MHB Free Modules - Another issue regarding Bland Proposition 2.2.4
  • Thread starter Thread starter Math Amateur
    Modules
The discussion centers on understanding Corollary 2.2.4 from Paul E. Bland's "Rings and Their Modules," specifically the proof that if f: R^(Δ) → F is an isomorphism and f(e_α) = x_α, then {x_α}_Δ forms a basis for F. It is established that {x_α}_Δ generates F since f is surjective, allowing any m in F to be expressed as a linear combination of x_α's. Furthermore, the uniqueness of representation is confirmed by showing that if a linear combination of x_α's equals zero, then all coefficients must be zero, confirming linear independence. This rigorous proof demonstrates that the conditions indeed imply {x_α}_Δ is a basis for F. The discussion effectively clarifies the proof's logic and structure.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am trying to understand Section 2.2 on free modules and need help with the proof of Corollary 2.2.4 - that is some further help ... (for my first problem with the proof see my post "http://mathhelpboards.com/linear-abstract-algebra-14/free-modules-bland-corollary-2-2-4-issue-regarding-finite-generation-modules-13196.html" )Corollary 2.2.4 and its proof read as follows:View attachment 3538
View attachment 3539The last sentence in Bland's proof reads as follows:
" ... ... If $$ f \ : \ R^{ ( \Delta ) } \ \rightarrow \ F $$ is an isomorphism and $$f ( e_\alpha) = x_\alpha$$ then it follows that $$\{ x_\alpha \}_\Delta$$ is a basis for $$F$$. ... ... "Although the above statement seems plausible I am unable to frame a formal and rigorous proof of the statement ...
Can someone please show me exactly why $$ f \ : \ R^{ ( \Delta ) } \ \rightarrow \ F $$ is an isomorphism and $$f ( e_\alpha) = x_\alpha$$ implies that $$\{ x_\alpha \}_\Delta$$ is a basis for $$F$$?
Help will be appreciated ...
Peter
Peter
First we verify that $\{x_\alpha\}_{\Delta}$ generates $F$.
Let $m\in F$. Note that $f$ is surjective.
Therefore $f(r)=m$ for some $r\in R^{\delta}$.
Now $r=\sum_{\alpha\in \Delta} r_\alpha e_\alpha$ for some $r\alpha\in R$ (where almost all of $r_\alpha$'s are $0$).
Thus, $f(r)=\sum_{\alpha\in \Delta}r_\alpha f(e_\alpha)=\sum_{\alpha \in \Delta} r_\alpha x_\alpha$.
Thus $\{x_\alpha\}_{\alpha\in \Delta}$ generates $F$.
Now we need to verify that each element of $F$ can be expressed uniquely as an $R$-linear combination of $x_\alpha$'s.
Say $\sum_{\alpha\in \Delta} r_\alpha x_\alpha=0$.
Then $\sum_{\alpha\in \Delta}r_\alpha f(e_\alpha)=0$.
Therefore $f(\sum_{\alpha\in \Delta} r_\alpha e_\alpha) =0$.
Which gives $\sum_{\alpha\in \Delta} r_\alpha e_\alpha=0$.
This leads to $r_\alpha=0$ for all $\alpha\in \Delta$.
Hence we are done.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
