Free falling rotational motion
In summary, the conversation discusses the motion of a post with length L as it falls from its lowest point. The question is posed of what the velocity of the upper part of the post will be when it hits the ground. One person suggests using the energetic method and the other suggests using the conservation of mechanical energy. The formula v = √3gL is proposed but the person is unsure how to prove it.
vabamyyr
66
There is a post with length L and it is being cut down from its lowest point. So the post starts a free fall with circular trajector. The question is that what is the v of upper part of post when it hits the ground?
I used energetic method and mvL= 0,5mv^2 plus or minus something...
i have a feeling that it might be [tex] mgL= \frac 1 2 mv^2 - \frac 1 2 mgL \Longrightarrow v=\sqrt{3gL} [/tex]
but i don't know how to prove it? Can anyone help me?
It's just conservation of mechanical energy, treating the falling post as being in pure rotation about the lowest point:
[tex]\Delta {PE} = - \Delta {KE}[/tex]
[tex]mg\Delta h_{cm} = - 1/2 I \omega^2[/tex]
... etc...
FAQ: Free falling rotational motion
What is free falling rotational motion?
Free falling rotational motion is the movement of an object under the influence of gravity, where both its linear and angular velocities change over time.
How is free falling rotational motion different from linear free fall?
In linear free fall, only the object's linear velocity changes as it falls under the influence of gravity. In rotational motion, both the linear and angular velocities change as the object falls.
What is the formula for calculating the angular velocity in free falling rotational motion?
The formula for calculating the angular velocity in free falling rotational motion is ω = √(2gh/R), where ω is the angular velocity, g is the acceleration due to gravity, h is the height of the object, and R is the radius of rotation.
Can an object experience free falling rotational motion without a rotational force?
No, in order for an object to experience free falling rotational motion, there must be a rotational force acting on the object, causing it to rotate as it falls.
What are some real life examples of free falling rotational motion?
Some examples of free falling rotational motion include a diver performing a twisting dive, a falling leaf spinning in the wind, and a helicopter rotor blade while descending.
