Free fall and pressure when landing in snow
In summary, during World War II, Russian soldiers were occasionally dropped inside bales of hay onto snow due to a lack of parachutes. The human body can survive an average pressure of 30 lb/in2 on impact. To determine if it was safe to drop soldiers, a dummy bale was dropped from an altitude of 150 ft and observed to sink 2 ft into the snow. Using the equations W=F∆x and v=√(2gh), two different answers were obtained. The first equation led to a pressure of 15 lb/in2, while the second equation led to 30 lb/in2, which was deemed very risky. However, it was later discovered that the equation ∆t = ∆
Order
97
During the second world war the Russians, lacking sufficient parachutes for airborne operations, occasionally dropped soldiers inside bales of hay onto snow. The human body can survive an average pressure on impact of 30 lb/in2.
Suppose that the lead plane plane drops a dummy bale equal in weight to a loaded one from an altitude of 150 ft, and that the pilot observes that it sinks about 2 ft into the snow. If the weight of an average soldier is 144 lb and his effective area is 5 ft2, is it safe to drop the men?
I use two equations. One lead to the correct answer and that is the formula:
[tex]W=F\Delta x[/tex]
The other one lead to another answer and that is
[tex]v=\sqrt{2gh}[/tex]
I use the notation [tex]h=150 ft[/tex] [tex]m=144 lb[/tex] [tex]\Delta x = 2 ft[/tex] [tex]A=5ft^{2}[/tex]
1. The work done on the falling body is zero from jump to landing so [tex]0 = mgh-F\Delta x[/tex] and therefore [tex]F=\frac{mgh}{\Delta x}[/tex] The pressure is therefore [tex]P=\frac{F}{A}=\frac{mgh}{\Delta xA}= 15 lb/in^{2}[/tex]
2. The speed of the falling body at impact is [tex]v=\sqrt{2gh}[/tex] As it hits the snow it will drop in speed during a time [tex]\Delta t = \frac{\Delta x}{v}[/tex] Therefore the force on the body at landing will be [tex]F=\frac{mv}{\Delta t}[/tex] This leads to a pressure of [tex]P=\frac{mv}{\Delta t A}=\frac{2mgh}{\Delta x A} = 30 lb/in^{2}[/tex] Very risky indeed.
Now this is two answers and only one can be correct. What is wrong?
Hi Order! :smile:
Your equation ∆t = ∆x/v is wrong.
∆t = ∆v/a would be correct (if we assume constant acceleration ). :wink:
tiny-tim said:
Hi Order! :smile:
Yes, I think we assume constant acceleration since we assume constant pressure on the body. Ok, so a=-d2x/dt2 leads to [tex]\Delta x=v \Delta t -\frac{a\Delta t^{2}}{2}=v \Delta t -\frac{v\Delta t^{2}}{\Delta t2}=\frac{v \Delta t}{2}[/tex] which leads to [tex]\Delta t = \frac{2\Delta x}{v}[/tex] Now this must be correct. Thanks for help!
I thought there was something wrong and thought about average velocities , but this was much better.
FAQ: Free fall and pressure when landing in snow
What is free fall?
Free fall is a type of motion where an object falls towards the ground due to the force of gravity, without any external forces acting on it. This means that the object is not being pushed or pulled by any other forces.
How does free fall affect the body when landing in snow?
When landing in snow, the body experiences a sudden deceleration due to the impact with the ground. This can cause stress and strain on the body, especially on the joints and bones. Additionally, the resistance from the snow can cushion the landing and reduce the impact force on the body.
Does the amount of snow affect the pressure when landing?
Yes, the amount of snow can affect the pressure when landing. The thicker the layer of snow, the more cushioning effect it will have on the landing, reducing the pressure on the body. However, if the layer of snow is too thin, it may not provide enough cushioning and the pressure on the body may be higher.
How does the speed of free fall affect the pressure when landing in snow?
The speed of free fall can greatly affect the pressure when landing in snow. The higher the speed, the greater the impact force will be on the body. This means that a higher speed of free fall will result in a higher pressure on the body when landing in snow.
Is there a difference in pressure when landing in loose snow versus compacted snow?
Yes, there is a difference in pressure when landing in loose snow versus compacted snow. Loose snow will provide more cushioning and reduce the impact force on the body, resulting in a lower pressure. On the other hand, compacted snow will have less cushioning and may result in a higher pressure on the body when landing.
