Free energy from Thorium to Radon
In summary, the released energy is approximately 1.23 x 10^-12J, which was calculated by multiplying the mass difference of 0.0082257 atomic mass units by the speed of light squared. This value may seem high, but it is accurate according to the equation E=mc^2.
Xeno24
Th --> Ra + He
90 88 2228,031015u --> 224,020186u + 4,0026033u
228,031015u - [224,020186u + 4,0026033u]=
0,0082257u
0,0082257u x 931.49 MeV = 7662157,293eV
7662157,293eV x (1.602 x 10^-19J) =
1,2274776 x 10^-12J
Svar: Frigjorda energin är: ~ 1.23 x 10^-12JHi, people could anyone check what I've done wrong here? My teacher says the answer value is a bit too high. It's just arithmetic and I've still done something wrong...I tried multiplying the (0,0082257u) with (1.66 x 10^-27) x C^2 and I still get ~ 1.23 x 10^-12J
Thanks.
Xeno24 said:
228 224 4
Th --> Ra + He
0,0082257u
1,2274776 x 10^-12J
Thanks.
Your answer appears to be right.
From E = mc^2:
Just multiply the mass difference in kg. by c^2 in m/sec. to get the energy in joules
Mass difference is 8.226x10^-3 amu. One kg = 1000 x 6.02x10^23 amu so one amu = 1.66 x 10^-27 kg. Multiply that by (3 x 10^8 m/sec)^2 to get the energy in J. per amu. (= 1.49 x 10^-10 J.). So that works out to 8.266x10^-3 x 1.49 x 10^-10 = 12.3 x 10^-13 J = 1.23x10^-12 J.
AM
Hi there, thank you for providing your work. I see that you have correctly calculated the difference in mass between thorium and radon and converted it to energy using the equation E=mc^2. However, the issue may be in your conversion from atomic mass units (u) to kilograms (kg). The conversion factor you used (1.66 x 10^-27) is for converting from atomic mass units to kilograms, but you also need to convert from kilograms to joules. This can be done by multiplying by the speed of light squared (c^2), which is 8.99 x 10^16 m^2/s^2. So the correct conversion factor would be (1.66 x 10^-27) x (8.99 x 10^16) = 1.49 x 10^-10. Using this conversion factor, the final answer would be 1.22 x 10^-13 J, which is closer to the expected value. I hope this helps clarify the issue.
Related to Free energy from Thorium to Radon
1. What is free energy from Thorium to Radon?
Free energy from Thorium to Radon refers to the process of harnessing energy from the radioactive decay of thorium into radon. This process is known as thorium-based nuclear power and has been proposed as a potential alternative to traditional nuclear power sources.
2. How does the process of free energy from Thorium to Radon work?
The process involves the use of a nuclear reactor to convert thorium into uranium-233, which then undergoes fission to produce energy. This process also generates smaller amounts of other radioactive elements, including radon, which can also be harnessed for energy production.
3. What are the advantages of free energy from Thorium to Radon?
There are several potential advantages to this type of energy production, including a larger supply of thorium compared to uranium, reduced waste and environmental impact, and the potential to reduce the risk of nuclear proliferation.
4. Are there any potential drawbacks or challenges to implementing free energy from Thorium to Radon?
While there are many potential benefits, there are also some challenges to consider, such as the technical complexity of building and maintaining thorium-based nuclear reactors, the potential for accidents or meltdowns, and the need for further research and development to fully understand the safety and feasibility of this technology.
5. Is free energy from Thorium to Radon a viable solution for our current energy needs?
There is still much debate and ongoing research about the potential of free energy from Thorium to Radon as a sustainable and safe energy source. While it shows promise, it is not yet considered a proven or widely implemented solution for our current energy needs.
