MHB Free Modules - Another problem regarding Bland Proposition 2.2.3
  • Thread starter Thread starter Math Amateur
    Modules
The discussion centers on understanding Proposition 2.2.3 from Paul E. Bland's book on free modules, specifically the proof's assertion that any element in module M can be expressed as a finite sum of basis elements, where almost all coefficients are zero. The key point raised is the need for clarification on how the definition of a basis justifies this condition. Participants emphasize that the submodule generated by a set only involves finite sums, making the condition necessary. The conversation highlights the importance of grasping the definitions of basis and generation in module theory for a clearer understanding of the proof. Understanding these concepts is crucial for comprehending the structure of free modules.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am trying to understand Section 2.2 on free modules and need help with the proof of Proposition 2.2.3 - that is some further help ... (for my first problem with the proof see my post "http://mathhelpboards.com/linear-abstract-algebra-14/free-modules-bland-proposition-2-2-3-a-13179.html")
Proposition 2.2.3 and its proof read as follows:View attachment 3531The first line of Bland's proof reads as follows:
"Proof: $$(1) \Longrightarrow (2)$$. Since $$ \{ x_\alpha \}_\Delta$$ is a set of generators of $$M $$, it is certainly the case that each $$x \in M$$ can be expressed as $$x = \sum_\Delta x_\alpha a_\alpha$$ where $$a_\alpha = 0$$ for almost all $$\alpha \in \Delta$$. ... ... "Now, by definition of a basis, $$ \{ x_\alpha \}_\Delta$$ being a basis for M certainly implies that each $$x \in M$$ can be expressed as a sum $$x = \sum_\Delta x_\alpha a_\alpha$$ ... ...
... ... BUT ... ... how do we know that each $$x \in M$$ can be expressed as $$x = \sum_\Delta x_\alpha a_\alpha$$ where $$a_\alpha = 0$$ for almost all $$\alpha \in \Delta$$ ... ...
... ... specifically ... ... what/where in the definition of a basis is the justification for adding the condition "where $$a_\alpha = 0$$ for almost all $$\alpha \in \Delta$$"?
Hope someone can help,
Peter
Peter
Let $M$ be any $R$-module and $S$ be a subset of $M$.
Then the submodule of $M$ generated by $S$ is defined as
$$\{ \sum_{\text{finite}}a_is_i:a_i\in R, s_i\in S \}$$
Summing up infinitely many elements of a module doesn't make any sense.
Now coming to your problem.
If $X=\{x_\alpha\}_{\alpha\in J}$ is a basis of $M$, then $X$ generates $M$. Use the definition of "generation" as discussed above.
I hope this helped.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
