Free fall velocity of object under water
In summary, the author is trying to calculate the impact force of a free falling cylinder of metal under water. He started with the work energy principle and net work done to calculate the impact force, but now he is trying to include the drag from the water. He got a couple of equations, one being stokes Fd = 6PIuvd and the other being Fd = 0.5CpAv^2. Using the principle that the forces of buoyancy and drag are equal to the force of it falling; he started to try and work things out. He found that the buoyancy force was equal to the displaced fluid weight times the accel due to gravity, and the drag coefficient was equal to 0.82.
jayzedkay
I posted this problem in another section, but it seems to have fizzled out and I’m trying to solve it, so resurrected it here hopefully to get somewhere.
I’m trying to calculate the impact force of a free falling cylinder of metal under water accounting for the drag. The cylinder is restricted to vertical falling, so cannot tumble down so to speak.
I started with the work energy principle and net work done to calculate the impact force, but now I am trying to include the drag from the water.
I got a couple of equations, one being stokes Fd = 6PIuvd and the other being Fd = 0.5CpAv^2.
Using the principle that the forces of buoyancy and drag are equal to the force of it falling; mg=Fb+Fd, I started to try and work things out.
Buoyancy force I used is the displaced fluid weight times the accel due to gravity. So here I used;
Fb = volume of cylinder X density of fluid X accel due to gravity = PIr^2hpg
For drag I used either Fd = 6PIuvd or Fd = 0.5CpAv^2 in each calculation.
I rewrote the equations with all the available parameters:
mg = PIr^2hpg + 6PIuvd
or
mg = PIr^2hg +0.5CpAv^2
I then rearranged for velocity, my objective is to isolate velocity inclusive of drag, then I can use that new calculated velocity in the original work energy principle and get the new impact force. So I get;
v = [ (m*g) – PI*r^2*h*p*g ] / 6*PI*u*d (eqn1).
Or
v = sqrt{ 2*[ (m*g) – PI*r^2*h*p*g ] / C*p*A } (eqn2).
I used the following for the parameters;
m = mass of metal cylinder, I used 10kg
g = acceleration due to gravity (9.8m/s^2)
PI = 3.1416
r = radius of cylinder, I used 7.5cm
h = height/length of cylinder, I used 30cm
p = density of fluid, I used 1000kg/m^3
u = viscosity of fluid, I used 0.00179 Pa.s
C = drag coefficient of cylinder, I used 0.82
d = diameter of cylinder, I used 15cm
A = cross sectional area of cylinder
Eqn1 doesn’t give me physically possible number as answer (>9k), eqn 2 could be, i.e. it’s less than 9.8, which I’d expect. Things fall slower under water than in air.
Am I going about it the right way, if not, where am I going wrong etc.
Thanks in advance for help/pointers etc.
How r u going to use stokes' law it is for sphere
you can see how i intended on using it in my post? rightly or wrongly, probably. as that one gives me non-physical answer? my other drag equation seems to be more suitable, but I'm not sure I'm going about it the right way. so trying whatever i can get my hands on really. i'd appreciate a more constructive/practical critiscm really? anyone else add some informative info to my problem?
thanks in advance.
Related to Free fall velocity of object under water
1. What is free fall velocity?
Free fall velocity is the speed at which an object falls towards the Earth due to the force of gravity, without any external forces acting on it. In other words, it is the maximum speed an object can reach as it falls through a medium, such as air or water.
2. How does the free fall velocity of an object under water differ from that in air?
The free fall velocity of an object under water is affected by the density and viscosity of the water, as well as the shape and size of the object. This means that the object will reach a lower maximum speed in water compared to air.
3. How is free fall velocity calculated in water?
Free fall velocity in water can be calculated using the formula v = √(2gd), where v is the velocity, g is the acceleration due to gravity (9.8 m/s²), and d is the distance the object has fallen.
4. Can the free fall velocity of an object under water be changed?
Yes, the free fall velocity of an object under water can be changed by altering its shape, size, or weight. For example, a more streamlined object will have a lower free fall velocity compared to a larger, bulkier object.
5. What factors affect the free fall velocity of an object under water?
The main factors that affect free fall velocity in water are the density and viscosity of the water, as well as the shape, size, and weight of the object. Other factors such as the depth and temperature of the water can also play a role.
9K
  • Mechanics
  • Mechanics
