Free Fall Trajectory? Simple answer
In summary: So in summary, the free fall trajectory method is the component method for calculating the velocity of a marble as it falls.
MacFanBoy
So I am basically lost in what that means. I think it is the component method for vectors? Am I right? Some background on the lab: We rolled a marble down a curved ramp so that it went off the table and hit the ground in front of the table. (we marked where it hit with carbon copy paper. I already measured the potential energy and velocity.
Question: Recalculate the horizontal marble velocity of the marble at the bottom of the track using the free fall trajectory method.
The height of the curved track from the table was 14.3cm and the height from the table to the ground was 84.4cm
And the distance that the marble traveled from the edge of the desk was 44.5cm
mass of marble = 13.7g
Do I need the length of the track?
(THis is what I am looking for)
If someone could explain what free fall trajectory method is (my teacher doesn't teach, he just talks). That should be enough to point me in the right direction. Also if it is the component method, then i would need the angle of the ramp, correct?
Thanks!
You basically have it, so long as you know the height of the table.
Knowing the height you can calculate the time that it takes to drop.
Your Vy is initially zero until it goes off the edge.
So the time is given simply by 1/*g*t2 = height of table.
Knowing the time you're rolling in clover because the x distance isd calculated simply by Vx * time.
Not asked but going further if you know the V you know the m*v2/2 which is going to be equal (if you could ignore friction and such) to the initial Potential energy of the marble at the height it started rolling down from.
Ok, so when I do:
height of table = 84.4cm
.844m=[.5*(9.80m/s)]*t2
I get t=.415s
Then; dx=Vx*t gets me Vx of 1.07m/s
Thats the velocity in the X-direction?
If so then my other calculations are off by 400%...
This is what I got for my other calcs:
mmarble=13.7g
htable and ramp = 98.7cm
PE=mgh
PE=(.0137kg)(9.80m/s)(.987m) =.133 J
Then;
PE=KE
.133 J=.5*m*v^2
.133 J= .5*(.0137kg)*v^2
v=4.41 m/s
Is all of that right?
Thanks
MacFanBoy said:
Ok, so when I do:
I get t=.415s
mmarble=13.7g
PE=mgh
Then;
PE=KE
.133 J=.5*m*v^2
v=4.41 m/s
Thanks
Not quite. If
1/2*m*v2 = m*g*h
Then your initial Vx will be given by Vx = (2*g*h)1/2
The h though is only the h of the ramp down to the top of the table.
That comes to (2*9.8*.143)1/2
Oh. Alrighty. I guess it just clicked in my head. Thanks.
Related to Free Fall Trajectory? Simple answer
What is free fall trajectory?
Free fall trajectory is the path or trajectory of an object when it is falling freely under the influence of gravity, with no other forces acting on it.
What factors affect the trajectory of a free falling object?
The factors that affect the trajectory of a free falling object are the initial position, initial velocity, and the acceleration due to gravity.
How is the trajectory of a free falling object calculated?
The trajectory of a free falling object can be calculated using the equations of motion, which take into account the initial position, initial velocity, acceleration due to gravity, and time.
What is the difference between free fall trajectory and projectile motion?
Free fall trajectory refers to the motion of an object that is only influenced by gravity, while projectile motion takes into account both the effects of gravity and an initial horizontal velocity.
What is the importance of understanding free fall trajectory in science?
Understanding free fall trajectory is important in science as it helps us predict and understand the motion of objects in free fall, which is a fundamental concept in physics. It also has practical applications, such as in the design of parachutes and other devices that involve free fall motion.
11K
