Free Fall With Air Resistance Problem
In summary, the piece of Styrofoam reaches terminal speed of 0.3 m/s after falling 0.5 meters and takes 5 seconds to reach the ground. The value of the constant b is 32.667 and the acceleration at t = 0 is -9.8 m/s^2, reaching a final acceleration of -4.9 m/s^2 when the speed is 0.150 m/s.
hardygirl989
A small piece of Styrofoam packing material is dropped from a height of 2.00 m above the ground. Until it reaches terminal speed, the magnitude of its acceleration is given by a = -g + bv. After falling 0.500 m, the Styrofoam effectively reaches terminal speed, and then takes 5.00 s more to reach the ground. (a) What is the value of the constant b? (b) What is the acceleration at t = 0? (c) What is the accleration when the speed is 0.150 m/s?
ƩF=ma
W = weight
FD = resistant force
I drew a free body diagram with the resistance force pointing up and the weight pointing down, where up is positive.
ƩF=W-FD=ma
-mg + bv = ma
-(1)g + bv = (1)a
-g + bv = a
bv-g = 0
b = g/v
I am stuck here because I am not sure how to find the terminal velocity. Do I do v=x/t=0.05/0.150=10/3≈3.33 m/s? That would make b = 9.8/(10/3)=2.94Kg/s, which seems too high...Can anyone help? Thanks.
hardygirl989 said:
A small piece of Styrofoam packing material is dropped from a height of 2.00 m above the ground... After falling 0.500 m, the Styrofoam effectively reaches terminal speed, and then takes 5.00 s more to reach the ground.
What distance does the Styrofarm travel with the terminal speed?
ehild
The terminal speed is when the acceleration is zero.
During the first 0.5 meter fall, the velocity increases from 0 m/s to the terminal velocity. After the object falls 0.5 meter, the velocity remains constant.
The velocity of the object as it falls the last 1.5 meters is the terminal velocity.
Distance = terminal velocity * time
1.5 = terminal velocity * 5
Terminal velocity = 1.5 ÷ 5 = 0.3 m/s
This is the velocity of the object, after falling the first 0.5 meter.
a = -9.8 + bv
At t = 0, v = 0
a = -9.8
At terminal velocity, acceleration= 0
-9.8 + bv = 0
-9.8 = b * v
b = -9.8 ÷ v
v = terminal velocity
b = 9.8 ÷ 0.3
b = 32⅔ = 32.667
Now that we know the value of b, we can write the equation for acceleration.
a = -9.8 + 32.667 * v
Terminal velocity = 0.3 m/s
So this speed occurs during the time, when the object was accelerating/
Use the equation for acceleration!
a = -9.8 + 32.667 * 0.150
a = -4.9 m/s^2
To find the terminal velocity, we can use the formula v = v0 + at, where v0 is the initial velocity and a is the acceleration. At the point where the Styrofoam reaches terminal speed, the acceleration is 0 since it is no longer accelerating. Thus, we can set v = v0 + at = 0, and solve for v0.
Using this value of v0, we can then calculate the value of b using the equation b = (a + g)/v0. This will give us a more accurate value for b, rather than using the value of v calculated from the given data.
To find the acceleration at t = 0, we can use the equation a = -g + bv, where v is the initial velocity. Since the Styrofoam is dropped from rest, the initial velocity is 0, and thus the acceleration at t = 0 is simply -g.
To find the acceleration when the speed is 0.150 m/s, we can use the same equation a = -g + bv, but this time we know the value of v. Thus, we can plug in the values of g, b, and v and solve for a.
Overall, the key to solving this problem is understanding the concept of terminal velocity and using the appropriate equations to find the values of b and a at different points in time.
FAQ: Free Fall With Air Resistance Problem
1. What is "free fall with air resistance"?
"Free fall with air resistance" refers to the motion of an object falling under the influence of gravity while also experiencing the resistance of air or other fluids in its path.
2. How does air resistance affect free fall?
Air resistance, also known as drag force, opposes the motion of a falling object and reduces its acceleration. This means that an object in free fall with air resistance will not accelerate at a constant rate like in a vacuum, but instead will gradually slow down until it reaches a terminal velocity.
3. What factors affect the amount of air resistance experienced by an object in free fall?
The amount of air resistance experienced by an object in free fall depends on its speed, size, shape, and the density of the air it is falling through. Objects with larger surface areas, such as parachutes, experience more air resistance than smaller, streamlined objects.
4. How do you calculate the acceleration of an object in free fall with air resistance?
The acceleration of an object in free fall with air resistance can be calculated using the equation a = g - (kv^2)/m, where a is the acceleration, g is the acceleration due to gravity, k is the drag coefficient, v is the velocity, and m is the mass of the object.
5. Can air resistance ever be completely eliminated in free fall?
No, air resistance cannot be completely eliminated in free fall as long as the object is falling through a medium with air or other fluids. However, it can be reduced by changing the shape or size of the object, or by changing the properties of the medium through which it is falling.
