us to use the principles of Newton's laws of motion to determine the net force on the car and predict its motion on the mountain.
  • Mechanics
  • Mechanics
